#1 |
Member Sales Rating: (11)
Member#: 239620
Vehicle:2003 WRX Wagon Aspen White |
Hey guys,
I have a 03 Aspen White Bugeye Wagon with 92k miles. $16,000 FIRM Not in a rush to sell. If you don't like my price, troll on. I'd rather part it out, then sell for a dollar less. I've owned the car for a little over 3 years. It's a hybrid motor, so 2.5L shortblock with 2.0L heads. Unfortunately the motor has a little bit of piston slap, nothing crazy or bad, still runs great and makes great power. Exterior has it's usual door dings, nothing to crazy. I'm in the process of repairing some panels. Vin: JF1GG29633G801844 NOT TAKING PARTS OFF THE CAR, DON'T ASK. Mods list: Performance: USDM STi EJ257 Block CP Pistons STi Rods USDM EJ205 Heads w/ BC 272 Cams Forced Performance 18G Turbo w/ Welded Wastegate PE 850cc Big Body Injectors Engine Wiring Harness Trimmed and Wire Tucked Unnecessary Engine Bay Brackets Deleted Halman Manual Boost Controller CRX Racing Aluminum Radiator ARC Radiator Caps Perrin Turbo Inlet Turbo XS Front Mount Intercooler Piping and Intercooler painted black Bosel Divorced Shorty Downpipe Grimmspeed 38mm External Wastegate V-Band Up-pipe Tial Blue V-Band 38mm External Wastegate Grimmspeed Thick Exhaust Gaskets Grimmspeed 8mm Phenolic Spacers Ported and Polished Modified Throttle Body Ported, Polished Intake Manifold Topfeed TGV Deletes SRS Catback Walbro 255lph Fuel Pump Gates Racing Timing Belt Tomei Timing Belt Guide Grimmspeed Lightweight Crank Pulley NGK Iridium Spark Plugs (Stock Temp) Cobb Short Shifter Kartboy Shifter Bushings ACT Stage 2 Clutch ACT Streetlite Flywheel Andrewtech Transmission Cocktail 5 Speed Rebuilt Twice (Fresh rebuild as of June 2012) Taylor Battery Trunk Relocation Kit Washer Tank Deleted Day Time Running Lights Deleted Semi-Shaved Engine Bay Holes ProSport Carbon Fiber Hood Struts OpenSource Tune by M.R. Performance Handling & Brakes: BC BR Coilovers Modified w/ Camber Plates Helix Adjustable Front Swaybar w/ Noltec Endlinks Whiteline Adjustable Rear Swaybar w/ Kartboy Endlinks Perrin Stout Mounts GT Spec Rear Strut Bar GT Spec Fender Braces Whiteline Subframe Lock Down Bolts ʼ04 STi Steering Rack w/ Whiteline Steering Rack Bushings Ingalls Camber Bolts Polished STi Control Arms Modified for Extra Caster Whiteline Anti-Lift Kit Whiteline Front Control Arm Bushings FHI 4/2 Pot Calipers Kartboy Rear Caliper Bracket Hawk HPS Pads DBA Drilled & Slotted Rotors Goodridge SS brakelines ATE High Temp Blue Brake Fluid Exterior: Sedan Front Fenders & Bumper JDM STi Grille JDM STi BlackChrome Projectors w/ Functioning Leveling Motors Authentic 3-piece Rear Lip 5 LED Blue Parking Lights Kaminari Carbon Fiber Hood Authentic EGR Sideskirts (Rare as all hell, not pictured) Project Mu Lug Nuts 20% window tint JDM Ganador Mirrors Windshield Wiper Delete/Rear Window Wiper Delete Rolled Front Fenders Rolled & Pulled Rear Fenders Wheels: 18x9.5 +35 Klutch SL14 Machined Finish w/ Center Caps 215/35/R18 Mayrun M800 Z-Rated 5mm Spacer All Around Interior: ʼ04 STi Interior Front and Rear Seats Door Cards ʼ04 STi Gauge Cluster ʼ06 STi Center Console Painted Black w/ STi Shifter Surround ʼ04 STi Steering Wheel Painted Black Black STi Floor Mats STi Key ARC Shift Knob ATI Triple Gauge Clock Pod Autometer Cluster Surround Dual Gauge Pod Defi Blue Racer Series: Water Temp Boost Oil Pressure AEM Wideband Air/Fuel Ratio Gauge A, B, C Pillars Painted Black Blitz Turbo Timer Sound: 6.5” Eclipse 3-way Speakers F&R 2 Soundstream Tarantula 5ʼs Audiopipe 1800 Amp Clarion VX400 Double Din Headunit I have a worlds load of extra parts for this car including a new darton sleeved motor and JDM 6-speed transmission swap and rotated GT35R kit. I may be willing to throw in everything I've been stocking on my shelves for my next build. WHAT I WOULD TRADE FOR: I'd like to trade for a nice FD, I'll entertain any color except black. 5-Speed only. I hate tan interior, so the less tan the better. I'd like something with some nice suspension mods, like bushings, swaybars, and most importantly, coilovers. I don't mind engine mods either, as long as it's not to extensive. Everything has to be in working condition, meaning heat, A/C, power steering, gauges, everything! Everything works on my car, so i'd like that in return. On to the pics: I'll obviously raise the car and make it more practical for the new owner. ![]() ![]() ![]() ![]() - Nick
#2 |
Member#: 255666
Vehicle:2005 WRX STI WRB |
sweet ride, but put the state in the title so this doesn't get locked. seen this around the greater glen cove area before, thing is sick.
#3 |
Member Sales Rating: (1)
Member#: 279935
E. Canada
Vehicle:1999 BMW 328iC 'vert Fern Green Metallic |
This!
http://forums.nasioc.com/forums/show....php?t=2020393 ... and while you're at it, this! http://forums.nasioc.com/forums/showthread.php?t=347246 GLWS. |
#5 |
Member Sales Rating: (3)
Member#: 74670
Vehicle:02 WRX Sedan Aspen White |
can i buy your mirrors i'll send u my stock ones..they stock 02 aspen white in perfect condition..i been looking for ganador mirrors painted white for while now
