Old 10-03-2012, 02:12 PM   #1
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Default Where is my coolant going?
I noticed my coolant overflow tank below the MIN line, mixed up some Subaru coolant (50/50) and raised the level to the MAX line in the overflow tank yesterday. Checked again today and it's the same level as yesterday. at the MIN line. Popped open the coolant tank above the turbo and the coolant level is at the top.
Why is coolant disappearing from my overflow tank?
eurospek is offline   Reply With Quote
Old 10-03-2012, 02:17 PM   #2
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
Well it's either leaking out or being burned.
tebriel is offline   Reply With Quote
Old 10-03-2012, 02:20 PM   #3
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Looking at my radiator, and the piping going to and from it it looks clean, checked under the turbo heatshield and also looks ok. Where else can I check for leaks?
If it's being burned, it's a sign of what? What's burning it?
Old 10-03-2012, 02:29 PM   #4
03sportwagon
Member#: 252943
2003 wrx sport wagon
Look at exhaust and see,smell. If you got fluid in exhaust u may need new head gasket
03sportwagon is offline   Reply With Quote
Old 10-03-2012, 02:34 PM   #5
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Exhaust seems fine, smells fine too.
Just called my mechanic (6 Star Motorsports) and was told the level of coolant will fluctuate in the reservoir tank. Either way, I'll know on Monday for sure about leaks, have scheduled an appointment for then.
I'll keep you guys posted.
Old 10-03-2012, 05:14 PM   #6
h00z0r
Member#: 212540
Check your lower hose's water neck, it cruds up and weeps onto the exhaust manifold and burns away, mine did it and never left a drop on the ground and I could never smell it in the car
h00z0r is offline   Reply With Quote
Old 10-03-2012, 07:00 PM   #7
NFJ79
Member#: 90750
2000 RS EJ207 Hybrid
2006 BMW K1200S
Check under intake manifold for leaks. I had a pool of coolant from a leaking hose clamp on top of the block.
NFJ79 is offline   Reply With Quote
Old 10-06-2012, 02:07 AM   #8
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Okay, something's definitely leaking. I can smell the burnt coolant.
Looked around with a flashlight and found a nice coolant puddle under the PCV valve (which was replaced about 20K miles ago with OEM).
Yup, the coolant pool is definitely on top of the block. I'll confirm tomorrow with daylight once I snoop around some more. How serious of an issue is this to drive around with?
Old 10-06-2012, 04:42 PM   #9
quazimoto
Member#: 70395
I'ts not a huge issue.
Old 10-06-2012, 04:53 PM   #10
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Safe to say I can take a 100 mile trip tomorrow biking before my visit to the shop on Monday?
Old 10-08-2012, 05:29 PM   #11
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Got it fixed today and back on the road.
Turns out one of the coolant lines on the throttle body had a weak clamp, along with a cracked line.
