Old 10-02-2012, 04:54 PM   #1
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Default Bad Spot For O2 Sensor?
I'm in the process of installing my AEM UEGO gauge and have a quick question. The instructions state to have the bung welded in at least 36" downstream from the exhaust port. I found a place where I can mount the sensor and have plenty of space so it doesn't get hung up anywhere.
My question is, I marked the spot in the pictures below, will the sensor being mounted on that bend cause any problems with the gauges accuracy?
Any input would be appreciated. Thanks!
DMD
Old 10-02-2012, 06:05 PM   #2
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
probably going to hit the bottom of your car there. Going to need to put it closer to the seam where the cast and stainless meet facing the trans. COBBs version of that dp has it right at the top after the turbo. I have my uego about 12 inches max from the turbo, right were my tuner wanted it.
Old 10-02-2012, 06:10 PM   #3
kaczmarz
Member#: 307624
2008 WRX Hatch
325/347, 380XT, 8 cm2
"36" downstream from the exhaust port" doesn't mean "36" downstream from the turbo". You also have to count turbo and length of the uppipe and headers.
kaczmarz is offline   Reply With Quote
Old 10-02-2012, 06:55 PM   #4
RoadKillDMD
Member#: 284792
2011 STI
Blurple
It won't hit anything, I'm sure of it I chose this spot while the DP was still on the car to make sure the sensore wasn't going to hit the firewall or any crossmembers when I install it. There's plenty of room. I just want to know if the sensors accuracy will be compromised if it was mounted at that bend. Will the bend cause any change in exhaust flow to the sensor causing it to misread?
36" psshhh I took all of that into account, thanks . If you look again, my mark is only ~18" from the turbo flange ...
Old 10-02-2012, 07:09 PM   #5
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
dont be a fool. put the sensor up closer to the turbo.
Old 10-02-2012, 08:25 PM   #6
RoadKillDMD
Member#: 284792
2011 STI
Blurple
So, I'm a fool for following instructions? Well you're no help at all!
Just to be clear, I plan on using this gauge to constantly monitor my AFR's and I don't want to have to replace the sensor more than I need to. I've heard of people running this sensor just past the turbo and being fine for over a year. On the other hand, I have also seen that plenty of sensors were crapping out within the first couple of months at this location... I want to play it safe and install the sensor where and how it describes in the instructions.
Old 10-02-2012, 08:30 PM   #7
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
putting your WBO2 that far downstream will skew any results you have when trying to tune. Especially because of the location of those bends. putting it closer to the turbo WONT hurt it, and will make it more accurate.
But one has to ask, why are you even bothering to ask the question when you are just going to ignore the input from those who have CLEARLY been doing this MUCH longer than you.
Do you think so many aftermarket DP makers would put an O2 bung in the bellmouth if it was a bad idea to run the sensor there? (cobb for example)
At the end of the day, its your car, so I could give a flying **** if you go run it into a wall. I just think you need to pull your head out of your ass and try listening to the experience people on this forum.
Old 10-02-2012, 09:01 PM   #8
kaczmarz
Member#: 307624
2008 WRX Hatch
I have EL Perrin headers and they have 16-18" long tube for each head and about 6" for each pair of heads. Then add 12" for uppipe and you have almost 36" of piping before turbo!
I know the lengths well because I had to pre-cut the wrap before wrapping the heads and uppipe.
Old 10-02-2012, 09:11 PM   #9
hutch959
Member#: 267463
uhhhhhh.... i have mine further down from that based on what my tuner suggested. he said... "dont put it up in the bellmouth, ive seen cars have some funny readings with it mounted there" .....it is about 12" up from the stock sensor, on the right hand side of the car at about a 15 deg angle up. there is a little space between the downpipe and the frame.
works great. ill try to get some pics.
Now, if you think about it from an "gas flow" perspective.. at wot, the velocity in the turbine side of the belmouth is fast and the wg side is turbulant... this means any swirling gases on that side would go lean/rich/lean... depending on how the gases were moving. It would make beter since to get it down in the main stream of the gases away from this to give a more consistant reading.
the graphs from my aem failsafe, looking at the af's... look smooth.
hutch959 is offline   Reply With Quote
Old 10-02-2012, 10:22 PM   #10
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
It's the same exhaust coming through the turbine and the wastegate...
