![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1151 | |
Member#: 276118
SCIC
Vehicle:2011 WRX OBP |
#1152 |
Member#: 260501
AKIC
Vehicle:2011 WRX 5dr SWP Ltd |
So winter setups aren't discussed here much but this seems like the appropriate thread. I've been thinking about picking up some steelies and someone pointed out to me that they need to be 16"s to clear WRX brakes. Before I was looking at 14"s since tires are so damn cheap with that diameter, and the thought just occurred to me, I was thinking about getting spacers for the stockers anyway. So now I'm wondering if it would be practical, and I can't think why not. There's lots of 14"s on CL for $100 or less, along with the tire savings would probably pay for the spacers. Anyone have an idea what the offset of most 14" steelies are or what size spacers would be necessary?
Mostly talking out loud here. |
#1153 | |
Member#: 261845
Tri-State
Vehicle:2011 WRX Silver EFI logics stg 2 |
#1154 | |
Member#: 261863
MAIC
Vehicle:2011 WRX TP Stg 2 SSM |
#1155 |
Member#: 41447
MAIC
Vehicle:---- _________ |
couldnt find it in here, but will bugeye 16" wheels fit on the 11+ without spacers to clear the brakes?
#1156 | |
Member#: 283784
RMIC
Vehicle:2012 SWP WRX HATCH White |
#1157 | |
Member#: 276118
SCIC
#1158 | |
Member#: 260501
AKIC
#1159 | |
Member#: 306659
TXIC
Vehicle:2012 Impreza WRX Obsidean Black Pearl |
#1160 |
Member#: 260501
AKIC
Right, my bad. Oh well, thanks.
#1161 | |
Member#: 97135
NWIC
Basically......unless buying very specific 15" wheels, you need 16's. |
#1162 |
Member#: 260501
AKIC
Yeah, Braids are my dream but I'm poor. I appreciate the clarification though.
Not entirely off topic, I might just stick with stock for the sole reason of the TPMS, I CANNOT live with the light and new ones are expensive. |
#1163 | |
Member#: 97135
NWIC
#1164 |
Member#: 284187
SCIC
Wheels: Te37sl Black 18x9.5 +40
Tires: 255/40/18 RE11 Suspension: KWv3 How does this sound as a street car for the track? any disadvantages with going with these specs? |
#1165 | |
Member#: 260501
AKIC
#1166 |
Member#: 239546
NWIC
Vehicle:2011 WRX TP Stg2+AEM Spark Silver Sedan |
Curious if I would have issues running 17x9 +35 on a '11 WRX lowered on H&R springs... Tire is a 235/45/17
Thanks in advance if someone knows. Most likely rubbing on bumps or peeps in the back. Would I just need rear rolled, or would running camber be recommended? |
#1167 | |
Member#: 283784
RMIC
Only disadvantage is steering feel with wider more offset tires is less. Weight can effect response. What is the weight of those? |
#1168 |
Member#: 317045
Vehicle:2012 WRX Hatchback SWP |
yeah, the 255/40-18 will be too tall. Try the 255/35-18 size. This size will be a little shorter than the 265/35-18 but will give you better steering feel and will allow you to accelerate out of the corner slightly faster. They will probably also be a little lighter than the 265 (same tire model).
Another route is to go with 17" wheels. 17x9" and 255/40-17 tires. Or go to even lighter stock sized wheels at 17x8" and 235/45-17 tires that are really really sticky! This will give you the best steering feel too. Last edited by texascanuck; 09-27-2012 at 11:25 AM. |
#1169 |
Member#: 278510
Vehicle:2011 WRX Hatchback Red |
How does the +38 offset compare to the +40 offset
I'm looking at 18x9.5 5x100, enkei rpf1 id like the +40 offset but they only look to come in +38 What tires with that offset? Last edited by redwrx11; 10-01-2012 at 11:59 AM. |
#1170 | |
Member#: 97135
NWIC
265/35. |
#1171 |
Member#: 298002
BAIC
Vehicle:2011 WRX Base Obsidian Black Pearl |
#1172 | |
Member#: 292699
MAIC
Vehicle:2011 WRX Sedan DGM Stg1+ SF |
Read through the thread man....extremely common setup and if you lower you are going to most likely roll with either tire. Rolling fenders is not a big deal.... |
#1173 |
Member#: 276118
SCIC
Alright guys I'm looking at going wider now. I've been using my stock wheels with star specs on them for autocross and I've gotten to the point that bigger tires and bigger brakes are where I'm going to be making time. So I'm looking at going all out here. I was a nice 17x9.5 wheel 5x100 that's not going to be dumb expensive. Enkei rpf1 seems like a good choice to me. But I'm more concerned about offset. I want to run a 275/35. Has a slightly shorter diameter so acceleration should improve out of the corners too. Also anyone here have any experience with the Hoosier a6 tire? Star specs are great but I'm looking for something more aggressive.
#1174 |
Member#: 313693
Vehicle:2012 WRX 5-Door OBP |
We have not yet tried 285/35R18, for a couple of reasons. One is that the tire is 2.1% larger than the stock 2011+ WRX tire, slightly over our 2% rule of thumb in terms of variance from stock.
Dan- How did you compute for the 2.1% variance comparing 285/35R18 vs 235/45R17 (stock)? Curious as to how I could use this as a benchmark. Thanks! |
#1175 | |
Member#: 276118
SCIC
| Thread Tools | |
| Display Modes | |
| Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
| need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
| Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
| WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
| Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
