#1 |
Member#: 193628
E. Canada
Vehicle:2010 STI SSM |
Event: Road Dyno Session
Location:Eastern Canada Ambient Temp: 20c Elevation: 100 Weather: Overcast Car: 2010 STI Tuner: Franko Dyno Info: Virtual Dyno Transmission: Stock 6 Speed Gear: 3rd Peak HP at RPM: 376 @ 6184 Peak Torque at RPM: 401 @ 4510 Baseline hp/tq for a stock on same dyno: no idea Target Boost: 25psi Target AFR: 11.5 (12.5 true gas afr) Fuel: 91 octane with 50/50 meth Engine/Power Modifications: CP drop in pistons arp head studs etc etc... 20g XTR 8cm GT spec UEL headers Invidia Q300 Catless tbe TGV deletes Aquamist hfs 3 ACT HDSS clutch ![]() Seems a bit low to me considering xluben is making 491 ft lbs on essentially the same setup but with e85. I figured I would be able to come close to that with 50/50 meth. Are my numbers about right for the setup or is something else going on here and holding me back? Tuning gurus chime in please.
#2 |
Member#: 210527
BAIC
Vehicle:05 STi WRB |
About what RPM does it hit peak boost?
#3 |
Member#: 193628
E. Canada
3700 rpm i guess.. Its in the graph there.
#4 |
Member#: 210527
BAIC
Sorry forgot this was a road dyno. Does it seem to spool much slower than stock?
#5 |
Member#: 193628
E. Canada
Not bad. A little slower then stock naturally but keeps the car fun which is what I wanted.
#6 |
Member#: 210527
BAIC
Thanks. Numbers aside it looks like a strong setup.
#7 |
Member#: 27091
NWIC
Vehicle:2010 STi SE DGM |
My 2010 STi is at 377hp 398tq.
Blouch 20g XT 8cm DW 1000cc AEM intake AP uel header/up pipe Invidea catted dp, Harmon Motive cbe ETS tmic open source tune Similar results, all things considered. |
#8 |
Member#: 44836
MAIC
Vehicle:1999 Fozzy silver |
looks like it is holding power up top really well. E85 will make more power than 91 + 50/50 though, so shouldnt be too surprised
#9 | |
Member#: 193628
E. Canada
#10 |
Member#: 155696
Tri-State
Vehicle:2007 BLK STI Dom3XTR 415/405 Precision Tuning |
Thats about right. With a Fp green 7cm 2.4" and Meth i made 380/412 @22 psi. E85 is More potent and makes power easier than Meth. From what i see most 93 vs E85 tunes are 60-100whp different. e85 would put u near 450whp easily. Plus Xluben is running like 27-28psi to make those numbers.
#11 |
Member#: 27091
NWIC
Franco--Deatschwerks 1000 cc injectors, DW 265 fuel pump, stock rails.
Looks like what you are seeing is probably about right. Have fun and enjoy. |
#12 |
Member#: 171773
South East
Vehicle:04 wrx sti jbp dom 3 xtr w meth! |
Are you iwg?
#13 |
Member#: 193628
E. Canada
#14 |
Member#: 196071
Post Logs so we can see Timing, Boost, RPM, Etc....
#15 |
Member#: 27091
NWIC
Franko-- 92 octane, here in WA state.
#16 |
Member#: 307236
ewg or iwg?
#17 |
Member#: 171773
South East
#18 |
Member#: 299442
Vehicle:2005 Forester XT |
Franko, what part of easten Canada? As far east as the maritimes by chance?
#19 |
Member#: 193628
E. Canada
Nope, newfoundland. Yeah, its out there.
