Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 09-27-2012, 04:00 PM   #1
Faster_Gun
Member#: 180217
2004 WRX WGN 348whp
1980 Diesel Rabbit 35whp
Default Catch Can Gurus Help!
I seem especially dense today and am having a hard time figuring out how I should configure my catch can with only one nipple on the turbo inlet. I'm sure I'm over looking something, help me find it!
Yellow are T's
Currently (which I think is wrong...):
What I want to do, but feels wrong:
Feels better, but oil mist all in my bay?
Faster_Gun is offline   Reply With Quote
Old 09-27-2012, 07:20 PM   #2
sfk1412
Member#: 290974
2005 WRX Wagon
http://forums.nasioc.com/forums/showthread.php?t=754710
This should answer any questions as well as how to hook it up.
sfk1412 is offline   Reply With Quote
Old 09-28-2012, 11:59 AM   #3
Faster_Gun
Member#: 180217
2004 WRX WGN 348whp
Yeah... It doesn't. I don't have enough inlet nipples. If I don't vent one to atmo I wind up sucking straight into my inlet. Of course this is no better then what I have currently...
I need sleep.
Old 09-29-2012, 09:44 PM   #4
sfk1412
Member#: 290974
2005 WRX Wagon
What turbo inlet do you have? on the stock inlet there's a nipple for the pcv. That's where your lost. I think.... i know perrins v1 inlet doesnt have a nipple for the pcv and you have to T it into your head breathers. picture number three would be the way you would do it. That's what I would imagine atleast
Old 09-30-2012, 12:14 AM   #5
03sportwagon
Member#: 252943
2003 wrx sport wagon
03sportwagon is offline   Reply With Quote
Old 10-29-2012, 01:48 PM   #6
Faster_Gun
Member#: 180217
2004 WRX WGN 348whp
The link above doesn't really help. It leaves me with a vent to atmo crank case.
Bump, I actually have time to do this now.
Old 11-02-2012, 03:37 PM   #7
super_usdm
Member#: 286211
1993 Legacy SS
Make a new hole in your inlet and run two cans is the best way to do it. One can for PCV and one for breathers. Connecting the two systems is not correct. It'll be better to run only one system to the can and leave the other alone if two cans isn't an option.
The issue I had trouble understanding was why connecting the systems is bad. Excessive blow by in the crankcase can potentially cause air to be forced back into the breather vents- which should be under vaccum. Not only that but you are lowering the vaccum on each system if you t into the line because they both go into one nipple on the inlet which is creating the vaccum.
super_usdm is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 03:14 PM.
