Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 10-03-2012, 09:05 PM   #1
TurboLegacy
Member#: 82068
1992 Legacy
Maroon
Default VF39 blades hitting housing? Help
I have not dealt with many turbos before and I just purchased this used off of craigslist. It seems to have very little shaft play but these marks around the blades worry me. Is this normal or should I ask for a refund. Thanks in advance. I re-sized these but they are still big.
TurboLegacy is offline   Reply With Quote
Old 10-03-2012, 11:28 PM   #2
rdieder
Member#: 257818
2007 STi
Refund , its gonna blow up sooner or later
rdieder is offline   Reply With Quote
Old 10-03-2012, 11:30 PM   #3
StealthTL
Member#: 206912
2006 Forester XT
If it touches, it lunches.
Any contact is dead bearings.
StealthTL is offline   Reply With Quote
Old 10-04-2012, 02:17 AM   #4
STIBungy
Member#: 51684
Its fine. I have a used vf39 in my garage and looks just like that.
STIBungy is offline   Reply With Quote
Old 10-04-2012, 08:11 AM   #5
WMCCook29
Member#: 152685
2005 VF34 WRX Wagon
Contact can be perfectly acceptable in a turbo that has no oil flowing through it. The oil acts as a cushion between the bearings and the shaft and when there's no oil there can be slight contact between the blades and the housing.
WMCCook29 is offline   Reply With Quote
Old 10-04-2012, 08:33 AM   #6
Frank-i-e
Member#: 316463
2005 STi
You're going to be perfectly fine. What you should be worried about more is if you see pieces missing off the compressor. As long as there isn't too much drag. It appears to be very minimal.
Frank-i-e is online now   Reply With Quote
Old 10-04-2012, 09:20 AM   #7
TurboLegacy
Member#: 82068
1992 Legacy
Maroon
After looking at all the ads for vf's on here the marks seem to be normal. The pictures are a bit deceiving as it makes it appear the blades are touching the housing, they have a mm or so of clearance.
Old 10-04-2012, 09:24 AM   #8
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
This is correct. You really should put a little oil in the drain side, and rotate the turbine. Prop it up so the oil has a chance to distributed through the bearing cartridge. Let it sit for a day or so and repeat. It will eventually get enough in there to re center the cartritge. I had to do this after an old vf-39 sat for a few months. If it is going to stay in storage put some caps on everything after the oiling.
gutie04 is offline   Reply With Quote
Old 10-04-2012, 09:32 AM   #9
Frank-i-e
Member#: 316463
2005 STi
This is correct too, oil fills up voids and the play is more when turbo is dry. Minimal difference but true!
Old 10-04-2012, 01:31 PM   #10
luvless2620
Member#: 190566
Do you even know what a VF39 looks like?
luvless2620 is offline   Reply With Quote
Old 10-04-2012, 03:26 PM   #11
TurboLegacy
Member#: 82068
1992 Legacy
Maroon
GOOD NEW!! I took it to a turbo rebuild shop to get a professional opinion and they said the end play was normal! The marks are caused by running high flow filters that allow tiny particles to pass into the turbo and said it is nothing to worry about. Thanks again everyone.
Old 10-04-2012, 03:52 PM   #12
LBell05STI
Member#: 305890
2005 STI
I call BS. Shaft play is shaft play. How much in and out and side to side play do you have?
LBell05STI is offline   Reply With Quote
Old 10-04-2012, 04:11 PM   #13
TurboLegacy
Member#: 82068
1992 Legacy
Maroon
Zero in and out, side to side is very little. He also said because it was a thrust bearing with no oil there would be a tiny bit as mine showed, once pressurized with oil he said there would be none. I could try to get a dial indicator hooked up to it, but I tend to believe somone who works with turbos every day when he tells me that it is a good turbo.
