Old 09-29-2012, 06:11 PM   #1
Nemesis_STI
Member#: 325545
2006 STI
As stated I'm looking for the ecu definition for a usdm 06 Sti. I have ecu flash and romraider and the latest defenitions but cannot find an 06?? Any help is appreciated
-Justin
Nemesis_STI is offline   Reply With Quote
Old 09-29-2012, 06:52 PM   #2
OC_Nooby
Member#: 311781
2003 WRX w STI V8
2006 USDM Subaru Impreza STi MT A2ZJE11J 4312594006
http://www.romraider.com/forum/viewt...hp?f=35&t=7591
Is that what your looking for?
OC_Nooby is offline   Reply With Quote
Old 09-29-2012, 09:03 PM   #3
quazimoto
Member#: 70395
-Justin
If you have the latest definitions then what's the problem? It's in there. Sounds like you installed them wrong or did not tell the programs where they are. Read the FAQ's.
Old 09-30-2012, 12:29 PM   #4
Nemesis_STI
Member#: 325545
2006 STI
Thanks. Info have the latest definitions I was wondering which is for the Sti.
Thanks for the help
-Justin
Old 09-30-2012, 12:50 PM   #5
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
THink of it as a test, if you can't figure out the software stay out of your rom.
The Defs are either metric or standard for all the supported cars.
Old 09-30-2012, 07:51 PM   #6
quazimoto
Member#: 70395
Thanks for the help
-Justin
What exactly are you trying to do? If all you are trying to do is open the ROM then you are miserably failing at using this software.
Old 10-01-2012, 01:19 PM   #7
Nemesis_STI
Member#: 325545
2006 STI
Went away from romraider and d/l'd access tuner instead, want to do away with the maf tuning and go SD since I been tuning other platforms on SD for nearly 8 years now.
Old 10-01-2012, 02:23 PM   #8
quazimoto
Member#: 70395
Are you using Opensource or not? The individual definitions can be found in ECU flash. It's not that hard to find if you actually look for it. It's in the program files>Openecu>Ecuflash>rommetadata>Subaru>Impreza STI . Once again,what are you trying to do? Patch the definition with Speed Density?
Old 10-01-2012, 04:45 PM   #9
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
If you are using AcessTuner, you'll get better help in NASIOC's Cobb AccessPort tuning forum.
