Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 09-30-2012, 12:31 AM   #1
chris the man
Member#: 287783
08 predator evo X
RR
Unhappy Thinking of Ditching the WRX...
so guys i really just have hit that wall.
im so tired of spending money on a car that cant even keep up with hondas. I have thousands of properly spent dollars into my ride. But i just think its time to go EVO.
my mods
stock 2.0l
intake
exhaust
68HTA
e85
rad
ic
1000ccs
dw 350
nitrous ic spray
full tunes
i just dont get it. is there a better platform that can atleast get me to keep up with something????
it seems that all you have to spend on any model EVO is just 2,000 and your already at 450wheel
version 7 is too limited
ej257 are ticking time bombs
am i just at that point that EVOs are really going to be a better power plant?
and suggestions
chris the man is offline   Reply With Quote
Old 09-30-2012, 01:11 AM   #2
jhayesvw
Member#: 326502
2003 WRX Wagon
the wrx is an all around good car but probably not the best car if you want only the most power or fastest times.
I bought mine because its a comfortable, well handling, decent power car with great aftermarket support.
the evo is smaller in the backseat and cheaper interior.
However, it is faster and cheaper to mod, but expensive to buy into.
locally evos are going between 16-21k for 03-06 models. similar to an STI, but way more than a wrx.
jhayesvw is offline   Reply With Quote
Old 09-30-2012, 01:47 AM   #3
chris the man
Member#: 287783
08 predator evo X
RR
i have to agree and support your good advice man.
my car truly is fantastic and its over 300wheel and pulls harder and harder everytime. I cant believe how reliable it is.
and my old momo interior is the **** lol!!!!!! you know bro?
but i really am looking to go faster, even if buying into costs more upfront. subarus out here are expensive they hold crazy value in CO
Old 09-30-2012, 08:11 AM   #4
OK Houston
we have an Uncle
sell it quick!!!!!
and this is a PRIME and juicy example of EXACTLY how to do it ALL WRONG in one easy fortune spent
Old 09-30-2012, 10:25 AM   #5
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
sell it quick!!!!!
- Rebuild the engine for a few grand with racing parts. Stop your bitching and keep it. ticking time bomb vs. crank walking ..hmm... equals out to be about the same with a less expensive price tag on the Subaru.
If you want to drive around a 40k EVO XXXXRIIVVV that looks similar to a giant praying mantis then go for it. best of luck to you.
FTW on stock 2.0
68HTA
e85
rad
ic
1000ccs
dw 350
nitrous ic spray
full tunes
white guys wrx is offline   Reply With Quote
Old 09-30-2012, 10:41 AM   #6
Overboosting04
Member#: 202417
04 WRX
EJ207/Rotated/E85/6spd
I agree with the op 100 percent, to have a fast reliable subaru costs alot more than it does to have an evo...but there are cons to having an evo too.
Overboosting04 is offline   Reply With Quote
Old 09-30-2012, 10:58 AM   #7
OK Houston
we have an Uncle
seriously....if the OP hasnt blown the trans outta the damned thing with all THAT....the tune is **** or something is seriously wrong somewhere
that thing should easily be at 330-350whp with all that **** and EASILY enough to smoke the trans, quick like
something wrong....likely the tune
Old 09-30-2012, 11:00 AM   #8
djuhnk
Member#: 331392
Have to say I agree to some extent. I have had two subarus now (lgt and my current wrx) and I'm not too impressed with the power capabilities. Awesome durability though. But when it comes down to it I'd take my old k20z1 way before these subaru 2.0's any day. High compression, low boost. Made 326 hp on 11.5 lbs of boost with a relatively large turbo that spooled faster than my 16g does. I miss it, but I definitely don't miss the fwd. Now we can talk about theoretical Mumbo jumbo all we want but there are definately better engines out there than these Subaru 2.0s and 2.5s
djuhnk is offline   Reply With Quote
Old 09-30-2012, 11:54 AM   #9
207STi
Member#: 197062
1998 Swapped Impreza
black
You started off with the lowest output usdm motor, then put a lopsided small-ish turbo on it and are mad that it doesn't keep up with evos? An sti would have been a better comparison
Old 09-30-2012, 12:07 PM   #10
chris the man
Member#: 287783
08 predator evo X
RR
the last thing im trying to do here is bash my subaru. i love my car.
so keeping on topic, im asking for suggestions, right now if i were to sell my car i would need about an extra 10,000 just to get into the evo scene.
what could i be looking at as far as a budget like that to spend to make some serious power, im just trying to see what is worth you know?
and yes i agree, we think my trans has a RA gear set, because i make well over 300whp.
and no im NOT trying to do an sti evo comparison. i agree sti and evo would be a better comp, but i dont have an sti.
what might you guys reccommend for a motor, trans? if the cost is over 10,000 to get me at 450whp then thats why i may go evo...
Old 09-30-2012, 12:18 PM   #11
207STi
Member#: 197062
black
I think an ej207 with a rotated turbo in the 35r range on E85 is capable of 450whp. A 6sp/r180 swap can be done for under 4k without the brembos. That's a little under 10k if you play your cards right and do the work yourself.
