Old 09-25-2012, 03:28 PM   #1
wrX-MEN
Member#: 330488
03 WRX
Default help please info for tire replacements
Hi everyone, this is my first awd car and I just learned that if I have one flat tire, I have to replace the whole 4 tires because of the differentials.
So my question is I have a set of used tires with the same size but it was from a fwd car of my cousins acura,can I use that? And also I have a used one from an audi a4 of my co-worker is that possible I can used those just for few months before I buy my winter tires?
wrX-MEN is offline   Reply With Quote
Old 09-25-2012, 05:39 PM   #2
sc00by4life
Member#: 97135
wear patterns on the FWD car will probably put them out of spec.
same with the a4 unless its a quattro.
Old 09-25-2012, 08:47 PM   #3
wrX-MEN
Member#: 330488
03 WRX
about the a4, isn't all a4 awd? so does that means that it's gonna be equal wear on the tires right? and also i don't know if it's going to make a difference but the tires we're originally put on an audi S4 then switched to the a4 few months ago and now im thinking of buying it from my co-worker so I can use it for couple of months before I switch to winter tires.
thanks for the help
Old 09-26-2012, 05:59 PM   #4
sc00by4life
Member#: 97135
thanks for the help
Only Quattro a4's are awd.
We really can't say for sure unless we can see the tires or you post tread depth measurements..
Old 09-26-2012, 08:34 PM   #5
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
AWD does not mean all tires wear evenly. Alignment, handling balance, and weight distribution all play roles. Most, if not all, F/AWD cars wear down the front tires faster, especially Subarus
Old 09-28-2012, 05:11 PM   #6
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
not all Audi A4's are quattro some are FWD ...
it is not recommended to mix tires on an AWD car ...
you could purchase 1 new tire and have it shaved to match the existing three ...
Luke@tirerack is offline   Reply With Quote
Old 10-02-2012, 11:01 AM   #7
Belyanin
Member#: 333576
Why do all 4 tires have to be replaced? I don't understand this. Any info would be helpful. New to the car scence.
Belyanin is offline   Reply With Quote
Old 10-02-2012, 11:38 AM   #8
krzyss
Member#: 8365
2013 Ford Focus SE
RTFM
Krzys
