Old 10-03-2012, 02:05 PM   #1151
kenny doggins
Member#: 326540
2012 Impreza MT SP
Originally Posted by pkL View Post
I really like the look of the gunmetal rims, I wish they would offer them here in Canada. It sucks how you're all the way in California otherwise I would drive down and get those rims from you.
I can meet you in Humboldt
kenny doggins is offline   Reply With Quote
Old 10-03-2012, 02:20 PM   #1152
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Originally Posted by grizzuhl View Post
Just a quick note.
On my '12 Impreza Hatch I currently have a SPT Front Strut Brace for a '12 WRX installed. It fits perfectly although it is barley touching the back of the engine bay.
Second I have been building custom intake for my car using an '99 intake, '04 WRX MAF housing *"Had to fabricate a different hole out of plexiglas for the sensor because the hole on the original housing is 1.4" and our MAF sensors need a 1" hole", and some various silicone tubing/bends. So far on my intake I have been getting a check engine light that causes my cruise control and traction control to flash. I'm thinking I may have to go into the dealership and get my ECU re-flashed.
The ECU reflash isn't going to help your problems. While I believe intakes don't harm the car, yours does. You probably don't have the correct placement of the MAF. Your homegrown approach is risky. Just go buy an intake.
Either you're silly, or you're a troll.
The sound the intake gives is just a personal preference for me. Also, as soon as I start boring out my cylinders and building up the N/A engine, I'm going to need that increased air flow right? From what I have read/heard it's possible to get more power out of an N/A engine than a Factory Turbo it's just fairly costly
No, the stock airboxes have been shown to provide ample flow for even WRX's and STI's. The setup is quite similar to the 2.0i
Because their nice people.
I have heard that getting a CEL with a new intake is quite common and all it needs is a reflash to work properly. I'm going to the dealership to ask them to do it before I do it myself and defiantly void my warranty.
No CELs are not common on intake installs. If it does give you a CEL then take it off your car. The reflash you're thinking of is TUNING the ECU to maximize the performance of the intake. Not reflash the stock ECU. I would do more homework if you plan on doing any of the above. I have to ask, how do you plan on doing it yourself?
You'll spend more on the car to make it faster than it would be to just buy a WRX. Taking an econobox and having high ambitions will burn a hole in your wallet with not proportional gains. Not trying to squash your hopes and dreams, just giving you the reality of the matter.
*Edit, I think I'm feeding a troll.
Old 10-03-2012, 02:22 PM   #1153
grizzuhl
Member#: 334032
2012 Impreza 5 door
Yes, The image with the intake on the car is before I fabricated the plate for the sensor. The Second is the MAF housing, plate, and the sensor being bonded with silicone.
grizzuhl is offline   Reply With Quote
Old 10-03-2012, 02:28 PM   #1154
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Looks awesome but it isn't going work on the NA FB20 motor with the MAF sensor. Go to the NA threads on the forums and read up on the CAI/SRI threads and you will learn that the 'Hybrid' mod is the only way it will work right. Hope Williarty isn't reading this...lol
Old 10-03-2012, 02:37 PM   #1155
ST Eye
Member#: 73068
*PHEW* Not a troll! Vacuum leaks in the intake path can cause a CEL. Scan your code.
Old 10-03-2012, 02:42 PM   #1156
uspopo
Member#: 317014
ISM
I do like the black strut tower brace Grizzuhl. Cusco or Ebay?
Old 10-03-2012, 03:00 PM   #1157
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Nice hot air intake!
Old 10-03-2012, 03:06 PM   #1158
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
The problem with intakes is the MAF scaling. The ecu thinks it is ingesting a certain amount of air based on the stock intake plumbing. If you modify it it is likely flowing a different amount of air. The ECU needs to be re-scaled for the new air flow rate. Otherwise your car could be totally confused as to why the AFR is not behaving the way it was expecting. This could result in a too rich or a dangerous too lean condition.
saabarupp is offline   Reply With Quote
Old 10-03-2012, 03:43 PM   #1159
grizzuhl
Member#: 334032
2012 Impreza 5 door
Thanks guys, I am much more informed on my intake project thank before. I will defiantly be doing more research into MAF Scaling and leaks. When I read my codes I did have a system lean error code so that will do it. It is all just a learning experience, hopefully I don't do anything that will lead to permanent damage
As for my Strut Bar, I ordered it through the dealership. I believe the product code is SOA8431130.
