Old 09-17-2012, 01:17 PM   #151
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Originally Posted by decodeddiesel View Post
now I know exactly what I will be replacing it with. As a mechanical engineer, the development and design of this turbo really interests me. I hope these will be available soon. Any idea what injectors would be recommended?
They are available now - the 6258s are in stock and 6758s are coming in consistently. Deatschworks 1000cc or ID1000s is the recommended injector, and you can pair it with the DW fuel pump or a walbro 400lph works great for gasoline (walbro 416 if E85 is used)
Originally Posted by BoostinChick View Post
seeing these numbers I am really between this and the FR 1.5 GT3071R scroll kit. The only reason I am leaning towards the 1.5 kit is because it keeps my existing TBE as Phatron has already pointed out. This is exactly in my realm for my goals with the car. I want a fun daily that keeps the pep I have with the TD04, and I also love the twin scroll like the Evo 9's are set up with.
Question for Geoff: Will you guys offer an option for going EWG? If so, what about an option to re-route the plumbing back to the exhaust
Hello Boostinchick, The 1.5scroll kits are popular for the reasons you mentioned. Simple bolt on, allows you to keep TBE and existing turbo etc. However it can not perform at the same level as the EFR turbo (even on stock lower manifold). If you are a 2.5L considering GT3071R, the 6758 would be my recommendation. Conversely if you are a 2.0L the 6258 is suggested
With our EFR stock location you still retain the CBE, just need to change out your stock style DP, or get it modified to fit the EFR. The EFR turbos are simply too long to use the stock subaru config DP flanges.
Originally Posted by Mortal2None View Post
I think he means for the amount of $$$ and work you would put in to get a 600HP Subbie, you would have 1000HP on the EVO. (He's not saying that a 600HP subaru is as fast as a 1000hp evo, unless the evo was towing a yacht)
The fact that the evo can make 4-digit HP #s more easily is only good for forum bragging rights.. I believe the target HP for a awesome street and occasional track car is ~500whp, and thats the same for evo or sti. I Daily-D a fully built evo on slicks (built motor/trans/diffs/driveline/brakes etc). My responsive 500whp evo will smoke most any 700 or 800hp evo in all instances except full-on drag racing. I can use any turbo from any mfg to build the powerband I want, but I believe anything more than 500whp is a waste of time if the car will truly be used and driven on the street
Full-Race Geoff is offline   Reply With Quote
Old 09-17-2012, 02:48 PM   #152
Jdub.csu
Member#: 283784
2013 EVO X GSR
What is the rough price since your website doesn't list it
Jdub.csu is offline   Reply With Quote
Old 09-17-2012, 03:05 PM   #153
onefasazn
Member#: 45574
2003 NB2 E-Street
2004 GGA - Prodrive
What kind of numbers are attainable with the 6258 on an EJ20? I am at the fork in the road in regards to my car and can go the stock bolt-on route, or the FR/BW 6258 bolt-on route. I'm guessing the usual supporting mods are recommended for this turbo on a 2.0 as well. Looking at a Bosch 040, ID1000, possibly fuel rails, 3" hard inlet, etc.
onefasazn is online now   Reply With Quote
Old 09-17-2012, 05:53 PM   #154
Type2
Member#: 200436
2004 Forester XT
Borg Warner EFR 6758 Turbo (275-450 HP)
Starting at: $1,461.54 (twin scroll $200 more)
https://www.himni-racing.com/turboch...rbo-275-450-hp
Turbine Specs
* Turbine Wheel OD: 58mm
* Available Housing Option #1: T25 Inlet, 3" (92mm OD) V-band downpipe discharge, .64 A/R, w/ Internal Wastegate
* Available Housing Option #2: T4 Divided / Twin scroll Inlet, 3" (92mm OD) V-band downpipe discharge, .92 A/R w/ Internal Wastegate
Borg Warner EFR 6258 Turbo (225-400 HP)
https://www.himni-racing.com/turboch...3qk1amub8sqck1
Turbine Specs
Not sure why the prices are listed the same.
