Old 09-24-2012, 04:09 PM   #1
hardhitter_alert
Member#: 293841
2007 STi
Default timing belt cam marks don't line up
I took my timing belt covers off just to check that everything was okay and I noticed that the marks on the cam gears do not line up perfectly. Is this just from belt stretch and is in acceptable?
I lined up one side:
and the other side looked like this:
hardhitter_alert is offline   Reply With Quote
Old 09-24-2012, 04:14 PM   #2
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
turn the crank counter clockwise a half turn, then go back. Should line back up just fine, its due to some slack the tensioner is making up. If the belt is new and the marks are light up perfectly it should be fine. If you question it, try and start it up with it the way it is. you dont need the balancer or any of the covers on to check it. Just let it idle, if it runs smooth its probably fine. If it has a rough idle, well its off. You will need to take the belt back off and try again. Off by 1 tooth wont damage anything, itll throw a code for timing over advance bank 2 or bank 2, which ever is off.
UK-Wagon is offline   Reply With Quote
Old 09-24-2012, 04:21 PM   #3
hardhitter_alert
Member#: 293841
2007 STi
Here's a pic with the driver's side lined up:
and here is what the passenger's side looks like:
Old 09-24-2012, 04:22 PM   #4
hardhitter_alert
Member#: 293841
2007 STi
This is a 80k mile belt, not new.
Old 09-24-2012, 04:24 PM   #5
the suicidal eggroll
Member#: 51961
2005 STi
Looks normal.
The marks will line up when the belt is slack. Once you pull the pin in the tensioner it will make it look like either one side or the other is a half a tooth off.
Old 09-24-2012, 04:40 PM   #6
hardhitter_alert
Member#: 293841
2007 STi
I didn't touch the tensioner though. I just removed the covers on both sides. Or are you saying with the tension off it will line up?
Old 09-24-2012, 05:03 PM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
It's fine.
Old 09-24-2012, 05:06 PM   #8
hardhitter_alert
Member#: 293841
2007 STi
thanks
Old 09-24-2012, 05:23 PM   #9
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
start it with all the covers off!! dont put it together just to find out it is actually off. Start it up, if its off there will be an obvious misfire at idle speed
Old 09-24-2012, 05:39 PM   #10
Member#: 51961
2005 STi
Yeah, but the person who built your motor many thousands of miles ago did.
Old 09-24-2012, 06:13 PM   #11
hardhitter_alert
Member#: 293841
2007 STi
I took the radiator out so I can't really start it. It was running okay before I checked it.
Old 09-24-2012, 08:05 PM   #12
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
If you're afraid it's of, then buy a timing belt kit and go to it.
Old 09-24-2012, 08:39 PM   #13
hardhitter_alert
Member#: 293841
2007 STi
It's close so I was just checking. I already put it back together so I'll change it later.
Old 09-25-2012, 03:02 PM   #14
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^^Good Grief!!!!
Old 09-25-2012, 06:43 PM   #15
DoogieSTi
Member#: 247023
2007 STi
Its fine. It's a half tooth off. If you can figure out a way to adjust a half tooth then...You are fine. Stop worrying.
DoogieSTi is offline   Reply With Quote
Old 09-29-2012, 02:28 PM   #16
SubieWolfSti
Member#: 331579
2006 Impreza WRX STi
Gray
When in doubt, count the teeth, thats what i did and it came out great.
SubieWolfSti is offline   Reply With Quote
Old 09-29-2012, 02:32 PM   #17
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
80k on the belt and you put it back together when you were 90% of the way through replacing it? WTF!
Kids these days, replace the damned thing!
Old 09-29-2012, 03:11 PM   #18
hardhitter_alert
Member#: 293841
2007 STi
Haha it looked fine though. I didn't want to replace the belt, idlers, ect when I don't need to. Trying not to waste money?
Old 09-29-2012, 05:42 PM   #19
holyjoetart
Member#: 232986
07 Legacy GT
$300 timing kit vs. what you would pay when your valves contact a piston. I'm not saying it's going to happen, but if it did, I'm willing to bet you'd feel pretty dumb.
holyjoetart is offline   Reply With Quote
Old 09-29-2012, 06:13 PM   #20
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
How is it wasting money? You will have to do it in 25k anyway which means you have to tear it all down again. Hell, I just replaced mine which only had 10k on it while I had the right head off because it's cheap insurance.
Old 09-29-2012, 06:51 PM   #21
hardhitter_alert
Member#: 293841
2007 STi
It's like changing anything out more than it needs to be.. it costs more.
Old 09-29-2012, 10:13 PM   #22
Member#: 51961
2005 STi
90% of the way through replacing it??? He had the timing belt covers off...that's it. That's 5% of the way, maybe.
I don't know why everybody is harping on replacing the timing belt 25k before schedule when all he had done was pull the covers. That's a 5 minute job...that's nowhere NEAR the effort required to do a full timing belt replacement.
Old 09-30-2012, 11:25 PM   #23
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^^^^^^^^Agreed...............a full timing belt job with seals and wtr pump is a good hour and a half
Old 10-13-2012, 06:34 PM   #24
tbssubaru
Member#: 200058
2004 Forester XT
and you can run the car without the radiator for 15-20 seconds maybe longer just to hear how it runs without hurting it
tbssubaru is offline   Reply With Quote
Old 10-15-2012, 10:28 PM   #25
hardhitter_alert
Member#: 293841
2007 STi
It was running fine I was just checking.. let's just drop this
