Old 02-20-2012, 06:05 PM   #1
RTechChef
Member#: 293242
Default Buttercup - R-Technique's Charge Speed Widebody/PUR Wheel'd 2011 STI Sedan
Buttercup - R-Technique's 2011 SWP STI Sedan
It started out as this:
After being picked up for SEMA 2011 the building and moding madness began. Long story short, here's what was planned:
The end result for my 2011 SEMA debut was this:
Mods are as follows:
*UPDATE Coming Soon*
Thanks for checking my build out.
-Christopher
RTechChef is offline   Reply With Quote
Old 02-20-2012, 06:06 PM   #2
RTechChef
Member#: 293242
I wanted to post more information about my wheels. When I was trying to figure out what size and offset to get made for my wheels, I searched High & Low all around the forums to figure it out. Ultimately I ended with this configuration:
Brand: Forgestar
Style: F14-Concave
Offset: +34
Color: Matte Gold
Tire: 255/35/19
I wanted to have the deepest concave possible with this wheel as well as keep my wheel as flush as possible. I did end up having to roll my rears and fronts. In fact, I ended up taking out the front fenter liners. I plan on modifying them later to be placed back on to protect the wires and intake that are fully exposed at the moment. I also need to camber the rear since I still rub a little bit when going up curbs. That'll happen once i get some rear camber bolts to make it happen. I'd like to go about -1 and lower the car another .5". I'll also be chaning my tires to a 245/35/19 to get a little more clearance. The only issue I'll have at that point will be my lower frame bar which is about another .5" lower than the car frame (more about this to come).
Here are some pictures and details about them:
Here they are when I picked them up!
Here is a closeup in the sun of the Matte Gold finish.
Tires mounted and ready to go....
http://farm7.static.flickr.com/6060/...73b0771b43.jpg
Here is a closeup to see the clearance of the wheel from the front caliper.
I haven't measured, but it's close.
And finally on the car:
Enjoy!
Here is the Blog Post by Forgestar about the car and wheels:
http://www.forgestar.com/blog/?p=1732
Old 02-20-2012, 06:06 PM   #3
RTechChef
Member#: 293242
Here are some pictures of my bars installed:
Front Under Brace Bar
Mid Under Brace
Rear Under Brace
The Mid-bar sits the lowest of all the bars and is acutally the lowest point on my underside. It's about .5" lower than the rest of the car, so this was a bit unexpected after first slamming the car with this bar installed. I ended up having to raise the car up a .5" just to clear speedbumps and crappy roads here in Los Angeles. Other than that they perform wonderfully. Super light-weight and do their job well. Props to them.
You can get these bars from Phase 2 Motortrend in Los Angeles. They are the US distributor for them. Just talk with Wayne and he can set you up.
phase2motortrend.com
This is also where I got my Coilovers (Curcuit Sports) which are equally amazing! They are dual adjustable and 12-way dampening adjustable. All that for UNDER $1000.00. Can't beat it.
Side View (also Calipers before being painted)
Another shot on the car
And another.
Last time I check the website Phase 2 did not have them listed for our cars, but they ARE available. You just need to contact them. I need to bring my car in for picture of the products and what-not so they can post it on the site. This goes for both all the under-brace bars, strut bars (rear in the works), and coilovers.
Old 02-20-2012, 06:06 PM   #4
RTechChef
Member#: 293242
Here are some Engine and exterior shots of the car:
Alutec Strut tower bar and wires/hose from the NX N-tercooler kit.
Close-up of the Circuit Sports Front Camber Plates & Adjustable knob. They are 12-way adjustable. On the softest setting, it's almost identical to stock. On the stiffest, I bounce all over the place when driving on so-cal roads. I currently run softest up front and +6 on the rears to tighten the back a bit to avoid rubbing till I adjust my camber. Feel is great for my daily-drive.
Close-Up of my Odyssey Battery & hold down.
AEM intake and greddy catch-can. I'll have to relocated the catch-can once I get my FMIC. It's a nice spot to show-off for now, but not the best for a FMIC.
Close-up of Hella Supertone Horns (painted to match car) and my Front Plate Delete.
And finally a picture of the rear of the car. It's debadged and paint matched trim. Still debating if I'm going "red-out" the turn signals....
Old 02-20-2012, 06:07 PM   #5
RTechChef
Member#: 293242
Photoshoot on the car (SEMA BUILD):
Old 02-20-2012, 06:10 PM   #6
RTechChef
Member#: 293242
Here is the link to all the pictures in my set if you'd like to see them:
Buttercup's Photoshoot
Pictures of Buttercups' NEW look...COMING SOON!