Old 10-02-2012, 10:37 PM   #11
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Post cat or after an exhaust leak maybe... Unless you have a plot showing WOT AFR readings at different locations on a catless exhaust, GTFO. There are many people running widebands in the stock rear O2 bung. Why would instructions tell you to mount it farther down if it was going to skew the readings?
Like you? >>"PUT IT CLOSER TO THE TURBO! " Yeah, super informative br0! If you have some real input, please do share. Otherwise, please don't waist my time...
Those bungs are meant for widebands to be TEMPORARILY mounted for tuning purposes. Heat kills the sensors. The closer to the heat source, the faster your o2 sensor will dye. FWIW, I have read instructions clearly stating that 'Even though the DP has an included bung 4" post turbo, it shouldn't be used as the sensor will overheat under boost.'
Page 2, sect. 4
www.wbo2.com/lsu/lsuinstal.pdf
Now that's just plain rude...
Old 10-02-2012, 11:01 PM   #12
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Dont put the sensor in the bend of any tubing (creates a weak point). Bottom out once on a speed bump and you will be very mad. Not only that, but from experience that is too close still. I know what the directions say, but move it further back about another 6" to 8". Ive installed many of these and most pro tuners will tell you this is where to install it also.
UK-Wagon is offline   Reply With Quote
Old 10-02-2012, 11:44 PM   #13
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Finally! Just the response that I needed. Thanks a lot UK-Wagon!
Old 10-03-2012, 03:47 AM   #14
HXC573
Member#: 268007
Ice Silver Metallic
I'm with this dude . 6 to 8 will be good on my 2012 WRX I have my wideband tig welded 2 1/2 inches before the stock o2 sensor
HXC573 is offline   Reply With Quote
Old 10-03-2012, 06:48 AM   #15
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
This may not be what you are looking for but here goes:
I've been here since Lincoln was in office. I've seen them used and installed from every clock position from 1 to midnight and back again. I've seen them used and installed from every pipe position from 2 microns from the turbo to hanging out of the tailpipe. In the grand scheme of things, it matters not where you install the damn thing. Install it where you think would be best and provides easiest access if you are going to be futzing with it a lot. Then have yourself a cup of tea and a cigarette on one of those long cigarette holders you see women in the 20s use.
Old 10-03-2012, 08:10 AM   #16
DMD
yer gunna do whatever yer gunna do with it regardless of what anybody tells you
so just bloody install it and stop wasting our time here
Old 10-03-2012, 12:43 PM   #17
RoadKillDMD
Member#: 284792
2011 STI
Blurple
I'm pretty sure I aggreed with UK-Wagon about moving it, but okay
Thanks Bomber. That actually does help a lot!
I'm all done with this thread mods if ya feel like locking it
Old 10-03-2012, 12:53 PM   #18
the suicidal eggroll
Member#: 51961
2005 STi
Remember, the farther downstream your wideband is, the greater the lag between combustion and the readings. A big lag can make tuning your fueling an absolute nightmare, especially under WOT or dynamic conditions (tip-in, etc).
With the sensor down by the stock rear one, I wouldn't be surprised if you have a 1/4 second delay between combustion and measurement. At the CAN logging speeds of what, 100 Hz? You're going to need to look 20-30 lines down in your log to find the AFR that corresponds with a given load/MAF/RPM. At low load the delay will be even larger.
Old 10-03-2012, 12:59 PM   #19
RoadKillDMD
Member#: 284792
2011 STI
Blurple
How far back would you suggest is too far? I didn't plan on going as far back as the rear o2 sensor. I was going to follow UK's advice and move it bak just a few more inches from where my mark is now.
Old 10-03-2012, 01:10 PM   #20
Member#: 51961
2005 STi
There's no real "this is too far" line, the correlation will just get worse as you go farther back. My sensor is about 8" from the turbo and I already have a lag of about 170 milliseconds (best guess by doing multiple WOT logs in different gears and cross-correlating the AFR error vs RPM in each log for different lags).
Old 10-03-2012, 01:14 PM   #21
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Makes sense. Thanks for the input Eggroll! I'm off to the muffler shop
Old 10-03-2012, 06:49 PM   #22
scby rex
Member#: 104878
02 wrxbastardchild
hopefully your "muffler shop" isnt going to make it look like bird **** with mig welding splatter.
Old 10-03-2012, 07:21 PM   #23
cablegorilla
Member#: 288942
2011 wrx premium sed
Mine is way the f back almost at the cat back. It reads just fine. Turboxs put it there on their down pipe
cablegorilla is offline   Reply With Quote
