Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 09-26-2012, 12:09 PM   #76
Extreme Turbo Systems
Member#: 194655
08 STI
Originally Posted by V8 GTFO Lesbic WGN View Post
You may have a point but not half, 32 Charge Rows (Competitors: 24 Charge Rows), which still should make a noticeable difference. 99% of aftermarket TMIC users buy silicon y-pipes or am I missing something? Will my Forester stock y-pipe work with the ETS then?
What is the difference between the 2005-2008 Forester TMIC and 2004-2007 STi TMIC of same year range?
2005-8 FXT
2004-7 STi
Depends which vehicle TMIC you look at. The 08+ is 39 charge rows.
Extreme Turbo Systems is offline   Reply With Quote
Old 09-26-2012, 01:23 PM   #77
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
@ETS
1) 2005-8 FXT
2) 2004-7 STi
Will the FXT stock Y-pipe fit 1 and/or 2?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 09-26-2012, 06:44 PM   #78
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
@ETS
1) 2005-8 FXT
2) 2004-7 STi
No, I have my stock FXT pipe here and it is different. The inlet ports from the FXT will fit the intercooler and the ports will match but you will need a STI Y portion (from the 2 piece y-pipe version) to make it complete, that or an after market silicon Y.
Sounds like you should just buy the PW if it comes with a y-pipe and splitter. It is a good TMIC!
Old 10-02-2012, 04:18 AM   #79
Methodical4u
Member#: 217546
Michael... I guess you didn't see my question back in March lol. Does your TMIC fit the 2012 wrx's? If not... is there a way to make it fit ? Anyone know?
Methodical4u is offline   Reply With Quote
Old 10-02-2012, 12:42 PM   #80
ians
Member#: 64173
2011 Impreza WRX
lightning Red
Is anyone out there running the PW TMIC on an 11 or 12 WRX with the SPT strut tower brace on? I'm looking at model #PRW PWTMIC07. Asked the question on Rallysport direct and they essentially said they were not sure. Anyone know?
ians is offline   Reply With Quote
Old 10-02-2012, 12:53 PM   #81
jay25RS
Member#: 4273
2011 GR-STI
& 2015 Legacy Ltd.
Just change out your intake manifold, turbo, shroud, mounting brackets, and then you'll be able to drop in an ETS intercooler in your 2012 WRX!
Old 10-02-2012, 01:09 PM   #82
Member#: 194655
08 STI
No, the TMIC will not fit the WRX. The intercooler is different. We do have plans to build one, but right now we are under heavy development and R&D. We will have more great products out shortly!
Old 10-02-2012, 01:25 PM   #83
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^What is the difference between the 2005-2008 Forester TMIC and 2004-2007 STi TMIC?
Old 10-02-2012, 01:31 PM   #84
Member#: 194655
08 STI
To be honest, i'm not 100% sure, but I'm going to have one of my guys look into and get a response back to you. I did a couple quick searches online and it seems that the Y-Pipe is different, so if you want to run the STI TMIC you need to get an STI Y-Pipe as well. I will get confirmation on this though. I do have a customer with our STI intercooler on his Forester.
Michael
Old 10-02-2012, 01:40 PM   #85
manitou
Member#: 193757
2006 XTI Limited
Michael
I had a stock STI intercooler on my Forester and it was an easy bolt on. I had to mod the firewall AC line with a little bending and vinyl hose warp of areas that interfered. I posted above that the stock Forester Y pipe and the stock STI Y pipe are different. ^^ see above.
I now have an ETS TMIC on my 2006 Forester XTI using the stock STI Y pipe and it fits great. The fit of the ETS intercooler is better than the stock STI intercooler.
Old 10-02-2012, 02:06 PM   #86
Member#: 194655
08 STI
Awesome! Thanks for the feedback. You might have been the customer I was thinking of that put tons of work into his forester with the interior swap, etc.
Michael
Old 10-02-2012, 02:15 PM   #87
manitou
Member#: 193757
2006 XTI Limited
Michael
Ya dat be me Wait till you see what's going on with it now. Keeping the ETS top mount but it will be maxed!
Old 10-02-2012, 02:17 PM   #88
manitou
Member#: 193757
2006 XTI Limited
Michael, Do you have or could you make me a high flow y pipe for your intercooler?
Old 10-02-2012, 02:23 PM   #89
Member#: 194655
08 STI
can't wait
Not currently, we haven't ran into any flow restrictions or excess back pressure off the factory unit even with a 35R on the car.
Michael
Old 10-02-2012, 02:26 PM   #90
manitou
Member#: 193757
2006 XTI Limited
Do you have a stock you could sell me? I need another for my stock STI IC.
Old 10-02-2012, 02:44 PM   #91
Member#: 194655
08 STI
I don't. A customer already purchased our stock IC and Y-pipe. You might check on Car-Part.com
Thanks!
Michael
Old 10-02-2012, 02:53 PM   #92
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
@ETS, I am asking for clarification about the difference between:
ETS 2004-2007 Subaru STI Top Mount Intercooler: ETS-SUB04-TMIC
VS
ETS 2005-2008 Subaru Forester XT Top Mount Intercooler: ETS-SUB04-TMIC1, the Forester ETS TMIC has a C1 at the end of Part Number.
Old 10-02-2012, 05:04 PM   #93
Member#: 194655
08 STI
The TMIC for both cars are the same. Our Forester intercooler requires the use of the STI Y-Pipe. We have it listed with a 1 at the end because the website doesn't allow duplicate part numbers. We list them individually so people will know it fits the forester as well as the STI with the use of the STI Y-Pipe.
Old 10-02-2012, 05:44 PM   #94
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^Understood, thanks.
But your website is still misleading, mixing descriptions of TMICs, showing pics/vid with no studs and end tanks fabricated, not cast.
Old 10-03-2012, 12:47 AM   #95
kaos200
Member#: 2692
Wait a minute.... The ETS STi intercooler end tanks are cast?
We just ordered one for a build, and that was NOT what we were expecting...
The website shows nicely fabbed tanks...
kaos200 is offline   Reply With Quote
Old 10-03-2012, 01:27 AM   #96
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Old 10-03-2012, 01:36 AM   #97
kaos200
Member#: 2692
What... the... heck.
Why are they all so nicely fabbed from aluminum plate on their website? We won't be using this intercooler then.
Old 10-03-2012, 01:36 AM   #98
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Has the hard line gap vs end tank been addressed?
Also what CFM?
And how much does it weigh STi 2004-7 specific?
Old 10-03-2012, 01:48 AM   #99
kaos200
Member#: 2692
To quote their website....
The end tanks are hand built and hand ported for maximum flow, fit and finish.
1) Hand built to me, implies fabbed up/welded up plates
2) Why would you port that if that was the case?
These statements are contradictory to me.... I really hope we don't receive a cast intercooler in the mail this week....
Just doesn't make sense, there is a STACK of them shown in the photo on their site. Why would they ship cast versions?
Old 10-03-2012, 10:49 AM   #100
pux888
Member#: 8356
02 STi swap
12 WRX limited
The end tanks are cast man, not the core itself... Its a nice piece.
pux888 is offline   Reply With Quote
Process West vs stock tmic caperex09 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 46 06-11-2012 08:43 PM
FS : Process West TMIC - 700 obo APriestOfGix SCIC Private Classifieds 30 04-13-2012 12:17 AM
Perrin vs Process West TMIC Bean-Counter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 98 04-27-2011 12:22 PM
process west vs sti tmic alphaomega0 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-10-2009 12:10 PM
STI TMIC Vs Process West TMIC snowmanwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-01-2009 12:54 PM
