Old 10-01-2012, 01:01 AM   #1
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Default Quarter Mile: Stock block EJ205 2.0L + 18G goes 11.66 sec @ 118.65mph
9-28-12 Back to the track same setup as before. Just pushed a little deeper on the record
Only got 3 passes on the third we blew a huge hole in the Perrin El
Event: Quarter mile
Ambient Temp: 48 degrees
Elevation: 1111
Weather: Mostly Clear with a few clouds, had rained previously for days
Track and Conditions: concrete first 220' asphalt remainder, runs up hill at shutdown(for 1/4 mile only)
Tires Toyo Proxes 205/45 16
Car: 2002 Wrx Sedan
Tuner: Matt Cater 555 motorsports
Dyno Info: road tuned
Transmission: 5spd/ppg gearset (1-2 straightcut,3-4 Helical stock 5th)
Gear: 1 thru 4
Peak HP at RPM: airboys around 340/305 give or take
Peak Torque at RPM: 4950
Baseline hp/tq for a stock on same dyno: airboy go do the math
Target Boost: 22
Target AFR: Secret (ha!)
Fuel: VP C16
Engine/Power Modifications:
Cobb intake
Gimmick Inlet and after MAF
TD05h-18G 7cm2 PnP/Jet Hot Coated and blanketed
CSS FMIC wrapped cold side to TB
Grimmspeed Coated TGV Deletes
PnP Intake and PnP/Coated TB
8mm Grimmspeed Phenolic Spacers
Walbro
DW 750 Inj.
Perrin El’s (wrapped)
Perrin LW Pulley
Grimmspeed Uppipe (wrapped) with Tial 38mm EWG
Perrin Style EBCS
Invidia Bellmouth DP wrapped
Buschur Racing 3in CBE
Driveline Modifications: Stock ratios, ACT heavy duty street disc clutch , ACT Streetlite flywheel, Kartboy short throw
Suspension Modifications: Group N tranny, motor and pitch stop, Alum front control arms
Other Modifications: weight removal (2900lbs)
Time slip attached. 2 video angles plus an in car cam
Quickest stock block EJ205 in a GD chassis
Thanks to all those involved , Especially Scrap for always keeping me on track! (And helping put the car together,pit crew chief and videos)
Thanks to my wife and son for thier trackside support. And daughter too!
Slip!
Thanks for looking
jmlaser is offline   Reply With Quote
Old 10-01-2012, 01:20 AM   #2
LBell05STI
Member#: 305890
2005 STI
Weight of the car?
LBell05STI is offline   Reply With Quote
Old 10-01-2012, 02:14 AM   #3
GeneralTJI
Member#: 152680
You did it man!! Way to go!!!
GeneralTJI is offline   Reply With Quote
Old 10-01-2012, 10:33 AM   #4
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
Great job Joel, glad to see the car keep getting faster!
mxturboracer86 is offline   Reply With Quote
Old 10-01-2012, 10:54 AM   #5
jmlaser
Member#: 125529
02 WRX 18G EJ205
Originally Posted by LBell05STI View Post
Weight of the car?
I knew I forgot something,... 2900
Old 10-01-2012, 03:37 PM   #6
Mooneyes13
Member#: 113666
60' all over you
good work
Mooneyes13 is offline   Reply With Quote
Old 10-01-2012, 05:52 PM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
very impressive
Old 10-02-2012, 11:03 AM   #8
2000subie
Member#: 207638
2004 WRX
Yellow
Ordering dss 800hp hybrid axles today. I'm coming for your record! Lol
2000subie is offline   Reply With Quote
Old 10-02-2012, 11:11 AM   #9
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
nice run!
k04sti is offline   Reply With Quote
Old 10-02-2012, 02:13 PM   #10
Android287
Member#: 180861
2005 cammed Hybrid
2.5xtr E85
Nice Time!!! How many mile on the stock block?
