Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 10-03-2012, 10:20 AM   #1
E_Jay_Twenty
Member Sales Rating: (16)
Member#: 124875
2002 WRX-MBP
1992 240sx coupe sr20
Default Work vs-xx
specs:
18x10 et21 square
They were purchased for a Subaru fitment, not VW so they will work on your WRX wagon/sedan/04 sti
they are 5x100 from work, they have work lips, and they have not been split.
need to sell fast, 3k with tires
im located in north new jersey
E_Jay_Twenty is offline   Reply With Quote
Old 10-03-2012, 11:41 AM   #2
Donzo
Member Sales Rating: (62)
Member#: 95337
2012 Jeep Overland
If they're VW specific, that means a Subaru owner would need lug nut adapters since VW's have a rounded lug seat and Subaru's have a conical lug seat.
I almost found out the hard way here:
http://forums.nasioc.com/forums/show....php?t=2334886
Donzo is offline   Reply With Quote
Old 10-03-2012, 12:10 PM   #3
johnsea
Member Sales Rating: (8)
Member#: 269720
Goddamn that front fitment is tits
johnsea is offline   Reply With Quote
Old 10-03-2012, 03:08 PM   #4
E_Jay_Twenty
Member#: 124875
2002 WRX-MBP
Thanks for the info! I'm actually selling these for a friend. So any fitmet questions Subaru related, I would not be able to answer.
Old 10-03-2012, 08:12 PM   #5
amonsta727
Member Sales Rating: (23)
Member#: 202312
They used to be mine so they def will fit subarus.
amonsta727 is offline   Reply With Quote
Old 10-03-2012, 09:39 PM   #6
SpooledSouth
Member Sales Rating: (2)
Member#: 283985
How much work would need to be done to fit a wagon lol
SpooledSouth is offline   Reply With Quote
Old 10-03-2012, 11:12 PM   #7
CVR STi
Member Sales Rating: (28)
Member#: 127428
wont fit 5x114.3 ?
CVR STi is offline   Reply With Quote
Old 10-04-2012, 12:14 PM   #8
E_Jay_Twenty
Member#: 124875
2002 WRX-MBP
Originally Posted by CVR STi View Post
wont fit 5x114.3 ?
They are 5x100 I don't know if you could make them work, you'd have to do your own research.
Just talked to my friend I'm selling these for. He told me they were bought for a Subaru fitment. They were on a WRX wagon before he got them.
Old 10-04-2012, 12:20 PM   #9
Donzo
Member#: 95337
2012 Jeep Overland
Fitting on a Subaru just means they have the same lug pattern. Were they made for Subaru fitment, or VW? Like I said in my prior post, it's not just the lug pattern that matters, but the actual contour or the lug holes.
Old 10-04-2012, 12:33 PM   #10
cowboy_Rob
Member Sales Rating: (5)
Member#: 194062
2003 Impreza WRX
I'm sure they use standard tuner lugs like most aftermarket wheels. most of the ftermarket wheels on vw's aren't ball seat anymore. They usually swap to standard taper seats. Only problem might be whether they're 14 or 12 mm holes.
However they will be anything but easy to fit on a Subaru especially a wagon. Stretched tires, lots of camber and heavily pulled fenders will be the only way you get them close to fitting.
cowboy_Rob is offline   Reply With Quote
Old 10-04-2012, 04:21 PM   #11
SLIC VIC
Member Sales Rating: (1)
Member#: 187428
2006 WRX Limited
perfection. GLWS.
SLIC VIC is offline   Reply With Quote
Old 10-04-2012, 05:51 PM   #12
E_Jay_Twenty
Member#: 124875
2002 WRX-MBP
Waiting on more information from my friend....
Old 10-04-2012, 06:35 PM   #13
jeremyz
Member#: 306287
they are cone seat like most works are, i used studs and tuner lugs when i ran them
not much, they were on one before i got them
wont fit 5x114.3 ?
no, they are 5x100 not 5x114.3
they will fit without crazy stretch and without crazy camber. if you run a 225 on them they will fit easily. they don't need heavy pulled fenders or crazy camber, but you have to know that they won't fit with standard size tires, you would be running 10" wide all around and if your buying them you should know what fitment entails . they had 12mm holes and i had them drilled to 14mm but that doesn't make a difference, your lugs (cone seat) will center the wheel. work makes 3 different disks and all of them will work on any car, the only difference is brake clearance. I don't come on here much but i am a very active user on vwvortex, i also have sold and owned over 30 sets of 3 piece wheels in the past year or so, if you have any questions feel free to pm me. and these are my wheels, i just asked a friend to post them initially because i don't come on here
Originally Posted by SLIC VIC View Post
perfection. GLWS.
thanks guys
jeremyz is offline   Reply With Quote
Old 10-04-2012, 07:02 PM   #14
celosteelo
Member Sales Rating: (4)
Member#: 80062
06 STi
Bump for a sick set of wheels...
celosteelo is offline   Reply With Quote
Old 10-12-2012, 12:57 AM   #15
E_Jay_Twenty
Member#: 124875
2002 WRX-MBP
Bump! He needs these sold so he can pay off the $4,000 set of wheels he just bought lol
Old 10-13-2012, 06:15 PM   #16
Felix C
Member Sales Rating: (21)
Member#: 260866
2004 Impreza STi
What is the weight of each wheel with out tire? Cast or forged?
Felix C is offline   Reply With Quote
