Old 10-03-2012, 01:58 AM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default Got a authentic Garrett Disco Potato, what should i do with it?
Hi,
My engine just gave up on me and I'm looking at rebuild the car. A friend of mine is kind enough to give me his Garrett turbo (Disco Potato). However, i understand the flange is different to a subbie. Is there a way around it? What are the alternatives, if any, or i swapping out the hot side is the only way?
Yours,
Jacky
jacky599r is offline   Reply With Quote
Old 10-03-2012, 02:01 AM   #2
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Go rotated, thats youre option.
Old 10-03-2012, 02:17 AM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Yeah, go rotated with an exhaust flange smaller than any of the off-the shelf rotated kits. You're looking at paying someone to fabricate a custom uppipe / downpipe if you want to use that turbo.
Old 10-03-2012, 02:31 AM   #4
jacky599r
Member#: 137631
2006 WRX
Red
Hi, thank you for the responses!
It is a pity the regulations are pretty strict back here in Singapore...so, getting custom exhaust work is pretty much out of the question. Besides, i have got a stock location CAI and turbo inlets. Should changing the hotside a simpler choice? What are the drawbacks?
Old 10-03-2012, 03:09 AM   #5
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
It cant be done with that turbo to mount in the stock location. It has to be custom. Thats the only way
Old 10-03-2012, 09:25 AM   #6
s2ktosti
Member#: 70151
2011 WRX Limited
Sell it and buy a turbo that will work.
s2ktosti is offline   Reply With Quote
Old 10-03-2012, 09:51 AM   #7
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
and that is that
Old 10-03-2012, 05:21 PM   #8
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
The main drawback here is that what you want is not readily available for purchase.
I suppose you can see if ATP or Blouch will sell one of their hotsides seperately, but I doubt they would.
The realistic solutions are to go rotated with custom fabbed pipes or use a different turbo. There are no off-the shelf solutions for a Disco potato, because that turbo is quite small and comparable to the significantly less expensive route of buying a used STi turbo and bolting it on without any fuss.
Old 10-03-2012, 05:27 PM   #9
sjs0433
Member#: 86061
I've always wanted to stick a larger gt28r on a STI just to see how it works out. I feel like it drive like a VF39 on steroids. Shouldn't be any worse than a vf39 anywhere and should be able to pump out a bit more power. For me ideally I'd love to have a fat powerband with about 350whp and the VF39 just won't get me there on pump gas. I have no desire to run anything but pump either.
sjs0433 is offline   Reply With Quote
Old 10-19-2012, 06:57 AM   #10
jacky599r
Member#: 137631
2006 WRX
Red
thanks guys
Old 10-19-2012, 07:57 AM   #11
tunertype
Member#: 335033
2009 wrx
Dark Gray Metallic
get some flanges a welder and some pipe and do it yourself. it's not rocket science it's pipes.
tunertype is offline   Reply With Quote
Old 10-19-2012, 10:56 AM   #12
mattminer
Member#: 90642
WKD Everything
This is exactly why the blouch dominator series was created lol. The dom 1.5 and 2.5 are both GT28 center sections.
mattminer is offline   Reply With Quote
Old 10-19-2012, 04:01 PM   #13
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Get this done...
http://www.ebay.com/itm/GT2860R-UPGR...sories&vxp=mtr
Then buy one of these and an upipe with ewg...
http://www.ebay.com/itm/GT2871R-7cmT...sories&vxp=mtr
For your reference, this was my 2.0 with a rotated disco potato, hydra and manual boost controller at 20 psi... Power band was great.
gt3071r with wg turbine wheel on 2.0, the turbine wheel was slightly bigger than the 2871r wheel 56.5mm instead of 54mm, not a full size 3071r wheel, 60mm. Car was a '00 RS with 2 people in it, virtual dyno was modified for the RS.
theotherguy is offline   Reply With Quote
Old 10-19-2012, 05:57 PM   #14
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
3071r centers, not GT28 centers. Blouch sells a subaru flanged GT28 and they probably sell like one every couple years because of it's price vs. a 16G.
Old 10-19-2012, 07:19 PM   #15
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
reading, it's fundamental.
or, perhaps it's more rocket sciencey than pipes.
ekw is offline   Reply With Quote
Old 10-20-2012, 11:22 AM   #16
theotherguy
Member#: 191514
'05 FXT 6spd, 98
You can get a 7cm subaru turbine housing for a gt28 for $165 and a wastegate actuator from Kinugawa. Running a gt28rs on a 2.5 is another subject...
Old 10-21-2012, 12:25 AM   #17
jacky599r
Member#: 137631
2006 WRX
Red
Thanks man, more or less what I'm looking for. Do they have a bigger hot side? Ive previously read that 7cms are too small for the 2.5s. I'll heed your advice with the upgrade. I cannot touch the exhaust pipings due to strict laws - could get a jail term for it.
Since it would be a DD street car, I believe he Turbo should serve this purpose well. I'm thinking of bolting a 6 speed too
Old 10-21-2012, 11:05 AM   #18
theotherguy
Member#: 191514
'05 FXT 6spd, 98
I haven't been able to find an 8cm^2 turbine housing for a gt turbo. I asked the vendor and they said that they were not available. Many have used the 7cm on a 2.5 but I don't know if it is optimal. With the the relatively small turbine wheel on the gt28 (47/53.9) it may help get it spooled up quickly, a little port work on the turbine housing may help. Since you are getting it free, it may be worth it to experiment. After the 56 trim/ 71 wheel upgrade, it may be like a super fast spooling td05-20g.
Is your compressor housing 3"? Do the Singapore models have TGV's? May be another problem for you.
Old 10-21-2012, 01:03 PM   #19
jacky599r
Member#: 137631
2006 WRX
Red
Hey,
Yeah, it appears the 7cm is more bad than good for the 2.5. What do i need to look out for to get a hotside to work? Im pondering if i should send it for balancing...Oh well, the inlet is 2.4 and we do have TGVs...