Type2 is offline   Reply With Quote
Old 09-17-2012, 06:51 PM   #155
BoostinChick
Member#: 218971
2007 WRX
Thanks for the info, Geoff! Definitely gives me a few options to consider for my 2.5L. I will be in talks with F.A.S.T of WC to help me determine which way I sway.
BoostinChick is offline   Reply With Quote
Old 09-18-2012, 02:28 PM   #156
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
6258 compressor map tops at 44 lb/min, this is enough to supply the 2.0L engine with air at 7000 RPM at ~23 psi counting some intercooler losses.
Theoretically a 44lb/min turbo would be capable of ~440 HP crank on good octane. But low efficiencies at that flow level on that turbo coupled with less than ideal EJ205 stock cams... I'd probably put that more around 400-420, then take out driveline and you're somewhere around 350ish WHP on good fuel on a conservative dyno, closer to 400 on an optimistic dyno.
Given what we've seen from the 7163, I would expect that power level would spool about like a small 16G or so. Probably ~3500 RPM give or take.
6758 is probably capable of only slightly more on an EJ205. at 23 psi, you're pretty close if not already over what the rods can handle reliably. You'd net some efficiency gain, but lose some response.
These are all just educated guesses / estimations. Don't hold me to the numbers. I tend to guess a little conservative though, I'd rather be surprised by more than disappointed by less.
Old 09-18-2012, 02:30 PM   #157
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Originally Posted by Type2 View Post
[information about prices of just the turbo]
I think he was talking about pricing of the Full Race kit, not just the turbo alone.
Old 09-18-2012, 03:44 PM   #158
Jdub.csu
Member#: 283784
2013 EVO X GSR
Correct
Old 09-18-2012, 07:31 PM   #159
onefasazn
Member#: 45574
2003 NB2 E-Street
2004 GGA - Prodrive
That about sounds on par with what I was thinking. We'll see I guess.
Old 09-19-2012, 11:33 AM   #160
Type2
Member#: 200436
2004 Forester XT
Correct
Their website says to call for prices. Did you call them and they refused to give you a price for the whole kit?
Old 09-19-2012, 12:03 PM   #161
Jdub.csu
Member#: 283784
2013 EVO X GSR
No when I had last looked they didn't have it up on the site yet
Old 09-19-2012, 09:24 PM   #162
jutes85
Member#: 127232
E92 M3
98' Foz
Any rough timeline on when/if a bolt-in 6758 FR kit will be available?
jutes85 is offline   Reply With Quote
Old 09-19-2012, 09:37 PM   #163
FASTofwestchester
Member#: 292964
1998 Legacy RHD TT
I have pricing ready to go.
PM me if interested.
Thanks,
Dave
FASTofwestchester is offline   Reply With Quote
Old 09-20-2012, 06:40 AM   #164
my99210kw
Member#: 180429
99 WRX
Dark green
In process of fitting EZ30r into GC8, which EFR turbo would you recommend for twin turbo set up to achieve 600+ HP atw?
Cheers,
Tony
my99210kw is offline   Reply With Quote
Old 09-20-2012, 04:05 PM   #165
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
6258 compressor map tops at 44 lb/min, this is enough to supply the 2.0L engine with air at 7000 RPM at ~23 psi counting some intercooler losses. Theoretically a 44lb/min turbo would be capable of ~440 HP crank on good octane. But low efficiencies at that flow level on that turbo coupled with less than ideal EJ205 stock cams... I'd probably put that more around 400-420, then take out driveline and you're somewhere around 350ish WHP on good fuel on a conservative dyno, closer to 400 on an optimistic dyno. Given what we've seen from the 7163, I would expect that power level would spool about like a small 16G or so. Probably ~3500 RPM give or take. 6758 is probably capable of only slightly more on an EJ205. at 23 psi, you're pretty close if not already over what the rods can handle reliably. You'd net some efficiency gain, but lose some response.
