Welcome to the North American Subaru Impreza Owners Club Thursday October 20, 2016
Old 08-27-2012, 05:24 PM   #1
Member#: 153235
2005 Saab 9-2x Aero
This afternoon, I got into my car after work, started it and heard a squealing noise after turning the steering to the left, the steering also began to judder a little as if there were intermittent losses of power. After a few wiggles back and forth it was fine but during the drive home, there is still an occasional faint hint of vagueness in the wheel that I never felt before. Does anyone have any idea what this could be? I should add that I hit a pretty big pothole 2 nights ago while driving home and checked everything since and it all seemed fine at the time.
acqui is offline   Reply With Quote
Old 08-31-2012, 04:05 AM   #2
Member#: 306536
same problem here, check power steering fluid?
senility is offline   Reply With Quote
Old 08-31-2012, 03:29 PM   #3
Member#: 95901
Reads like air is getting into the fluid. Pop open the PS reservoir and see if there's foam in there.
You may need this: DIY: Power Steering Pump Rebuild thread.
Old 10-02-2012, 11:14 PM   #4
Member#: 294833
2011 Impreza WRX
Dark Gray Metallic
I'm having this same problem and wanted to bump the thread in case anyone figured it out. I have a 2011 WRX (18,000 miles) and I've been dealing with it for about a month now. It doesn't happen consistently, so when I took it to the dealer to have it fixed under warranty, they couldn't recreate it.
Just to throw in a few more details: it'll happen regardless of whether the engine is cold or hot. It only happens on startup and will go away after a while. Like the OP, it only happens when I turn the wheel to the left. The sound is a high-pitched metal-on-metal grinding sound---almost like the front brake pad wear indicators are grinding on the rotors.
Thanks for the help...it's driving me nuts.
rshalvoy is offline   Reply With Quote
