Old 09-29-2012, 01:44 AM   #4326
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
Originally Posted by 25rsti View Post
Did you disconnect the battery before swapping?
Yes I did, any ideas on what it can be?
dolosolow is offline   Reply With Quote
Old 09-29-2012, 10:53 AM   #4327
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Originally Posted by amroof View Post
You can try an upgraded wastegate actuator! I hold 18psi to red after peak boost of 24psi!
this actuator works very well. I and a few other of my friends and even my tuner uses them.
they make different pressure actuators too.
ha not the only one peaking to high psi and then tapering down. so much low end torque.
WhiteBgeye02 is offline   Reply With Quote
Old 09-29-2012, 04:29 PM   #4328
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
PM 'fastnoypi'... i believe he dealt with that code in his own car.
Torquey is offline   Reply With Quote
Old 09-29-2012, 07:52 PM   #4329
pgrily
Member#: 333354
What should battery voltage be at during upper rpms under load during a pull? I'm still getting stuttering in the upper rpms (~5900+). Last log, the battery voltage was getting down as low as 12.16v around 6500 rpm. I've tried switching the coil packs and the spark plugs are all good and gapped at .026. Seems like the stuttering is related to my battery voltage dropping under load.
Any help?
pgrily is offline   Reply With Quote
Old 09-29-2012, 09:45 PM   #4330
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
I want to say my volt meter is up around 14 volts normally when the car is running.
Unfortunately I haven't driven it in a few months so I can't verify that for you.
simon021 is offline   Reply With Quote
Old 09-29-2012, 10:13 PM   #4331
mark342
Member#: 284693
1999 Impreza 2.5 RS
STM
Yeah, alternator will read 13.8-14 at idle, but it goes down under load
mark342 is offline   Reply With Quote
Old 09-29-2012, 10:28 PM   #4332
PHruska
Member#: 214589
2002 wrx wagon
doing my timing belt on my v8 and got a tomei guide. the gap is definitely bigger than 1mm. anyone have this issue? there is no wiggle room on it.
PHruska is offline   Reply With Quote
Old 09-29-2012, 10:55 PM   #4333
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Mine was slightly more too.. but can't really remember it being an issue. Here's a pic I have after everything was put back together... low rez FTL
Old 09-29-2012, 11:07 PM   #4334
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Here's another suggestion made by WhiteBgeye02 that you could try out to even the gap...
Originally Posted by WhiteBgeye02 View Post
just so ppl do it right i take a piece of paper. fold it in half and put it between the timing belt guides and the belt. push the guide down and tighten the allens. pull the paper out and you have a close tolerance guide that wont let the belt jump. its pretty simple setup and doesnt really require a special aluminum guide. he is getting his harness from me. waiting on pins in the mail
Old 09-30-2012, 11:57 AM   #4335
simon021
Member#: 157532
2002 MY03 EJ207 E85
What are you guys doing for placement for the wide band bung since the o2 sensor bung is right there? Just welding in another bung on the opposite side or what?
Old 09-30-2012, 01:52 PM   #4336
navydub
Member#: 242585
2005 Saabaru
Mine was actually a little close to the belt, I felt. But the same thing, it doesnt have slotted holes so there was no wiggle room to adjust it.
navydub is offline   Reply With Quote
Old 09-30-2012, 08:28 PM   #4337
amroof
Member#: 211224
2005 Saabaru
Who knows
I Drilled a hole and welded it on the opposite side of the o2 bung. Works great and my wb matches my o2 at least on corn!
amroof is offline   Reply With Quote
Old 09-30-2012, 08:47 PM   #4338
simon021
Member#: 157532
2002 MY03 EJ207 E85
Sounds good. I picked up another ss bung so should have no problems
Old 09-30-2012, 09:39 PM   #4339
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
put it a bit farther down. like 8-12 inches from the turbine. reduces any swirling turbulence leaving the turbine wheel and straight flow exh gas instead.
Old 09-30-2012, 09:42 PM   #4340
simon021
Member#: 157532
2002 MY03 EJ207 E85
So put the factory 02 sensor where my wideband was and put the other bung farther down to relocate the wideband. Just want to be clear. This makes the most sense to me.
Old 09-30-2012, 10:48 PM   #4341
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Here is where I put mine. (Yes I know I could use more wrap) the downpipe was hanging way too low and was scraping on everything, it rubbed a lot of the wrap off. I fixed it and this is how it sits now. I haven't had any issues with the wideband in the bung you can see.
ImNOrobo is offline   Reply With Quote
Old 09-30-2012, 11:46 PM   #4342
PHruska
Member#: 214589
2002 wrx wagon
went to drop my v8 into my bugeye tonight and the motor mounts are off by a few inches. do i need to use the usdm bugeye motor mounts? the tranny is sitting high and left too and i cant figure out why.
Old 10-01-2012, 12:30 AM   #4343
Nuke209
Member#: 108089
2003 WRX
NF Performance
Should be direct drop in
Maybe chassis is issue?
Nuke209 is offline   Reply With Quote
Old 10-01-2012, 02:04 AM   #4344
PHruska
Member#: 214589
2002 wrx wagon
i know a bunch of other people have dropped v8s into bugeyes...
Old 10-01-2012, 06:27 AM   #4345
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I used my bugeye Group N mounts. But I used Sti mounts in my bugeye before. This is not the problem.
Are you trying to use the V8 front subframe? Even then, I don't think it should be a problem.
Old 10-01-2012, 09:11 AM   #4346
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
should drop right in. your prob doing something wrong. Everything motor mount wise bolts right up!
Old 10-01-2012, 10:05 AM   #4347
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
The mounts might be on backwards/reversed. They have to be on a certain way to line up properly.
I can take pics when I get home to show you what I mean
Are they stock or aftermarket?
todeswalzer is offline   Reply With Quote
Old 10-01-2012, 12:11 PM   #4348
PHruska
Member#: 214589
2002 wrx wagon
They're the stock Jdm mounts. I didn't move them since I was under the impression it would drop right in.
And no I'm using the bugeye subframe.
Old 10-01-2012, 12:33 PM   #4349
todeswalzer
Member#: 191495
'05 WRB GTX3071R
How are they off? Are the studs too wide apart?
Old 10-01-2012, 12:47 PM   #4350
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
My version nine dropped right in with the tigwerks mounts. Do you have the six speed hooked up still? I dropped mine with the trans still connected and the front drain plug was caught on the subframe, check that.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
