Old 10-03-2012, 01:00 AM   #1
subbyboer
Member#: 316561
Default Turbo loss HELP
I just took my car in for a compression test they said everything tested find but when I left I felt that there was hardly any power. Check the boost gage on my Cobb and I couldn't get more then 7.5 psi. I checked all the hoses and they weren't unhooked or anything. Before they checke it it was running great. Please help its an 03 wrx 1.0 with a newly built motor
subbyboer is offline   Reply With Quote
Old 10-03-2012, 01:01 AM   #2
subbyboer
Member#: 316561
2.0l the motor has about 900 on it. But was running great
Old 10-03-2012, 09:03 AM   #3
Dr. octagon
Member#: 171127
2015 Subaru
take it back to whoever touched it last and have them show you what they touched. Really, a compression test is something you can/should be able to do on your own
Dr. octagon is offline   Reply With Quote
Old 10-03-2012, 09:19 PM   #4
subbyboer
Member#: 316561
I do know how to do it. It's just wanted to have another set of eyes on it. And have them go over everything to make sure it's good
Old 10-03-2012, 09:24 PM   #5
rocketperson7
Member#: 283968
MBP
sounds like a boost control issue, 7.5 ish is around wastegate pressure (or at least it is on my vf-39)
Old 10-04-2012, 12:24 AM   #6
subbyboer
Member#: 316561
Was looking at the Cobb bcs looks like that might be my fix. Any objections ?
Old 10-07-2012, 03:26 PM   #7
silversled
Member#: 261114
2003 wrx wagon
Your pipe from the turbo to the intercooler probably is cracked near your hose clamp. After I went with an access port my car suddenly wouldn't hold boost. Turned out the plastic eom piece was cracked under the hose clamp.
silversled is offline   Reply With Quote
Old 10-07-2012, 04:40 PM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
check the plugs, possibly they were lazy and didn't torque and replace them properly and now are backing out
Old 10-07-2012, 07:13 PM   #9
itr.#1446
Member#: 162447
03 Wrx
Sonic yellow
You should just go back to the place that touched your car like everyone stated and say hey my car didnt have this problem before you touched it why waste money for something they may have done.
itr.#1446 is offline   Reply With Quote
Old 10-08-2012, 02:30 AM   #10
assasain
Member#: 323978
2004 WRX STi
Aspen white
skip to 1:00, This is what you convey to the people that touched it.
assasain is offline   Reply With Quote
Old 10-08-2012, 11:18 AM   #11
Member#: 301037
2004 Forester XT
Sounds like it could be a intercooler issue. Like stated above I would take it back to where you had the test done and have them look at it again. If you have lost trust in them check the following,
Y-pipe on the bottom of your IC
check the Y-pipe to turbo connection
check the IC to TB connection
make sure the intake is in correctly and all connections are tight
check all the spark plugs for correct TQ
art@grimmspeed is offline   Reply With Quote
Old 10-08-2012, 12:19 PM   #12
DZXN
Member#: 306186
2002 Subaru WRX
^^^ is good advice. Take it back to the shop. If not, check what chris said. Also check to make sure the hoses running from your BCS are in place (not disconnected). I'm not sure what bcs you have, here is the OEM http://www.google.com/imgres?q=subar...r:17,s:0,i:123 do a google search for what you have.
DZXN is offline   Reply With Quote
