Old 10-03-2012, 01:19 PM   #1
Willywonka
Member#: 252920
Default Humvee turbo in a subbie
I've been looking around havent see anyone try this. Not a actual Humvee turbo bc they suck but a gm6 turbo. If you have seen one on the exhaust snail it has two inlets one on each side that are v bands . I'm thinking to mount where a top mount would be and have a exhaust Mani come up form both sides and run reverse intake Mani . What do you guys think oh the turbo is about the same size of a gt30 turbo
Willywonka is offline   Reply With Quote
Old 10-03-2012, 01:51 PM   #2
Elmerfudgeboost7
Member#: 333979
2012 Wrx
Remember your planning on putting a turbocharger meant for only diesel really lower rpm with a narrow rpm range.Its not meant to produce large numbers of boost i mean you could get technical in what have to start replacing but its not practical i see it as.
Elmerfudgeboost7 is online now   Reply With Quote
Old 10-03-2012, 02:22 PM   #3
Willywonka
Member#: 252920
Good point just thought it would be cool I know they use the cummins turbos thought it would be close to the same.
I'm a mechanic in the Military and they run 26psi and when you drive say on the interstate you have to floor it the hole time just to stay at speed soo there's where I was coming form thinking it would a ok turbo to run
Old 10-03-2012, 02:48 PM   #4
eg33GC
Member#: 206851
99 V4
EJ20K RS
a turbo has no idea what engine it is in, and any diesel turbo works great on a gas engine
example being a Volvo semi hx55 on a 2.0 4g63
Old 10-03-2012, 02:52 PM   #5
Elmerfudgeboost7
Member#: 333979
2012 Wrx
Oh really what branch? Im a vehicle mechanic for the USAF.
Old 10-03-2012, 02:53 PM   #6
Elmerfudgeboost7
Member#: 333979
2012 Wrx
There is different turbos for different displacement and applications. So agreed with your statement somewhat.
Old 10-03-2012, 04:03 PM   #7
Willywonka
Member#: 252920
US Army mechanic for the 10th special forces and I work ALOT they like to break **** lol mostly the atv and side by sides
Old 10-03-2012, 11:45 PM   #8
rocketperson7
Member#: 283968
MBP
Turbos are meant for specific Pressure Ratios and Flow Rates, not gas or diesel
unless you're talking about VNT, then they're really only supposed to be used on diesels because of the temperature difference, but even they can work well on gas engines if it's set up correctly
Old 10-04-2012, 12:46 AM   #9
SpinningAllFours
Member#: 332829
Don't get me wrong but I'm pretty sure the 09 up WRXs need some low end power since the turbo takes so long to spool up and most of the power comes at the high RPM range.
SpinningAllFours is offline   Reply With Quote
Old 10-04-2012, 10:25 PM   #10
tebriel
Member#: 244190
2004 BRP WRX Wagon
2004 JBP WRX
I haven't seen too many people use garrett turbos on here. I would think a t3/t40e would work fantastic with these engines. No lag and flows a lot.
tebriel is offline   Reply With Quote
Old 10-04-2012, 11:50 PM   #11
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Try this site instead, you'll find a few:
http://forums.nasioc.com/forums/forumdisplay.php?f=79
Look for numbers like 2871, 2876, 3071, 3076, 3582, 4088, 4202.
EDIT: Also, GT30, GT35, GT40
Old 10-05-2012, 11:15 PM   #12
tebriel
Member#: 244190
2004 BRP WRX Wagon
2004 JBP WRX
I'm old school, i'm not that familiar with the BB turbos, or the even newer ones.
Old 10-06-2012, 12:39 AM   #13
NSFW
Member#: 140444
05 Stage Free LGT
I had a hunch. Garrett's GT3076 and GT3582 BB turbos are really common, and it looks like the GTX3071 and GTX3576 are going to be the new standards until/unless Borg-Warner figures out how to ship their EFR turbos at a decent rate.
Old 10-13-2012, 12:11 AM   #14
98gc8
Member#: 169171
1998 98 zombie
I have a gm4 turbo on a stock 2.0. It is currently tuned at 18 psi putting out 300hp on the dyno. Spools around the 4800 rpm range. With a built 2.5 and some aggressive tuning it should be about the same as a 30r.
It is also a rotated intake with a perrin fmic.
Heres an old pic. has a different intake now.
98gc8 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 10:41 PM.
