Old 09-30-2012, 03:57 PM   #1
Sshantz
Member#: 323347
Default Screeching sound on cold start??
Hey guys. I have a 2002 wrx sedan with around 150k+ miles on it. So the problem is sometimes when I start the car after I haven't been driving it for a few hours (cold start) it gives off this really embarrassing loud screeching sound. The car runs fine, and the screeching only lasts for around 10-15 seconds. Never much longer than that. I searched and some people say idler pulley some say its the starter but I really have no clue. Any help would really be appreciated!
Thanks,
-Steve
Sshantz is offline   Reply With Quote
Old 09-30-2012, 04:13 PM   #2
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Check tension of belts and check pulleys... If you can't do that, take it to a shop
Old 09-30-2012, 04:42 PM   #3
rallymarty
Member#: 17418
2003 4Runner
If the sound is constant after you've released the key after starting, then you can generally eliminate the starter as the source.
More than likely, you have a loose belt which is slipping on a pulley. My 05 LGT has the same noise.
rallymarty is offline   Reply With Quote
Old 09-30-2012, 05:16 PM   #4
04reddragon
Member#: 216553
2006 wrx sti
gray
I can say from experience that its one of the pulleys for the ac belt give it a shot
04reddragon is offline   Reply With Quote
Old 09-30-2012, 05:21 PM   #5
Sshantz
Member#: 323347
Ok I'll look at my belts and let u know what I find.
Old 09-30-2012, 06:13 PM   #6
Sshantz
Member#: 323347
I checked it out and I'm pretty sure it was the pulley. I'll go get a new one from Subaru tomorrow and see if that fixes it. Just to make sure the pulley is the circular black one under the triangular ac compressor correct?
Old 10-01-2012, 10:40 PM   #7
cornercase
Member#: 306921
2004 WRX
When you start the car, spray the belt with water from a spray bottle. It doesn't take much. Just a mist from a windex bottle. If that kills the sound faster, replace the belt. If not, it's probably a pulley.
cornercase is offline   Reply With Quote