-Christopher
Old 02-20-2012, 06:11 PM   #7
RTechChef
Member#: 293242
Much love to Fluidampr for protecting Buttercup and giving us the great opportunity to be in this months (March 2012) DSport Magazine to represent them.
Checkout page 89 of the March 2012 Issue of D-Sport Magazine to see Buttercup in her 1st Magazine Debut!
Also be sure to check out FluidamprŪ Harmonic Dampers Made in U.S.A. for protecting your Subby (and adding HP)!
Old 02-20-2012, 06:11 PM   #8
RTechChef
Member#: 293242
UPDATE: 10-03-2012
Here are some of the "in-progress" pictures of the Charge Speed Wide-Body kit for the 11+ sedans. I will debut the new look at SEMA 2012 at the Charge Speed Booth. Be sure to come check it out!
Test fitting my new wheel setup: 19x10 +20 Rose Gold PUR 4our
More pictures of the kit are also posted on the Charge Speed Facebook page. And others on my facebook R-Technique page
All 4 corners are 20mm wider.
Old 02-20-2012, 06:16 PM   #9
RTechChef
Member#: 293242
Reso again....
Old 03-21-2012, 05:28 PM   #10
RTechChef
Member#: 293242
New Pictures coming soon with New Mods!
Old 03-21-2012, 05:43 PM   #11
Nitrous
Member#: 136929
Probably one of the worst mod paths for a DD subie I've ever seen on NASIOC.
Nitrous is offline   Reply With Quote
Old 03-21-2012, 06:20 PM   #12
CatfaceType-R
Member#: 81102
No, that would be modding engine while not tuned!
Not a very nice 1st post. I think it's not super overdone, yet...at least some later suspension parts(braces). It was made for sema, not for you.
Old 03-21-2012, 06:22 PM   #13
Badler
Member#: 133597
Needs more stickers. *barf*
Badler is offline   Reply With Quote
Old 03-21-2012, 06:34 PM   #14
07blitz
Member#: 286969
probably cause theyre his sponsors^ but anyways, nice car
07blitz is offline   Reply With Quote
Old 03-21-2012, 06:55 PM   #15
stu
Member#: 25768
35R bugeye
Slowbaru
Looks like its 2003 again... roll call
stu is offline   Reply With Quote
Old 03-21-2012, 07:05 PM   #16
insane_one
Member#: 301431
2005 Evolution VIII
shoulda went with NOOSSSSSSSS!! Toretto approved
insane_one is offline   Reply With Quote
Old 04-04-2012, 09:08 PM   #17
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
nice car! I'm also going to go with 19's on my car
Gregor91 is offline   Reply With Quote
Old 10-03-2012, 05:06 PM   #18
RTechChef
Member#: 293242
Updated for new look coming at SEMA 2012
Also note: First post still needs to be updated....Mod list has expanded a bit.
Old 10-03-2012, 05:17 PM   #19
xSHERIx
Member#: 261932
2002 Impreza WRX
thats so sick man, im looking forward to seeing it finished
xSHERIx is offline   Reply With Quote
Old 10-03-2012, 06:12 PM   #20
Ultimateone
Member#: 48025
15 Mustang GT
awful wheels for the widebody but i guess you're getting them on the cheap if sponsored
Ultimateone is offline   Reply With Quote
Old 10-03-2012, 06:30 PM   #21
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
I like the gold wheels..thats about it.
scby rex is offline   Reply With Quote
Old 11-07-2012, 02:47 PM   #22
RTechChef
Member#: 293242
Here is a walk around of the car from SEMA 2012
https://www.facebook.com/v/4365699192411
& a picture:
Old 11-07-2012, 04:02 PM   #23
dritgert
Member#: 320203
2015 Impreza wrx STI
Galaxy Blue Pearl
Love the white and gold. Looking to do that combo with mine
dritgert is offline   Reply With Quote
Gillman Subaru's project 2011 STI sedan, ...thoughts and input? glilly Texas Impreza Club Forum -- TXIC 22 01-19-2013 07:48 AM
WTB : 08+ Catted DP - Downpipe for my 2011 STI Sedan RTechChef Private 'Wanted' Classifieds 0 02-20-2012 05:53 PM
Comparing 2011 STi Sedan to 2011 WRX Sedan DasWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-21-2010 07:09 AM
Need 2011 STi Sedan for a Video - free mudflaps 409Industries Southern California Impreza Club Forum -- SCIC 6 12-19-2010 03:19 PM
2011 STi Sedan in white - 720p Action Video shot on Oregon's awsome roads! SubaruShawnPDX North West Impreza Club Forum -- NWIC 24 08-24-2010 02:39 PM
