Old 10-03-2012, 08:52 AM   #1
epistax
Member#: 224197
2015 435ix GC
Imperial Blue
Default 2013 WRX Plan
I love my 2013 WRX hatch. There are a few things I'd like to improve, and I'd like to try to keep a budget of about $2,000 over the next two years. I think the non-technical pieces will cost me around $800 or under (head unit, rear-view mirror, head & taillights).
Which leaves me about $1200 to address the powertrain. I don't have a specific WHP goal--my butt dynometer can't tell me whether a car I'm in is 250 WHP or 260 WHP, but I know I'd like to decrease the turbo lag and increase low/mid range response / power.
My initial thought was to replace the turbo inlet and get a torqued performance e-tune (open source) and roll with that for a while. Maybe 10k miles later I'd replace the down pipe and a catless or high-flow and get a pro-tune. I would just gut the down pipe but I lack the equipment. I would consult a tuner before picking the pipe.
So the way I usually see these threads go my main questions is:
1) Do I seem to have my head on straight? I don't think I'm way off base.
And if I'm not way off base:
2) Is there anything else I could do to get me a better bang for the buck given my (somewhat vague) intent?
3) (Crystal ball question) How likely am I to just want more after this?
It's of secondary concern, but still very important to me, to not impact the reliability of the car.
epistax is offline   Reply With Quote
Old 10-03-2012, 01:36 PM   #2
bacalhau16
Member#: 297565
2011 WRX hatch
Your goals seems pretty legitimate. You have the right idea with getting a tune. It should be one of the first things you do. Adding the Downpipe will void your warranty, so Thats up to u. I've been stage 2 on my 2011 for about 14k miles now with no issues. Take care of your car and it will take care of you.
bacalhau16 is offline   Reply With Quote
Old 10-03-2012, 01:50 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
1) Seems fine
2) Skip the turbo inlet
3) Very likely
Does your $2k budget include regular maintenance, or just mods? Depending on how much and how hard you drive, 2 years could mean 6 oil changes, a new set of tires, and a new set of brakes...and there goes the majority of your $2k budget.
Old 10-03-2012, 03:13 PM   #4
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Skip the inlet get a downpipe and a etune for the best bang for your buck.
nate_fisher is offline   Reply With Quote
Old 10-03-2012, 03:47 PM   #5
MaddMax
Member#: 9264
2016 BMW M235i 6MT
$80 Turbo blanket. Reduce heat soak, improve throttle response, reduce turbo lag
$120 for a more aggressive alignment. Crank in the camber, especially up front.
$80 for Stoptech pads. Better bite.
$90 STI 19mm sway bar.
MaddMax is online now   Reply With Quote
Old 10-03-2012, 05:02 PM   #6
epistax
Member#: 224197
2015 435ix GC
Imperial Blue
Thanks.
Originally Posted by the suicidal eggroll View Post
1) Seems fine
3) Very likely
Thanks. This is a 2k for improvement budget, not $2k available in total for the car. I'll be spending money on oil changes, air filters, possibly brakes, winter tires, etc.
I figured that I'd try the do-it-yourself turbo wrap. At <$40 I considered that in the noise as far as costs go, but thanks for reminding me.
Thanks for the brake pad advice. I've never installed my own but I would like to this time. My last car I traded in @ 45k miles and the pads were still solid, but maybe these ones won't last as long...
Man I forgot about the sway bar. That's a must have for me actually. The body roll seems to be better than on my old Impreza.
Thanks guys
Old 10-03-2012, 06:23 PM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Skip the "custom super stupid aggressive alignment" advice. You have no need for aggressive alignment on the street or occasional turn. And will contribute to faster tire wear.
Maybe once your brake pads are worn out, then upgrade. Otherwise you will not really want to justify the cost.
Skip the inlet till down the road. You don't really gain much from them more then a sense of safety from a rotted inlet.
Old 10-04-2012, 04:19 PM   #8
MaddMax
Member#: 9264
2016 BMW M235i 6MT
I disagree. A more aggressive aligment will improve the steering feel in turns, slow or fast. Since all you'd really be changing is camber for a street based car, additional tire wear isn't a problem. Yeah, it will wear more on the inner edges, but your tires will still wear out in the middle before the inner edges do. The argument could also be made that the increased negative camber reduces outer edge wear.
If you want better initial bite and brake feel, get the Stoptech Street pads. More dusting, but well worth the improvments.
Old 10-04-2012, 05:10 PM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
If you want the car to feel better in turns, other mods will go a lot further then an alignment. Aggressive camber is not a benefit on the street.
Old 10-04-2012, 06:33 PM   #10
04ScoobyWtf
Member#: 287974
Just get a downpipe and a tune. Your up pipe is already Catless.
04ScoobyWtf is offline   Reply With Quote
Old 10-04-2012, 07:11 PM   #11
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
but what about the loads of cars with tons of negative camber and stretched tires everywhere!? I know they're hardcore because they have stickers galore! (sponsors?)
SenorDucK is offline   Reply With Quote
Old 10-04-2012, 08:28 PM   #12
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Speak for yourself.
Old 10-04-2012, 08:40 PM   #13
cineris
Member#: 263329
2011 Impreza WRX
For #3: I told myself I wouldn't touch the car. Then I joined the forum. A month later, stage 1. I told myself I'd stop there. Eight months later, stage 2 and an intercooler. I told myself I peaked as far as modding the car. That was 4 months ago; now I'm going E85 and building the engine. It never ends.
cineris is offline   Reply With Quote
Old 10-04-2012, 11:33 PM   #14
pux888
Member#: 8356
02 STi swap
12 WRX limited
Thats a very subjective opinion and "the street" means a hell of alot of different things to different people.
pux888 is offline   Reply With Quote
Old 10-06-2012, 03:26 AM   #15
jale1
Member#: 312015
short shifter and bushings, makes ur shifting a lot more crisp, but it's a personal thing with that
jale1 is offline   Reply With Quote
Old 10-06-2012, 02:20 PM   #16
epistax
Member#: 224197
2015 435ix GC
Imperial Blue
A kartboy shifter was going to be my first upgrade originally, but the 2013 WRX that became available already has the OEM short shifter so I'm good there! I'm very happy with the short shifter, it's a nice improvement over the original that I had been driving on my '09 Impreza for 3 years.
Old 10-06-2012, 03:30 PM   #17
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Here some really good advice forget power mods!!!!
Talk to "TURN IN CONCEPTS" get a full bushing kit or "WHITELINE" which ever u would prefer cuz either way your suby will then feel confident, meaning building driver confidence!!! U will be amazed how different your suby will feel and handle. Would also consider coilovers like kW v3's..ect if your budget would allow as this would already kill the budget u have now but don't cheap out in this category
Save the power mods for down the road u don't want to risk voiding warranty claims unless u have deep pockets and obviously u don't with a 2k budget over 2yrs. Just enjoy your new ride and anything u do decide to go with use the search button its your friend hope this helps as u will thank me later
