Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 09-30-2012, 09:10 PM   #1
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
Unhappy keeping a level head
what do you guys do to keep a level head when you've been working on your car for well over an expected period of time?
like when there's that ONE bolt or nut...
or if there's less than a mm of space keeping you from something?
when your patience is just gone and you have to put the wrench down?
when it's a two man job and no one can help?
when you start breaking things when you're only trying to fix things?
A Fatal Ode is offline   Reply With Quote
Old 09-30-2012, 09:13 PM   #2
Shortpersonbk
Member#: 319017
12 sti 700+whp
I want 9sssss
when you drop your last wrench of that size under the motor..but don't care just enough to spend a hour finding it again
Shortpersonbk is offline   Reply With Quote
Old 09-30-2012, 09:14 PM   #3
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
and then you walk away... and realize that you were laying on it somehow or that it was stuck in a fold of clothing..
Old 09-30-2012, 09:20 PM   #4
the suicidal eggroll
Member#: 51961
2005 STi
I leave the garage, down 2-3 beers, then go back into the garage with:
1) less concern for perfection
2) less self-control when it comes to hammering something into place
It usually works itself out
Old 09-30-2012, 09:22 PM   #5
CmrnDrgn
Member#: 230605
VF39 HBSpeed Wagon
Don't lean onmah fenders!
I just walk away from the car, let out all of my fury and vengeance on a nearby inanimate object, sit down, drink a beer. Come back to the situation about an hour later and look at things from a fresh point of view.
CmrnDrgn is offline   Reply With Quote
Old 09-30-2012, 09:24 PM   #6
amroof
Member#: 211224
2005 Mystical
UniCorn FXTi
Just drink another beer! You will forget what you are doing and go right back to work ;-)
Old 09-30-2012, 09:24 PM   #7
modusvivendi
Member#: 214073
2008 Impreza WRX STi
Bsatin white pearl
i curse, drink a beer walk away for a minute, take a deep breath and go back at it. music helps too.
modusvivendi is offline   Reply With Quote
Old 09-30-2012, 09:26 PM   #8
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
see the key is to not let it build up. I do this by telling the bolt/coil to go **** itself several times a minute.
This makes me feel better.
tebriel is offline   Reply With Quote
Old 09-30-2012, 09:31 PM   #9
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
Old 09-30-2012, 09:32 PM   #10
Member#: 51961
2005 STi
Originally Posted by A Fatal Ode View Post
That too
Old 09-30-2012, 09:33 PM   #11
Saltine254
Member#: 312429
2008 WRX stg2++
Pearl
Well, beer seems to be the best answer. It helps numb the cuts and scratches that your hands tend to accumulate too.
Saltine254 is offline   Reply With Quote
Old 09-30-2012, 09:34 PM   #12
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
I just had that problem getting the crank bolt off my 91 CRX (dx....there's no hex fitting, so shut it, honda guys)
My impact gun didn't do it.
I bought a bigger gun....950 pound/feet.
Still didn't get it.
Put it all back together and decided that if it blows up from a broken timing belt, I'll put an integra B18 into it......
If the car was a keeper, I'd bring it to my mechanic and have him break it loose, then finish the job.
Old 09-30-2012, 09:34 PM   #13
CmrnDrgn
Member#: 230605
VF39 HBSpeed Wagon
^hahahah awesome. Having header/exhaust issues?
Old 09-30-2012, 09:40 PM   #14
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
there's this one nut on the bottom of the DP to turbo that i can't get a wrench on a have room to turn it. i have no clue how i got the DP off to begin with. i just did it. i've done it a dozen times. i have no clue why it's so difficult this time.
i've taken the dump of the EWG off and am about to take the entire EWG off to get even more room. this makes no sense. ...where's my beer.
Old 09-30-2012, 09:46 PM   #15
CmrnDrgn
Member#: 230605
VF39 HBSpeed Wagon
Hahahah you need to take a break, make a beer run, pick up a can of liquid wrench while you're out. Come back, spray the liquid wrench errrrywhere, shotgun a beer, then get back to work hahah
Old 09-30-2012, 10:17 PM   #16
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
i wish that liquid wrench could tighten bolts/nuts as well
Old 09-30-2012, 10:18 PM   #17
MaddMax
Member#: 9264
2012 WRX 5dr
Ice Silver
overcome
improvise
adapt
MaddMax is offline   Reply With Quote
Old 09-30-2012, 10:19 PM   #18
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
what baffles me is i took of the exhaust, dropped the trans, and replaced the clutch and fly... put everything back together... and now i'm hung up on one nut. it just blows my mind. but i know that the nature of this. one does not simply modify a car without breaking something.
Old 09-30-2012, 10:21 PM   #19
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
Originally Posted by MaddMax View Post
overcome
improvise
adapt
Old 09-30-2012, 10:28 PM   #20
leecea
Member#: 37359
When these things happen, I'm very glad I have a spare car so I can walk away and leave the stupid idiot thing sitting all broken in the garage.
leecea is offline   Reply With Quote
Old 09-30-2012, 10:37 PM   #21
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
on my first saturn I turbocharged I couldn't get the crank pulley off to get 1 oil pan bolt out. So I cut the oil pan bolt off with a sawzall. Ironically it never leaked even though it was missing that bolt.
Old 09-30-2012, 10:50 PM   #22
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
A lot of these answers have to do with drinking beer... So that seems to be the answer! BEER!
DSRX2005 is offline   Reply With Quote
Old 10-01-2012, 12:50 AM   #23
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
decided to try something new... it's not bad
Old 10-01-2012, 01:02 AM   #24
Reed7742
Member#: 286837
Beer is nearly always the answer.
But seriously, coming from an RX 8(motor is pretty much in the firewall, spark plugs underneath the car, oil filter mounted upside-down behind the motor) I just walk away when i get frustrated. I seem to always have at least 1 thing go wrong when I'm working on a project so I just expect for it and have a steady stock of beer.
Reed7742 is offline   Reply With Quote
Old 10-01-2012, 02:43 AM   #25
tmoftw
Member#: 327339
1996 Impreza Outback
Forest Green
good music, a friend to help or at least stand there and vent to if they're just supervising lol, and if all else fails, BEER. then back to work. possibly the next day depending on the strenght/quantity of said beer lol.
tmoftw is offline   Reply With Quote