Old 09-30-2012, 12:21 PM   #12
chris the man
Member#: 287783
08 predator evo X
RR
this is something i think i may just look into!
i might do a 30r.
the cheapest swaps i can find are atleast 6k though...
Old 09-30-2012, 12:26 PM   #13
207STi
Member#: 197062
black
i might do a 30r.
Jdmracingmotors (a NASIOC vendor) has v7 ej207 swaps with the 6 speed for like 6k
Old 09-30-2012, 01:20 PM   #14
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
rally spec gears in the tranny :-| done and done. no 6speed swap needed.
Old 09-30-2012, 09:01 PM   #15
Shortpersonbk
Member#: 319017
2005 SAABARU 18g xt
JDM 6 speed
i love my ticking time bomb (sti)..and my 2.0L :P...i would not complain if i were you..i have a stg 2 automatic wrx wagon lmao...try building boost in that in 1st gear and get back to me..had some kind of hope that 17pound tune up pipe headers and turbo back would make it faster
Shortpersonbk is offline   Reply With Quote
Old 09-30-2012, 11:45 PM   #16
4wdwrx
Member#: 72042
2002 WRX impreza
WRB "Blue Mammoth"
Yours is definitely much faster than my stage 2.
But I enjoy how it drives and am not competing with anyone else.
There is always something faster but if you want power and speed, definitely go with something like Corvette, M3, Supra, Mustang, Camaro, Viper... etc.
4wdwrx is offline   Reply With Quote
Old 10-01-2012, 12:47 AM   #17
UK-Wagon
Member#: 232430
555 I haz 5 Subarus
GC8/GF/SG/GD sedan & wag
do us all a favor and go buy and EVO, and go about modding it just as wrong as you have done to this current WRX. Youre car is 10 F*ing years old and not modded correctly (its half ass at best) yet you expect it to beat EVOs. And nitrous???? oh boy......
Serious OP, EVOs are 3x the cost and 3x problems, 3x the insurance and dont forget 3x the Ego. So have fun with that
UK-Wagon is offline   Reply With Quote
Old 10-01-2012, 01:10 AM   #18
djuhnk
Member#: 331392
Not once did he say he wants his wrx to beat evos. He wants it to keep up to Hondas. And how is his car modded incorrectly?
Old 10-01-2012, 02:06 AM   #19
xlr8onu
Member#: 36015
Those Hondas are still going to beat the Evo. Had one, 06', turbo back with tune that was strong but those light turbo Hondas are hard to beat. The handling is the only place the Evo shines.
xlr8onu is offline   Reply With Quote
Old 10-01-2012, 02:49 AM   #20
Paul
Member#: 56203
00 RSTI Coupe
+2 How is this car modded incorrectly???!?
Maybe you guys need to reread it cause his mods are a perfect combo for a fast stock ej205. The Nitrous is used to cool the IC so thats only helping
OP: do what Ill proly end up doing: full ej207 swap for 7.5k and a rotated 30r kit. should do 350-375whp on pump and 425-475 on E85 tuned correctly (dyno jet numbers). Plus after you sell all your old parts you'll easily get several Gs back.
yea no one could drive a stock wrx trans with 350whp....it'd blow up at idle proly right?
sell it quick!!!!!
Have you ever thought about not being a douche?
Old 10-01-2012, 03:59 AM   #21
boostin20
Member#: 253104
boostin20 is offline   Reply With Quote
Old 10-01-2012, 10:14 AM   #22
tebriel
Member#: 244190
2004 BRP WRX Wagon
2004 JBP WRX
Didn't you know, the mods have to sign an agreement to make it as unpleasant as possible to post here?
tebriel is offline   Reply With Quote
Old 10-01-2012, 11:02 AM   #23
Dr. octagon
Member#: 171127
62XX Rotated
*Mo Displacement
my mods
stock 2.0l
intake
exhaust
68HTA
e85
rad
ic
1000ccs
dw 350
nitrous ic spray
full tunes
and suggestions
That turbo eats **** but noobs constantly buy this mother****er, and really this is exactly what i am talking about concerning not doing your homework on your car and parts effiency.
How is version 7 to limited and ej257 a ticking bomb? I would stop hanging with the mother****ers teaching you this **** and start over on your own.
Dr. octagon is offline   Reply With Quote
Old 10-01-2012, 12:12 PM   #24
2gnt2wrx
Member#: 123625
2002 wrx
vf34 Tuned at Cobb
As soon as someone lists a few grand worth of power mods then follows it up by "Full Tunes" it automatically discredits the entire post.
2gnt2wrx is offline   Reply With Quote
Old 10-01-2012, 03:30 PM   #25
classicaddict
Member#: 220619
04 wrx wagon
Enjoy the parts and labor cost of doing a clutch or turbo upgrade on an evo. Cake walk on a Subaru.
classicaddict is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 03:40 AM.