Android287 is offline   Reply With Quote
Old 10-02-2012, 02:53 PM   #11
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
This reminds me... does anyone make a SS321 typical EL design header yet?
The design seems to perform consistently well, but everything out there is either the 3-bolt chinese or the Perrin, and they're all SS304 and go cracky cracky due to precipitation hardening when you really push them
Old 10-02-2012, 11:23 PM   #12
scrapinstien
Member#: 225776
98 LGT
and jmlaser's 02 wrx
113.xxx on jm's car and the block has never been opened.
scrapinstien is offline   Reply With Quote
Old 10-03-2012, 07:32 AM   #13
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Great job! Making some great power on the 18G!
Old 10-03-2012, 09:25 AM   #14
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Something tells me that the header wouldn't have cracked if it were coated instead of wrapped? Nice job on the passes.
Subian is offline   Reply With Quote
Old 10-03-2012, 09:55 AM   #15
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Thats sweet dude..gotta love a well set up 2.0
Any idea of peak MAF V on your COBB intake?
Old 10-08-2012, 10:55 PM   #16
jmlaser
Member#: 125529
02 WRX 18G EJ205
O Really,... What makes you say that ? Thanks
Ty,. Yes when they are set up right they can get the job done.
Maf V is very close to max IIRC. I would go pull a log, but I kinda got an open exhaust VW thing going on.
Old 10-09-2012, 02:15 PM   #17
karlknaupp
Member#: 60871
2004 WRB WRX
Dam man. great run. listen to those ppgs whine. keep it up!
karlknaupp is offline   Reply With Quote
Old 10-09-2012, 03:38 PM   #18
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
http://forums.nasioc.com/forums/show....php?t=2147028
Post#17
Not sure how many track passes you've done with the header, but they might have been exposed to extreme heat being wrapped. Are you the original owner of the header? Maybe something to look into with Perrin regarding a replacement.
Old 10-09-2012, 04:08 PM   #19
djc1827
Member#: 238618
498whp fp black
Nice driving man....Better 60ft time and you will be running 11.40s. Great trap speed too
djc1827 is offline   Reply With Quote
Old 10-10-2012, 09:07 AM   #20
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
PERRIN headers - nom nom nom great performance, but yeah wrapping mine did this... mid track run LOL
Mine were 6 months old, PERRIN would no way replace when wrapped, only if coated.... Ill never buy again
OP - if you can get a MAF v at any time PM me, its of particular interest to me as we have similar vehicles, I feel mine is in the '11,s' with a good pilot
Old 10-16-2012, 05:09 PM   #21
jmlaser
Member#: 125529
02 WRX 18G EJ205
Heres what happened to mine. Yeah There is no chance of warranty. Bought them used and abused, then I wrapped them and ran them. Wasnt putting the money into ceramic coating, got my wrap for free from a friend.
I think Either way your screwed... As Concillian said the precipation hardening occurs then its crack city.
I may pull them off and redo them with SS321 this winter if I get bored and havent come up with another solution by then
Old 10-16-2012, 09:52 PM   #22
karlknaupp
Member#: 60871
2004 WRB WRX
Dam that's a hole
Old 10-17-2012, 08:20 AM   #23
MMR
Member#: 273595
2012 WRX STI
thats pretty darn good! any plan to bring the times down further?
MMR is offline   Reply With Quote
Old 10-17-2012, 10:55 AM   #24
st205wrx
Member#: 193253
08 wrx 322/352
wrb
Nice trap time
st205wrx is offline   Reply With Quote
Old 10-17-2012, 07:52 PM   #25
jmlaser
Member#: 125529
02 WRX 18G EJ205
Originally Posted by karlknaupp View Post
Dam that's a hole
Yes, Yes it is. Bigger than a Quarter
Thank you,...Sure, After the exhaust issue is sorted out... Next season looks good!
Anyone have any drag radials I can borrow or obtain on the cheap?
Originally Posted by st205wrx View Post
Nice trap time
