Old 06-22-2012, 03:25 PM   #1
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Default Cheap OEM EGR/Air pump delete plates!
So today Im replacing head gaskets on a 06 Tribeca..... and I see this.....
Part# and $$ is on post#3
If this is something that has been discussed let me know, did a search and nothing came up.
*Update, on the RH side head you will need to drill the lower hole of the block off plate ever so slightly larger. The hole does not line up perfect but its really close. If you drill it larger it work just fine.
Old 06-22-2012, 04:33 PM   #2
StealthTL
Member#: 206912
2006 Forester XT
Why replace it?
StealthTL is offline   Reply With Quote
Old 06-22-2012, 04:45 PM   #3
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Part# 14754AA050
Retail $3.70
HERE you go kids!!! Sorry to the guys who make these as aftermarket.
Peeps should do research like this.
Pulled it off and test fitted it onto a set of 07 STi heads I have here in the shop. Bolts up exactly and uses the same metal gasket.
Old 06-22-2012, 04:46 PM   #4
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Originally Posted by StealthTL View Post
Why replace it?
For the air pump delete on 2007+ WRX and STi! You must not know what im talking about here. These retail from KStech for a lot more than $4
Refer to this
http://www.kstech.biz/servlet/the-Air-Pump-Delete/Categories
Old 06-23-2012, 12:59 AM   #5
20wrx09
Member#: 207417
2009 WRX
td06sl2-20gtx 413/423
will this work with both head ports?
the driver port is a different shape than the passenger
from kstech's site:
20wrx09 is offline   Reply With Quote
Old 06-23-2012, 01:20 AM   #6
StealthTL
Member#: 206912
2006 Forester XT
I realise what you were pointing out, I just wondered why you were upset that the air pump was missing, and why you would replace it! ( and not sure what a Ceap plate was....)
Good find!
Old 06-23-2012, 02:10 AM   #7
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
You can use the same plate for both sides. That shape for the other side is merely looks. The bolt pattern is the same and its just a flat plate that you can never see anyways. I checked it against both sides and it will work just fine. One plate is behind the Up pipe and you will never see it even if you were that picky.
Old 06-23-2012, 07:06 AM   #8
20wrx09
Member#: 207417
2009 WRX
i wasnt really worried about the looks of the plate. it was just the gasket has a different seal than the other. (should have specified that)
the same gasket could be used for both sides?
Old 06-23-2012, 08:55 AM   #9
9-2 wrx
Member#: 225759
2006 Saab 9-2X Aero
Nice find.
9-2 wrx is offline   Reply With Quote
Old 06-23-2012, 01:06 PM   #10
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Yes, itll work just fine.
Old 09-28-2012, 02:00 AM   #11
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
What gasket PN (or #s) is needed? Or would it just be cheaper to make your own gasket out of RTV?
-edit, helps if I read. Looks like I can just re-use the stock gaskets.. Derp Derp.
Mike 01Hawk is offline   Reply With Quote
Old 09-28-2012, 10:40 AM   #12
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Sorry if this is slightly off topic, would they work for tgv deletes? I saw something similar just couldn't find it again.
OC_Nooby is offline   Reply With Quote
Old 09-30-2012, 11:39 PM   #13
nutinbuthehits
Member#: 214758
no they wouldnt work for tgv deletes, but ks tech makes separate plates for that exact mod. check there site
nutinbuthehits is offline   Reply With Quote
Old 10-29-2012, 09:07 PM   #14
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Nice find !
anyone done this with pics showing the RH misaligned hole? Can I reuse the gaskets?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 10-29-2012, 09:32 PM   #15
stevejones19
Member#: 275250
2006 WRX
I have the plates but haven't installed them. I will take some pictures when I get to it if if nobody else knows.
But an FYI for anyone ordering them, expect a wait. I ordered mine at the dealer here and there was only one in the country at the time. And the other had to come from over seas.
stevejones19 is offline   Reply With Quote
Old 10-29-2012, 10:11 PM   #16
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
I ordered 4 and they will be in tomorrow. Ill post pics of the install for you guys.
Old 10-29-2012, 10:22 PM   #17
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Why 4? Did you get gaskets too?
Old 10-30-2012, 04:24 PM   #18
Zodiac
Member#: 325303
so if you are removing an existing air pump where would we get the gasket or does it already come with the kit from subaru?
Zodiac is offline   Reply With Quote
Old 10-30-2012, 04:34 PM   #19
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Any chance to post pics of plates and gaskets? What part number for the gaskets? Are you sure the getting the same gaskets will seal on both sides driver/passenger, it is a different geometry and contact patch.
Old 10-30-2012, 06:01 PM   #20
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
It works just fine i got a set and we installed them on my friends '12 sti with no problems. But as noted you will have to drill the holes out a bit for the odd sized one and yes the original stock gasket worked just fine and has had over 5k miles on it already. For $7 a set you cant go wrong lol.
nate_fisher is offline   Reply With Quote
Old 11-07-2012, 04:14 PM   #21
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Uk wagon? Pics?
Old 11-07-2012, 11:29 PM   #22
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Originally Posted by V8 GTFO Lesbic WGN View Post
Uk wagon? Pics?
Yep
The one on the Left has been drilled to fit the driver side.
Old 11-07-2012, 11:36 PM   #23
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
For 2 engines
You can reuse the gaskets, never had one leak.
Old 05-06-2014, 09:19 PM   #24
wrxchris2014
Member#: 351525
2013 WRX Limited
Sorry for bringing up an old thread but if i'm not mistaken, this will work with all the 08+ wrx/sti's? i have a '13 wrx and was just searching through different sites on how to remove the air pump system.
wrxchris2014 is offline   Reply With Quote
FS : KSTech TGV Deletes, Phenolic Spacers, Air Pump Delete Block-Off Plates yamsta Engine/Power/Exhaust 6 12-01-2011 07:55 AM
Cosworth Air Pump Delete Kit **Brand New** wrxmaniac Engine/Power/Exhaust 4 10-03-2008 02:31 AM
Air pump delete? Scooby89 Newbies & FAQs 6 05-05-2008 02:03 PM
Buschur Racing Air Pump Delete.. information? xmystikx Newbies & FAQs 3 04-19-2007 08:38 AM
Air Pump Delete Plates, Instock And Ready To Ship David Buschur Engine/Power/Exhaust 2 03-22-2007 03:33 PM