Thanks for posting, that is a well written assessment. Take a look at BorgWarner's MatchBot App using EJ20, 2.0L displacement, revving to 7000rpm, @ 21psi boost to reach your 420hp/350tq target (crank not wheels) agree, it is not wise to push the stock ej20 beyond this point
most Full-Race turbokits take ~3-4 weeks to ship after ordering, this is accurate for all singlescroll EFR turbokits at this time. we have 6258s in stock, more 6758s arrive next week (we just sold out)
Originally Posted by FASTofwestchester View Post
I have pricing ready to go. PM me if interested.
we're excited for you to test yours!
For a 3L displacement engine, the 8374 works well for up to 600HP, here is a matchbot that shows 667HP and 590tq @ 25psi.
I actually have this 8374 internal-WG turbo on my 2.0L daily driver @25psi and love it
Old 09-20-2012, 04:38 PM   #166
my99210kw
Member#: 180429
99 WRX
Dark green
I actually have this 8374 internal-WG turbo on my 2.0L daily driver @25psi and love it[/quote]
Thanks for that but what about twin turbo configuration?
Old 09-20-2012, 04:40 PM   #167
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
OOPS Twin turbo! thats a simple call - EFR 6258 x2 (sorry - brain fart, i read twinscroll)
for a twin turbo, i prefer twin 6258s to twin 6758s
Old 09-20-2012, 04:52 PM   #168
my99210kw
Member#: 180429
99 WRX
Dark green
Sorry for the next question Geoff but in the earlier days of this turbo line there were apparent reliability issues have these concerns been cleared up?
Thank you again for your help.
Cheers,
Tony
Old 09-20-2012, 05:11 PM   #169
jutes85
Member#: 127232
E92 M3
98' Foz
Is this kit available on your site? I can't seem to find it.
Old 09-20-2012, 08:35 PM   #170
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Sorry for the next question Geoff but in the earlier days of this turbo line there were apparent reliability issues have these concerns been cleared up? Thank you again for your help
yes, one of borgwarner's suppliers messed up on an early batch of 6258s, all were replaced under warranty and the rest of the EFRs have been solid.
Anyone who is a fan of Indycar Racing - there were zero EFR turbo failures during the IRL season. The teams all use EFR6758 x2 or EFR9180 x1
our "webguy" evan has been busy updating multiple new EFR kits, his deadline is oct30 (1st day of SEMA)- there will be many updates over the next few weeks
Old 09-20-2012, 11:20 PM   #171
my99210kw
Member#: 180429
99 WRX
Dark green
I like the fact that I can have waste gate and BOV all in one package. Bit more simple than my current EWG and seperate BOV that is not plumbed back due to plumbing issues(front mount GT35R). Hope the twin 6258's delivers on my high expectations with the
EZ30.
Thanks for the advice.
Old 09-29-2012, 03:46 PM   #172
oh1
Member#: 142708
I've had an eye on this kit for a while and prices are finally listed on the website. Hope to see some installs and results!
oh1 is offline   Reply With Quote
Old 09-30-2012, 08:41 PM   #173
BoostinChick
Member#: 218971
2007 WRX
I see it on their site now as well. Does the BPV/BOV block off plate not come with? I didn't see it in the kit picture. Also, I see that the downpipe has a hi-flow cat? Will that cause issues for those that will run primarily 93 octane, but occasionally E85?
Old 10-02-2012, 11:51 PM   #174
3mlwhly
Member#: 217648
01 2.5rs
so sick.. ive wanted a setup like this for a while now...
but im poor :-(
3mlwhly is offline   Reply With Quote
Old 10-03-2012, 12:04 AM   #175
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
My buddy just tried to smog his car with a high flow cat and failed. Might as well just go catless.
