#1 |
Member#: 224197
Vehicle:2013 WRX Hatch DGM |
I love my 2013 WRX hatch. There are a few things I'd like to improve, and I'd like to try to keep a budget of about $2,000 over the next two years. I think the non-technical pieces will cost me around $800 or under (head unit, rear-view mirror, head & taillights).
Which leaves me about $1200 to address the powertrain. I don't have a specific WHP goal--my butt dynometer can't tell me whether a car I'm in is 250 WHP or 260 WHP, but I know I'd like to decrease the turbo lag and increase low/mid range response / power. My initial thought was to replace the turbo inlet and get a torqued performance e-tune (open source) and roll with that for a while. Maybe 10k miles later I'd replace the down pipe and a catless or high-flow and get a pro-tune. I would just gut the down pipe but I lack the equipment. I would consult a tuner before picking the pipe. So the way I usually see these threads go my main questions is: 1) Do I seem to have my head on straight? I don't think I'm way off base. And if I'm not way off base: 2) Is there anything else I could do to get me a better bang for the buck given my (somewhat vague) intent? 3) (Crystal ball question) How likely am I to just want more after this? ![]() It's of secondary concern, but still very important to me, to not impact the reliability of the car. Thanks
#2 |
Member#: 297565
Vehicle:2011 WRX hatch Silver |
Your goals seems pretty legitimate. You have the right idea with getting a tune. It should be one of the first things you do. Adding the Downpipe will void your warranty, so Thats up to u. I've been stage 2 on my 2011 for about 14k miles now with no issues. Take care of your car and it will take care of you.
#3 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
1) Seems fine
2) Skip the turbo inlet 3) Very likely Does your $2k budget include regular maintenance, or just mods? Depending on how much and how hard you drive, 2 years could mean 6 oil changes, a new set of tires, and a new set of brakes...and there goes the majority of your $2k budget. |
#4 |
Member#: 270482
Vehicle:2011 forester xt corn fed td06 20g 8cm |
Skip the inlet get a downpipe and a etune for the best bang for your buck.
#5 |
Member#: 9264
Vehicle:2012 WRX 5dr Ice Silver |
$80 Turbo blanket. Reduce heat soak, improve throttle response, reduce turbo lag
$120 for a more aggressive alignment. Crank in the camber, especially up front. $80 for Stoptech pads. Better bite. $90 STI 19mm sway bar. |
#6 | ||||
Member#: 224197
Thanks for the brake pad advice. I've never installed my own but I would like to this time. My last car I traded in @ 45k miles and the pads were still solid, but maybe these ones won't last as long... ![]() Man I forgot about the sway bar. That's a must have for me actually. The body roll seems to be better than on my old Impreza. Thanks guys |
#7 |
n00b Moderator
Moderator Member#: 140114
Vehicle:06 18G Semi Built SGM WRX |
Skip the "custom super stupid aggressive alignment" advice. You have no need for aggressive alignment on the street or occasional turn. And will contribute to faster tire wear.
Maybe once your brake pads are worn out, then upgrade. Otherwise you will not really want to justify the cost. Skip the inlet till down the road. You don't really gain much from them more then a sense of safety from a rotted inlet. |
#8 | |
Member#: 9264
If you want better initial bite and brake feel, get the Stoptech Street pads. More dusting, but well worth the improvments. |
#9 |
n00b Moderator
If you want the car to feel better in turns, other mods will go a lot further then an alignment. Aggressive camber is not a benefit on the street.
#10 |
Member#: 287974
Just get a downpipe and a tune. Your up pipe is already Catless.
#11 | |
Member#: 327511
Vehicle:13 WRB GR EL-EWG-E85 |
#12 |
Member#: 9264
#13 |
Member#: 263329
Vehicle:2011 Impreza WRX DGM |
For #3: I told myself I wouldn't touch the car. Then I joined the forum. A month later, stage 1. I told myself I'd stop there. Eight months later, stage 2 and an intercooler. I told myself I peaked as far as modding the car. That was 4 months ago; now I'm going E85 and building the engine. It never ends.
#14 | |
Member#: 8356
South East
Vehicle:02 STi swap 12 WRX limited |
#15 |
Member#: 312015
short shifter and bushings, makes ur shifting a lot more crisp, but it's a personal thing with that
#16 |
Member#: 224197
A kartboy shifter was going to be my first upgrade originally, but the 2013 WRX that became available already has the OEM short shifter so I'm good there! I'm very happy with the short shifter, it's a nice improvement over the original that I had been driving on my '09 Impreza for 3 years.
#17 |
Member#: 280572
E. Canada
Vehicle:2011 sti sedan plasma blue pearl |
Here some really good advice forget power mods!!!!
Talk to "TURN IN CONCEPTS" get a full bushing kit or "WHITELINE" which ever u would prefer cuz either way your suby will then feel confident, meaning building driver confidence!!! U will be amazed how different your suby will feel and handle. Would also consider coilovers like kW v3's..ect if your budget would allow as this would already kill the budget u have now but don't cheap out in this category Save the power mods for down the road u don't want to risk voiding warranty claims unless u have deep pockets and obviously u don't with a 2k budget over 2yrs. Just enjoy your new ride and anything u do decide to go with use the search button its your friend hope this helps as u will thank me later ![]() |
