Old 10-02-2012, 11:57 AM   #1
jaronfitz
Member#: 279160
2007 WRX STI
black
Default quick CEL question
I posted here about a week ago asking for help on a problem i was having when throwing a p0171 code and thanks to all your help my car is running amazingly.
When I unplugged my MAF my car instantly ran great, so I got some cleaner and cleaned it up and plugged it back in. It runs even better to my surprise. After plugging it in and starting it up I immediately checked my accessport and I now have p0102(MAF sensor) p0113(intake air temp circuit high input) and still my p0171 running lean code. i dont get it my car is running perfectly. Only mods on the car are a turbo back and a stage 2 tune.
any input?
jaronfitz is offline   Reply With Quote
Old 10-02-2012, 07:05 PM   #2
04ScoobyWtf
Member#: 287974
Both the maf and iat are 1 sensor. Get an oem maf sensor and that should fix it. Or if you can switch mafs with someone and see if it fixes it because mafs are $$$
04ScoobyWtf is online now   Reply With Quote
Old 10-02-2012, 08:33 PM   #3
kwikside
Member#: 107888
2003 Impreza WRX
^^Agreed, try switching MAFs first. As, a new MAF is around $300 at some places. You can find used ones for around $75 TO $90 in the classifieds on here.
kwikside is offline   Reply With Quote
Old 10-03-2012, 10:48 AM   #4
04ScoobyWtf
Member#: 287974
Don't buy an autozone or oreilys one if you do end up needing one. Get oem
Old 10-03-2012, 10:52 AM   #5
jaronfitz
Member#: 279160
2007 WRX STI
black
Thanks guys my light ended up going off by itself and the car is inning great. Crazy computers
Old 10-03-2012, 10:59 AM   #6
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
if the cel was on....there was an issue and it will come back
Old 10-03-2012, 12:08 PM   #7
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
Agreed. I bought on from Napa and the scaling is no where close to factory. In the cooler weather, I would max it out during a wot pull and I'd throw the high input code. Switched back to a factory one and so far no codes when cold out.
Jackie leggs is offline   Reply With Quote
Old 10-09-2012, 08:41 PM   #8
kgrander
Member#: 323584
2004 wrx
rally blue
what did you clean it with? that could have made it run bad till it "cleaned itself" or dried it off.
kgrander is offline   Reply With Quote
