Old 09-29-2012, 09:18 PM   #26
sfk1412
Member#: 290974
2005 WRX Wagon
Originally Posted by tebriel
I just replaced the passenger side, which was leaking. Is there any overwhelming reason why to do the driver's side as well?
Safety ha.
sfk1412 is offline   Reply With Quote
Old 09-29-2012, 10:54 PM   #27
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
well i kind of feel like why fix something isn't broke - worried that if I go to replace it - it will leak after lol.
tebriel is online now   Reply With Quote
Old 09-30-2012, 12:32 AM   #28
sfk1412
Member#: 290974
2005 WRX Wagon
Very true. Save it till it leaks or for a boring rainy day
Old 09-30-2012, 01:18 AM   #29
561wrx
Member#: 166427
03 wrx
But has any one change there PCV valve (NOT TRYING TO A BE A$$) because that can kill ur valve cover gasket with the quickness if u don't change it or any number of gasket that aren't made to take those crank case gases (Blow-by or Oil pan gases) and I will bit it will happen again if u didn't change it out.
561wrx is offline   Reply With Quote
Old 09-30-2012, 11:36 AM   #30
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
yeah the previous owner said he changed it, but that is something that I might do just for safety.
Old 09-30-2012, 01:25 PM   #31
Haelan
Member#: 151045
2013 Subaru STI
CBP
I had the dealership do it. The old one with the hose assembly is in the box of parts I gave you
Haelan is offline   Reply With Quote
Old 09-30-2012, 02:27 PM   #32
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
Okay cool. Yeah **HOPEFULLY** I fixed it... and didn't make it worse. :P
Old 10-01-2012, 12:10 PM   #33
rotheee
Member#: 291964
how many half moons are there?
rotheee is offline   Reply With Quote
Old 10-01-2012, 12:14 PM   #34
sfk1412
Member#: 290974
2005 WRX Wagon
4 I think
Old 10-01-2012, 01:23 PM   #35
hoffmanEstates
Member#: 122043
04 wagonier
psm
One for each cam?
hoffmanEstates is offline   Reply With Quote
Old 10-01-2012, 04:27 PM   #36
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
hehe. there's 2 per side.
The instructions I saw didn't say whether to put rtv under them, but the pieces I took out did have rtv on the notched edge - so I put some on there when I replaced them.
I don't think it's leaking unless it's super super slow. I parked over some cardboard let it run for a while, revved it, drove around, no drops that I saw immediately afterward.
Old 10-01-2012, 06:00 PM   #37
hoffmanEstates
Member#: 122043
04 wagonier
psm
Did you.let the silicone set..how long each.side?
Old 10-02-2012, 12:49 PM   #38
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
I used the Right Stuff grey for imports. I let it set about 16 hours before I started up the car. There doesn't appear to be any oil leaks, but I haven't done a lot of driving yet.
Old 11-05-2012, 07:52 PM   #39
hoffmanEstates
Member#: 122043
04 wagonier
psm
How it.holding up
Old 12-05-2012, 09:33 AM   #40
hoffmanEstates
Member#: 122043
04 wagonier
psm
Update?
Old 12-05-2012, 12:16 PM   #41
danger1138
Member#: 279525
04 rex luger!
Can u re-use the washers on the valve cover bolts or should u get new ones?
danger1138 is offline   Reply With Quote
Old 12-05-2012, 05:25 PM   #42
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
^^you can reuse them as long as the rubber portion is still soft. If they are hard then I would replace them.
recce02 is offline   Reply With Quote
Old 12-05-2012, 05:50 PM   #43
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
new ones are cheap enough, but if you are tight on budget you can clean and re-use, dab a little sealer on them for extra measure.
Old 12-05-2012, 06:44 PM   #44
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I just purchased a full set from the dealer and they cost about $40.
Old 12-05-2012, 08:53 PM   #45
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Wow, things went up, I bought my new set for around $27 from the dealer in TX when i rebuilt last year.
To the OP, FYI the grommets are $8.20 for sets of 5 on rockauto
Old 04-02-2013, 09:40 PM   #46
hoffmanEstates
Member#: 122043
04 wagonier
psm
Hows it holding up
Old 12-26-2013, 08:59 PM   #47
hoffmanEstates
Member#: 122043
04 wagonier
psm
holding up?
Old 01-08-2014, 07:56 PM   #48
shineyTwrex
Member#: 361473
Ive finally been hit with the problem,...
so on my 03 WRX, symptoms are fumes and gases coming from my passenger side Head/valve gasket. it dont see any signs of leaking, but strong gases and fumes from it, below the reservoir tank. smells like something is burning...
ive read it all, can my problem be the same thing? a bad gasket, but no leaks? just fumes or something burning.
Thanks and Thank you.
shineyTwrex is offline   Reply With Quote
Old 01-08-2014, 09:18 PM   #49
hoffmanEstates
Member#: 122043
04 wagonier
psm
could be axle boot torn flinging grease, something is wrong
Old 01-09-2014, 03:13 PM   #50
shineyTwrex
Member#: 361473
whole area there is clean, no mess or grease splats.
BUT! now it think its not the head//valve gasket...
smells like plastic or rubber mixed with a slight scent of exhaust being burned,... :|
thanks though dudes! going to follow my nose! :|
