10-01-2012, 06:23 PM | #1 |
Member#: 142608
TXIC
Vehicle:2003 Sonic Yellow Marginally well behaved. |
Dyno Tune: Cobb Plano + 03 WRX + NEW Forced Performance HTA71 makes 426 WHP/417 WTQ
Event: dyno pull
Location: Cobb Tuning Plano, Tx. Ambient Temp: 95 degrees Elevation: Unknown Weather: Sunnny & Humid Car: 2003 Sonic Yellow WRX Tuner: Calvin Dotson - Cobb Tuning Dyno Info: Mustang Transmission: 5spd ppg gearset Gear: 3rd Peak HP at RPM: 426 HP @ 6000 (uncorrected) Peak Torque at RPM: 417 @ 4000 (uncorrected) Baseline hp/tq for a stock on same dyno: Target Boost: 23 psi Target AFR: 11.7 Fuel: E85 Engine/Power Modifications: Watt's Shop Built 2.5L, CP Pistons (9.2:1 CR), Pauter Rods, 2.0L Heads, EQ Tuning CNC Chambers, 2006 STi Camshafts, BC valvesprings, Forced Performance HTA71 with advanced flow port, Internal Wastegate, FP 84mm turbo inlet, ETS Top-Mount Intercooler, KS Tech Intake, Invidia Catless DP, GT Spec UEL Header, ID 1000 injectors, DW 300lph in-tank. Driveline Modifications: PPG 5-Speed, OBX Front Diff, Kartboy shifter and bushings, Group N Engine/Trans Mounts, Positive Shift Kit, Diff lock bolts. Suspension Modifications: BC Coilovers with custom valving and spring rates, Cobb Sway Bars, TIC Enthusiast Control arm bushings, Whiteline Positive Steering Response Kit, Vorshlag Camber Plates, STi Control arms and lower rear links, Front and Rear strut mounts, under car cross-bracing. Other Modifications: STi Steering Rack.
10-01-2012, 07:28 PM | #2 |
Member#: 165104
SCIC
Vehicle:E85 SoCalPorting Owner |
How did this turbo respond? Well, in your opinion and the tuners? Its looking good so far
10-01-2012, 08:53 PM | #3 |
Member#: 142608
TXIC
Both me and my tuner were both very impressed with the response of this turbo. We actually ran out of injector...at 26-27 psi, this turbo should make 470-490 WHP.
It actually spoools very fast for the power that it makes. |
10-01-2012, 08:58 PM | #4 |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
Hardwire and FPR with more base pressure?
10-01-2012, 09:18 PM | #5 | |
Member#: 165104
SCIC
10-01-2012, 11:36 PM | #6 |
Member#: 285777
Vehicle:2004 STi- |
very impressive torque curve with internal wastegate
id like to see some engine bay shots of ur setup! |
10-02-2012, 01:53 PM | #7 |
Member#: 83069
TXIC
Vehicle:2007 STi 302/350 UGM Wingless |
10-02-2012, 02:57 PM | #8 |
Member#: 142608
TXIC
Probably...down the road. Didn't really want to have to put aftermarket fuel rails on it...looks really clean this way. I'm really happy with it right now...and as an autocross car, it makes more than enough power.
Now i just have to re-learn how to drive it with 100 more WHP. |
10-02-2012, 10:40 PM | #9 |
Member#: 207905
TXIC
Vehicle:2005 forester xt silverf |
How is running higher comp pistons? I'm in the process of building a 2.1 stroker and am advised to stay away from higher compression because it's mote knock prone.
10-02-2012, 10:54 PM | #10 |
Member#: 142608
TXIC
Havn't had any issues. The off-boost response is excellent and the engine takes boost like a champ. Tuner did not have any knock issues when tuning the car. he actually wished we had had a bigger injector or more fuel pressure to turn the boost up.
10-03-2012, 02:11 AM | #11 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
E85 has tons of margin in it at stock CR. You sure will see these issues with a 0.5-1 point CR bump on pump gas, but on E85? Shouldn't see knock with such a small bump in compression.
10-03-2012, 08:36 AM | #12 |
Member#: 81102
South East
Pretty interesting, shawn. How does she spool on the street?
No avcs, right? Carmi (new sn) Last edited by CatfaceType-R; 10-03-2012 at 08:48 AM. |
10-03-2012, 02:59 PM | #13 |
Member#: 181995
Vehicle:2003 WRX WRB |
Pretty excited to see this seeing as I have a 71HTA on order my self. Although I'm putting mine on a stock 2.0L in a 2003 WRX. I'll be running pump gas as well, so I'm not expecting these kind of numbers. Either way that's pretty impressive.
Have you seen this turbo on a 2.0L? I wonder how much different it will spool...I'm getting my stock manifold ported with a new crosspipe and EWG. |
10-04-2012, 07:34 AM | #14 | ||
Member#: 142608
TXIC
No, no AVCS, which i'm regretting just a little bit with this build. I think the power would have come on a lot smoother and a bit sooner with it. Quote:
I would personally think this turbo really needs E85 to perform the way it was designed. As stated above, it was originally developed for use in higher boost applications. Last edited by Squidz; 10-04-2012 at 10:12 AM. |
10-04-2012, 09:13 AM | #15 |
Member#: 290413
TXIC
Impressive! Nice job man. Wouldn't mind checkin it out sometime.
10-04-2012, 09:20 AM | #16 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
Nice too see some results. Thing seems to be a beast. Also has nice spool.
