Old 10-03-2012, 11:50 PM   #1
orest100
Member#: 329931
2004 wrx
Default Turbo question
Hey guys i just finished rebuilding my 2.0 wrx with a new crank, bearings,gaskets, piston and rings. It had one completely missing rod bearing thats why i rebuilt it, got rid off all the metal shavings inside. My question is, when i went to put the turbo on i noticed the shaft had alot of play (in/out) and up and down ( just bought the car). It will obvuasly need to be rebuilt but i was wondering can i leave the turbo on just to start the car and hear it idle for the first time untill i get the rebuild kit? also i blew air through the oil line to get rid of any metal that could have been in the turbo from the bearing.
orest100 is offline   Reply With Quote
Old 10-03-2012, 11:58 PM   #2
paulpat
Member#: 237145
02 WRX
12 FXT
In and out play is bad. Td04's are common in the local classified sections.
paulpat is offline   Reply With Quote
Old 10-04-2012, 12:25 AM   #3
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
not worth the risk, just get a diff turbo
tebriel is offline   Reply With Quote
Old 10-04-2012, 12:26 AM   #4
orest100
Member#: 329931
2004 wrx
can i still start it with the turbo on?
Old 10-04-2012, 12:27 AM   #5
orest100
Member#: 329931
2004 wrx
get another one or rebuild?
Old 10-04-2012, 02:36 PM   #6
paulpat
Member#: 237145
02 WRX
12 FXT
rebuilding or buying used is about the same price. TD04's typically dont like to be rebuilt. ...they can be but its not common... Something about supply and demand, market shift... better options available...
Old 10-04-2012, 06:12 PM   #7
zashoe
Member#: 329523
2002 Impreza WRX
to to the classified section and find a slightly used td04. I got one with 10k miles for $150 shipped. it's easier and cheaper than new/rebuild/upgrade. of course, this only applies if you're happy with your current numbers.
zashoe is offline   Reply With Quote
Old 10-04-2012, 06:16 PM   #8
zashoe
Member#: 329523
2002 Impreza WRX
also, I'm fairly certain you COULD start it with no turbo at all, provided it's for a very brief period or time.
Old 10-04-2012, 06:30 PM   #9
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
You can find used td04s all the time in the private classifieds, be careful though when making a purchase
As for starting the car with a bad turbo, you can but I wouldn't drive it
brew02wrx is offline   Reply With Quote
Old 10-04-2012, 06:51 PM   #10
djuhnk
Member#: 331392
yeah you can start it with that turbo on as long as it has no oil shavings and stuff in it. when you make sure of this take your ignition fuse out and crank the car till the oil light goes off to prime the system with oil.
djuhnk is offline   Reply With Quote
Old 10-04-2012, 11:42 PM   #11
orest100
Member#: 329931
2004 wrx
I just want to start it, def not going to drive it, i will also unhook the return line for the oil just in case any shavings are still inside the turbo. Thanks guys!
