Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 09-30-2012, 11:45 PM   #1
datboia84
Member#: 166057
2002 wrx ap stage 2
white
Default 02 wrx wheel hop and stutter from start
here the deal i have done reseach and ive spent alot of money on what they said but still getting the wheel hop when starting from stop in first gear. this is the list of items ive changed in the last 2 months and still have the dang wheel hop.
driveshaft
clutch
flywheel
rear diff bushings
outrigger bushing
motor, tranny and rear pitch mounts
struts and springs
all 4 new tires
please help only things i can think left is the drive axels if those still dont fix it ill go crazy thanks everyone.
datboia84 is offline   Reply With Quote
Old 10-01-2012, 08:38 AM   #2
Thermo
Member#: 317109
We'd need more detail on the "wheel hop."
Does it only occur in first gear? Does it only occur below a certain speed? Does it only occur when traveling straight-ahead / cornering / both?
Which wheels are affected - only one axle or both axles?
Does it occur only during acceleration or under constant speed as well? Does it occur continuously while these conditions exist or only for a moment - even if the conditions remain unchanged (i.e. same gear, same load, same speed, same steering input)?
Thermo is offline   Reply With Quote
Old 10-02-2012, 02:39 AM   #3
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
The chances of you having "Wheel Hop" are next to zero. Search for "clutch judder" and see if that more accurately describes your issue.
bushflyr is offline   Reply With Quote
Old 10-02-2012, 07:54 AM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
This...
What clutch did you install and did you install it because if THIS problem??
Old 10-02-2012, 09:01 AM   #5
datboia84
Member#: 166057
2002 wrx ap stage 2
white
sorry for the late response but yes i replaced the clutch because of this, thought it may have fixed the problem but didnt its a stage 4 clutch with a 12ilb flywheel. Dont know exactly which wheel or wheels are having the problem, it does it only when acceleration when dragging the clutch a bit also in 2nd gear the car will do it when dragging the clutch a little bit. but it has had the issues before installing all the items ive put on.
Old 10-02-2012, 09:49 AM   #6
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Originally Posted by datboia84 View Post
....its a stage 4 clutch with a 12ilb flywheel.
There's your problem right there.
from Vitek:
Stage 4 - .... It is not designed for your daily driver car. .... you will probably experience moderate chatter. ... it is either engaged or disengaged with no ability to ease into the clutch. Its optimum use is designed for rally racing.
It's not a "wheel or wheels". 02's are known to have clutch judder or chatter on the stock parts, just slip the clutch and let it warm up a bit and it'll be fine. By putting on some monster racerboi clutch you just made it worse. At this point you should just quit throwing parts at it and learn to live with it or go back to stockish.
Old 10-02-2012, 11:56 AM   #7
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
This
from Vitek:
and this...
Old 10-02-2012, 05:49 PM   #8
datboia84
Member#: 166057
2002 wrx ap stage 2
white
but it was doing the samething with the factory clutch that was in there before... but i guess i see what yall are talking about i guess the 6 puck is to grippy for it what your saying. yea its not that bad when i dont push on the gas when disengaging the clutch, its just sucks because theres not much room for it so i die out every now and then. thanks for the input yall.