Old 10-03-2012, 04:24 PM   #1160
uspopo
Member#: 317014
ISM
Thanks. I didn't know that Subaru had released a non-adjustable strut brace because the adj. SPT one is 500.00 which is crazy....How much was it?
Old 10-03-2012, 04:35 PM   #1161
jsteg
Member#: 329271
Ice Silver Metallic
Also interested in this!
Old 10-03-2012, 04:39 PM   #1162
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Typing in "SOA8431130" into google shopping shows prices around $200 for the spt strut tower brace front
Old 10-03-2012, 04:55 PM   #1163
grizzuhl
Member#: 334032
2012 Impreza 5 door
Yeah, I got mine for about $230. It took just about a day to ship to the dealership. When I went to order it, the parts department said it was new to the SPT catalog.
Old 10-03-2012, 05:08 PM   #1164
myrt1987
Member#: 323103
2012 Limited 2.0i
apparently the SOA8431130 strut is shared between 09-11 forrester and impreza according to google. idk. i want it tho. lol
Old 10-03-2012, 05:19 PM   #1165
kenny doggins
Member#: 326540
2012 Impreza MT SP
fitment is all good? No rubbing on back of engine bay?
I thought i red somewhere about one that almost fits, but not quite. Hopefully this isn't the one I'm thinking of cause I want it too
Old 10-03-2012, 05:20 PM   #1166
uspopo
Member#: 317014
ISM
Glad to know because I waited 7 weeks for my Cusco brace. Thanks Subaru for just letting us know now...haha
Old 10-03-2012, 05:27 PM   #1167
grizzuhl
Member#: 334032
2012 Impreza 5 door
It doesn't rub it's really really close to doing so though.
Old 10-03-2012, 10:18 PM   #1168
uspopo
Member#: 317014
ISM
Got the Cusco brace installed this evening and snapped a quick pic...Love it!
Old 10-03-2012, 10:24 PM   #1169
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Have you tried getting a MAF housing that can be welded to the intake pipe? That would help with any leaks if the silicone is not working
http://www.ebay.com/itm/260853047915...84.m1423.l2648
italia490 is offline   Reply With Quote
Old 10-03-2012, 10:47 PM   #1170
grizzuhl
Member#: 334032
2012 Impreza 5 door
No, I haven't yet. I will defiantly look into it after I try putting some high heat proof sealant on all the connection points and if it doesn't work.
I got most of the holes sealed it seems. When I first started up the car I got just under 2000 rpms, took it around to see if there where any holes. I heard some hissing. Turned it off checked the piping and it started up at just under 1000 rpms. So, there's defiantly a lot more work to do.
Old 10-03-2012, 10:53 PM   #1171
ST Eye
Member#: 73068
Just be aware that if you have engine problems it won't be covered under warranty.
Old 10-04-2012, 12:03 AM   #1172
scoutisimo
Member#: 315759
2014 WRX Hatch
Love that you found a new solution for the strut brace though! Thanks for sharing!
Old 10-04-2012, 12:46 AM   #1173
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Your Cusco one looks exactly like my eBay one.
Old 10-04-2012, 12:51 AM   #1174
ans2k
Member#: 315631
2012 Impreza Sport
not really, the base of the cusco looks sturdier than the ebay one.
Old 10-04-2012, 01:04 AM   #1175
scoutisimo
Member#: 315759
2014 WRX Hatch
Originally Posted by ST Eye View Post
The aftermarket will make one. In fact ppl normally buy knockoffs from ebay.
or just make them yourself. if you search around you'll find the how to. i was planning on this at some point, not pink but same difference. Once you get the badge off, goof off takes the paint right off the inside of the emblem leaving the chrome stars and a clear background ready for your paint of choice. i'm assuming the 2012 emblem is able to be modified like this as well.
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 05:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 12:18 PM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 11:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 11:58 PM
