Old 10-03-2012, 10:05 AM   #101
kaos200
Member#: 2692
Originally Posted by pux888
The end tanks are cast man, not the core itself... Its a nice piece.
It's not what was advertised or paid for, nor what we want. It's really that simple
kaos200 is offline   Reply With Quote
Old 10-03-2012, 11:08 AM   #102
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned
Originally Posted by V8 GTFO Lesbic WGN
Has the hard line gap vs end tank been addressed?
Also what CFM?
And how much does it weigh STi 2004-7 specific?
My fitment was perfect with the hard line. I know the cfm flow is high, I thought it was around 2000 cfm but not positive about that. It's more about the efficiency of the core than the cfm's. Your turbo will never outflow the IC, I believe a 35r flows around 900 cfm.
Old 10-03-2012, 11:11 AM   #103
V8 GTFO Lesbic WGN
Member#: 191212
'07 Forester XT-5MT
ToBe: E85 TD06SL2 8cm 20G
^yeah I heard the 2000 cfm figure, that seems crazy considering a high flowing Spearco flows 1000 cfm ! Does your TMIC have cast or fabbed end tanks?, studs? Do you have any pics mounted on the FXT?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 10-03-2012, 11:30 AM   #104
Extreme Turbo Systems
Member#: 194655
08 STI
Hey Guys,
Sorry, we didn't update the website. We have been shipping out cast end tanks for the last 4-5 months. This was an oversight on our side. I sent an email to our web guy to have him update the pictures and description on our website.
The reason for going cast was not to cheap out, it's actually about the same. We use a US foundry the quality is as high as it gets when it comes to castings. It's not a cost issue either, the US tanks cost a lot more to make than the competitors who use overseas castings.
The cost balances out except we can make more in a day to keep up with demand. The hand fab tanks are cheaper, but take longer to build. The cast tanks are more expensive but quicker to build. I'm sorry we didn't make this clear on the website.
If anyone is not happy with the cast end tanks we will gladly take back the units. I'm sorry it was not advertised correctly.
I can guarantee your going to receive the exact same performance as our hand fab end tanks. We include the same high density core that we used prior. The only thing that changed is the physical tank material, the overall dims are the exact same size. We had an issue when we first released the tanks where the blow off valve holes were slightly off, but that has been addressed and everything fits perfect! No need to bend the a/c line like some of the other units. Fits directly to the factory shroud so air is pushed through the intercooler and not around. This is one of the highest quality top mounts on the market fit and finish.
Again, we are truly sorry and we are updating the website right now. If anyone has questions they can email me directly at Michael@extremeturbosystems.com or call me at 360-896-3000.
Michael
Extreme Turbo Systems is offline   Reply With Quote
Old 10-03-2012, 12:36 PM   #105
kaos200
Member#: 2692
Originally Posted by Extreme Turbo Systems View Post
Hey Guys,
Michael
Thanks Michael,
We not only wanted the performance of your intercooler, but also the looks as well. Since this build will be a CA street legal swap we figured the bay might as well look as nice and clean as it possibly can. I know it sounds silly to some, but there's no reason why function and form can't go hand in hand.
Thanks for understanding.
Now, for my GT, I was considering your FMIC kit. Is that still fabbed/plate or is it/will it also be cast?
You mentioned earlier that there will be a newer WRX style fitment TMIC in the works. Would that also be cast? (I ask since I could use that on my GT).
Old 10-03-2012, 01:09 PM   #106
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned
Cast tanks, studs. Fits better than stock STI IC.
Notice the lack of space between my strut bar and the IC. I have a full mechanical STI conversion on my Forester and I removed the FXT front cross member spacers from between the unit body and the cross member when I did the 07 STI drivleine swap. They are 1.125" thick. I did this to mimic the STI driveline alignment exactly and the motor sits higher in the EC now.
Old 10-03-2012, 01:14 PM   #107
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned
Michael,
I will most likely install a FMIC in my XTI in the near future but unfortunately yours is taller 11.25" to 9.25" than say the Perrin and does not include a bumper beam replacement. I don't think your FMIC will fit my XTI very well. I wish you made a core that was 9is" high for the Subarus.
Old 10-03-2012, 01:19 PM   #108
Member#: 194655
08 STI
^^ Anything is possible. If you need a custom intercooler, we can build one only 9.25" tall w/ the same mounting brackets i'm pretty sure. we would just treat it as a custom job.
Michael
Old 10-03-2012, 01:21 PM   #109
Member#: 194655
08 STI
Originally Posted by kaos200 View Post
Thanks Michael,
Those are hand fab still. We plan on moving to cast parts next year, but for now everything is hand fab in the FMIC department.
Michael
Old 10-03-2012, 01:39 PM   #110
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned
Here are a couple pulls from when I had my car tuned with the Killer B Holy Header w/ Tial MVR, VF48 and ETS TMIC on my stock EJ255. The blue is E85 and the red is 93 PG. Notice where my stock STI clutch let go, I think I would have made more power if not for the clutch. So the ETS TMIC works very well. We will soon see what it produces with the my new motor build and the Blouch 3.5XTR
Old 10-03-2012, 03:10 PM   #111
V8 GTFO Lesbic WGN
Member#: 191212
'07 Forester XT-5MT
^unless you have a chart comparing back to back TMICs this is not useful, as far as I am concerned you could have potentially made same power on a PW, Spearco, STi OEM TMIC, etc.
