#26 | |
Member#: 295602
SWIC
#27 |
Member#: 251804
SWIC
Vehicle:05 WRB STi |
#28 | |
Member#: 295602
SWIC
#29 |
Member#: 290896
Vehicle:2004 STi, FOR SALE PSM |
I was wondering the same as OP. My car put down 335/375 on a mustang dyno, 110 degrees. Before wcf it put down 255/290, that has me worried that I wont trap over 106ish. Hopefully the cooler weather bumps up the power?
#30 |
Member#: 142029
Tri-State
Vehicle:2013 Fozz 2004 STi, 1991 Miata BRG |
All other things equal, the cooler the temp, the more the powah. Just log to make sure your IDC isn't too high and you're still safe.
#31 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 WRX Wagon |
OP, why don't you post your full setup as well as dyno graph? Also, at what RPM are you shifting at?
#32 |
Member#: 295602
SWIC
Full car setup!
Grimmspeed catless uppipe Tial 38mm EWG vf39 FiveO 850cc injectors Fmic Aem cai Invidia q300 tbe 255walbro fuel pump 1° cooler spark plugs All on 91 pump gas |
#33 | |
Member#: 82745
SCIC
You would have made around the same power with 650cc, IWG, stock heat range plugs, and an STI TMIC. |
#34 | |
Member#: 230605
SCIC
Vehicle:VF39 HBSpeed Wagon Don't lean onmah fenders! |
You're probably seeing that low of a trap speed as a combo of a slow launch and/or the dyno reading high. |
#35 | |
Member#: 181298
MAIC
Vehicle:02 , Vf43 Inside.. 12 seconds at a time |
#36 |
Member#: 295602
SWIC
I did the mods with plan of a 20g in the near future. 13.2 @102 mph
#37 |
Member#: 23123
SWIC
Vehicle:05 Legacy GT 13 Scion FR-S |
Matt, on that same dyno, i was @ 468 with CF, and trapped 119.
12.12 @ 119, IIRC. crappy launch, crappy tires, spinning the rear thru 2nd. ![]() ![]() Last edited by Z0rr0; 10-04-2012 at 12:59 PM. Reason: dyno sheet |
#38 | |
Member#: 295602
SWIC
#39 | |
Member#: 246990
MAIC
Vehicle:2010 Wrx |
#40 | |
Member#: 82745
SCIC
In addition, why is the tune cut around 6.7K? I would have it tuned to 7k-7.1K. |
#41 |
Member#: 295602
SWIC
What Is the point of correction factor then.........?
#42 |
Member#: 295602
SWIC
Like saying bhp versus whp!?
#43 |
Member#: 134211
#44 |
Member#: 9749
SWIC
Vehicle:- |
#45 | |
Member#: 295602
SWIC
#46 |
Member#: 54918
Sounds like you're at elevation so the dyno correction factor for a turbocharged car is not accurate as someone else has mentioned. Based on that other correction factor I see you're likely making 255 whp.
With that said every dyno is different. On the a relatively low reading dynajet I had a customer with 290 whp pump gas hit 110 (stock turbo sti, Hydra EMS,TBE, FMIC) and my car went 112 mph with 309 whp pump gas (same mods). Other dynos in our area need 335-340 whp to hit 110-112 mph. Now you know so adjust your HP goals to get the trap speeds you want. |
#47 |
Member#: 82965
My contribution.
284whp 2003 Blobeye STi Type UK - So the 2.0litre model. 12.1 @ 113mph Graph and video: https://www.youtube.com/watch?v=UliHkXPZ24E ![]() |
