Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-03-2012, 11:48 AM   #1
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Default STI ancilliary hose kit on a Baja?
I have a abused and neglected 2005 Baja turbo in the shop that I am putting a bunch of work into (2 spun bearings, broken turbo, etc). I need all the ancilliary hoses since all the OE ones are broken, brittle and or cracked (Texas Heat turns rubber into plastic). Instead of going to the stealership to get bent over, I was thinking of ordering the ancilliary hose kit from IIR. Due to the intercooler differences, I am not sure if the fitment will be an issue. I know there may be other slight differences too.
I contacted IIR and they said they were not sure if they would fit or not. I figured that if anyone knew, it would be you guys .
Here is the link to the hose kit- http://www.importimageracing.com/mis...04-07-sti.html
bugeyetex is offline   Reply With Quote
Old 10-03-2012, 07:36 PM   #2
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Anybody? Its a simple question
Old 10-05-2012, 11:21 PM   #3
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Its my last bump before I go and beat on the counter with my forehead at the local stealership. Please don't make me do it...
Old 10-06-2012, 03:00 PM   #4
oguitar
Member#: 206720
2002 WRX Wagon
Buy the kit and test it out. If you don't use the kit because they don't fit just return it.
oguitar is offline   Reply With Quote
Old 10-06-2012, 08:20 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
ask oakos. they would probaly know more than iir. Should be the same, maybe one or two hoses you wont be able to use. Most are all coolant lines with that kit.
scby rex is offline   Reply With Quote
Old 10-06-2012, 10:10 PM   #6
hardhitter_alert
Member#: 293841
2007 STi
Import Image Racing is the **** so I would say go for it.
hardhitter_alert is offline   Reply With Quote
Old 04-14-2013, 09:53 PM   #7
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Just in case anyone ever looks this up, I thought I would let everybody know that it does not fit. There is a couple of hoses that sort of work, But for the most part it is useless.