I would like to know from ETS the weight of the cast TMIC and how much it flows.
By back to back I mean this, click me.
Old 10-03-2012, 04:05 PM   #112
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned
I'm not going to compare anything for you, sorry. My graph just shows the power and torque that the ETS TMIC is capable of supporting with a VF turbo. If you don't find this useful, that's not my problem.
Old 10-03-2012, 04:13 PM   #113
Member#: 194655
08 STI
18.35lbs to be exact
Old 10-03-2012, 04:18 PM   #114
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned
Dude, just pick one and run with it. All three of these TMIC's are very good quality and they can all be made to fit. The ETS seems to be the best fitting. I can't believe the frickin questions you ask, really! It's kind of a wonder that you get anything done on your car.
Sorry but I just couldn't help it
Old 10-03-2012, 04:20 PM   #115
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned
Michael
Can you PM me with details and price? Bumper beam replacement or no BB?
Thanks!
Old 10-03-2012, 04:32 PM   #116
Member#: 194655
08 STI
The price wouldn't change since i'm still using a 12" tall core and cutting it down. I can't say if it will need a bumper beam replacement or not, we can make it however tall you want though as a custom intercooler.
Michael
Old 10-03-2012, 04:42 PM   #117
V8 GTFO Lesbic WGN
Member#: 191212
'07 Forester XT-5MT
A fricking question asking how much a $1,000 part weighs, flows, and whether is cast or fabbed? This is a thread to discuss TMICs, pros and cons my Forester friend.
Old 10-03-2012, 04:47 PM   #118
V8 GTFO Lesbic WGN
Member#: 191212
'07 Forester XT-5MT
Annd flows to be exact?
Old 10-03-2012, 05:06 PM   #119
Member#: 194655
08 STI
One of the guys said it above, but this intercooler is rated at 1950cfm. Thermally this intercooler are designed for 450whp-500whp.
The reason for the high flow rating (CFM) is due to the amount of charge rows and the amount of air that can physically flow through this intercooler. I wouldn't get caught up on CFM numbers on a vertical flow intercooler because the numbers never look right when converted into HP like a horizontal intercooler.
Thanks!
Michael
PS: To be exact
Old 10-04-2012, 07:05 PM   #120
GT-Power
Member#: 275080
Hello Michael
Did is any fitment issue with a Cusco Strut Bar? Will work well or it's necessary to put out the Cusco Strut Bar?
GT-Power is offline   Reply With Quote
Old 10-19-2012, 11:52 AM   #121
kaos200
Member#: 2692
FYI we managed to find a brand new "old style" ETS TMIC (score!). Such nice quality. Can't wait to have the whole build done so it can go on there.
Just curious of the following:
1) It seems that it is designed to only use 2 of the 3 mounting bolts for the breather line pipe.
2) Are there supposed to be studs for the y pipe portion, or just the bov?
Thanks Michael.
Old 10-19-2012, 12:07 PM   #122
Member#: 194655
08 STI
Thanks Michael.
Yes, We only use 2 of the 3 mounting holes on the 04-07 STI TMIC. If I remember right it was because the 3rd hole was in the way for fabrication purposes. There is supposed to be Studs on the Y-pipe portion as well as the BOV.
Old 10-19-2012, 12:09 PM   #123
Member#: 194655
08 STI
Originally Posted by GT-Power View Post
Hello Michael
We don't have any known issues with the Cusco strut bar. If you wanted to purchase it and it doesn't fit you can return it for full value.
Old 11-12-2012, 08:48 PM   #124
sackytar
Member#: 149262
2003 03WRXw6sp/05FXT
Love my PW cuz it works as a whole kit. Most companies dont sell you an efficient splitter too!
sackytar is online now   Reply With Quote
Old 11-22-2012, 08:53 AM   #125
carnz-pj-410
Member#: 110994
2004 WRX STi
something good on the way
Pulled the trigger on an ETS tmic last night, excited to see how it performs
carnz-pj-410 is offline   Reply With Quote
Process West vs stock tmic caperex09 Factory 2.5L Turbo Powertrain 46 06-11-2012 07:43 PM
FS : Process West TMIC - 700 obo APriestOfGix SCIC Private Classifieds 30 04-12-2012 11:17 PM
Perrin vs Process West TMIC Bean-Counter Factory 2.5L Turbo Powertrain 98 04-27-2011 11:22 AM
process west vs sti tmic alphaomega0 Factory 2.5L Turbo Powertrain 18 05-10-2009 11:10 AM
STI TMIC Vs Process West TMIC snowmanwrx Factory 2.5L Turbo Powertrain 3 02-01-2009 11:54 AM
Message Board Statistics All times are GMT -4. The time now is 09:50 AM.
