Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 09-20-2012, 05:51 PM   #201
zaraa03
Member#: 332795
Hi everyone, I'm new here. Just got a 2012 Impreza premium. I have some existing Thule stuff I want to attach and I don't want to use the mounting points (I want to be able to take the rack off and use with another car if I want to). Does anyone know if the 480R and kit 1649 will work with the 5-door (Thule says it works for the 4-door but the hatch isn't listed). Thanks!
zaraa03 is offline   Reply With Quote
Old 09-22-2012, 07:51 AM   #202
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by gfxguy View Post
I also bought the Yakima Skybox 16s (which is 16 cu ft, but may not fit the same as the one you're asking about). It fit fine with the bars as far forward on the car as they could go (and the adjustable anchors on the Skybox as far back as they could go). The roof spoiler of the hatch makes contact with the Skybox when opened all the way, but it's not problematic.
Thanks for the info, I just ordered the same box! I'll be mounting it on Thule Crossroad feet with the square bars.
So you don't need to worry about your spoiler getting scratched when hitting the Skybox? Do you have the bigger optional spoiler on your hatch?
EDIT: Never mind. I see in the other thread where you posted a picture that you have the optional spoiler. I don't, so hopefully I won't have contact issues at all. Thanks for the info and pictures!
Old 09-25-2012, 03:42 PM   #203
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Hey guys, just received a Thule Hull a port and kayak feet. Anyone know if these will fit the Subaru factory cross bars? Or should I spring for the Thule Aero bars. I have a Premium 5 door.
Ladeef is offline   Reply With Quote
Old 09-26-2012, 11:21 AM   #204
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK, the front bar goes as far forward as possible.
How far back did you go with your rear crossbar? As far back as possible?
Old 09-26-2012, 04:49 PM   #205
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
As far back as the skybox anchor adjustments would allow, which places the crossbar pretty much right in the middle of the rear "hole" on the rails. About 30" spacing IIRC (front of front xbar to front of rear xbar).
gfxguy is offline   Reply With Quote
Old 09-27-2012, 12:22 PM   #206
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Got the Thule bars installed for the first time.
Now just waiting for Mr. UPS Guy to show up up later today with my Yakima Skybox!
Old 09-27-2012, 02:13 PM   #207
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
And here she is!
Old 09-27-2012, 04:11 PM   #208
superwhale
Member#: 330187
2013 WRX Limited
How much did that skybox run you? Hows the wind noise?
superwhale is offline   Reply With Quote
Old 09-27-2012, 05:33 PM   #209
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
Looking good!
Old 09-27-2012, 08:59 PM   #210
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
The best price I've seen is on Amazon:
http://www.amazon.com/Yakima-SkyBox-16s-Rooftop-Cargo/dp/B001PUZXGK/ref=sr_1_1?ie=UTF8&qid=1348790489&sr=8-1&keywords=yakima+skybox+16shttp://www.amazon.com/Yakima-SkyBox-16s-Rooftop-Cargo/dp/B001PUZXGK/ref=sr_1_1?ie=UTF8&qid=1348790489&sr=8-1&keywords=yakima+skybox+16s
I can't hear any difference between with vs. without the Skybox, even at highway speeds.
Oh, and with the box mounted as far forward as possible, there's several inches of clearance between the box and the hatch when I open the hatch fully. As you can see, I don't have the optional spoiler installed on the hatch.
Old 09-30-2012, 11:32 PM   #211
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
hey guys i need some help here...
i honestly have no idea where to start. can someone quickly list what i need?
first i'm assuming is rails that are perpendicular? after that cross bars?
JAMM0N is offline   Reply With Quote
Old 09-30-2012, 11:56 PM   #212
ans2k
Member#: 315631
2012 Impreza Sport
this thread is for the 2.0L NA impreza. i have no idea where to start for you. did the 2013 body style change since the 2012? if not, start there.
Old 10-01-2012, 12:06 AM   #213
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
no its the same. okay i'll check over there. thanks sorry i thought this would be a good place to start off.
Old 10-01-2012, 12:41 AM   #214
53x12
Member#: 206332
http://www.amazon.com/Yakima-SkyBox-...ima+skybox+16s
Have you had a chance to compare mpg's with vs without the box? How big of a drop have you noticed?
53x12 is offline   Reply With Quote
Old 10-01-2012, 05:02 AM   #215
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
My first road trip is this upcoming weekend. I'll report back after that.
Old 10-01-2012, 07:23 AM   #216
53x12
Member#: 206332
Thanks. My guess is a loss of 1-2 mpg based on what I have read. Look forward to hearing what you experience.
Old 10-01-2012, 12:25 PM   #217
ans2k
Member#: 315631
2012 Impreza Sport
with the yakima load warrior i lossed about 2-3 percent which is about 6 mpg ish at 65 mph.
Old 10-01-2012, 01:04 PM   #218
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
My hope is that the shape of my Yakima Skybox is more aerodynamic than having a bunch of stuff strapped onto a Load Warrior, and therefore will not impact fuel economy as much as you describe.
Stay tuned for actual data this time next week....
Old 10-01-2012, 01:14 PM   #219
ans2k
Member#: 315631
2012 Impreza Sport
yea, i believe you would be right. mine is very un-aerodynamic and makes quite a bit of wind noise. good luck.
Old 10-01-2012, 01:39 PM   #220
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
That much I can tell you right now. I don't get any wind noise at highway speeds with the Skybox mounted onto Thule square bars.
Old 10-01-2012, 01:44 PM   #221
ans2k
Member#: 315631
2012 Impreza Sport
mine is not that bad, it is more like having round cross bars and no fairing. i have thee aero bars attached to the car. i sometimes wish i got the sky box, but i like having the idea of tossing dirty items or relatively no height limit.
Old 10-01-2012, 02:16 PM   #222
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
So round cross bars are louder than square cross bars? I did not know that.
Old 10-01-2012, 02:43 PM   #223
ans2k
Member#: 315631
2012 Impreza Sport
well i didnt say that. i just said that my rack sounds like having round bars without the wind fairing. there is a noticeable howl/wind noise.
Old 10-01-2012, 03:00 PM   #224
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
With my Thule square bars (mounted onto Thule 450 Crossroad feet), I don't hear any noise regardless of whether my Skybox is installed, or if I'm driving around with just the empty bars.
Old 10-01-2012, 03:39 PM   #225
53x12
Member#: 206332
2-3% of 35mpg is about 1mpg.
WTB : roof rack crossbars for 08+ impreza tnguye09 NWIC Private Classifieds 0 11-16-2011 01:51 PM
Roof rail options for a MY97 Impreza L wagon? Levvy Interior & Exterior Modification 1 08-21-2005 11:51 AM
Roof Rack Options for '03 mikebike357 Forester Forum 13 05-19-2003 11:01 AM
MY02 TS roof rack options AllWheelDrift Canada Region Forum 2 03-09-2002 10:31 PM
Roof rack question for those Impreza OBS owners SubyLova General Forum Archive 3 12-04-2000 11:23 PM
