Old 02-02-2012, 07:14 AM   #1
modular
Member#: 308850
2012 Impreza Sport
Camellia Red
Default Daytime Running Light Delete-2012 Impreza
Anyone done this as of yet? Picked up a 2012 Impreza Sport for the wife. She hates the DRL's and wants them turned off. Is the procedure the same as the older models?
modular is offline   Reply With Quote
Old 02-02-2012, 07:50 AM   #2
infinite012
Member#: 74392
2015 Forester
More than likely it's the exact same procedure. Try to check under the passenger side headlight for the grey box.
infinite012 is offline   Reply With Quote
Old 02-02-2012, 06:01 PM   #3
modular
Member#: 308850
2012 Impreza Sport
Camellia Red
I saw no box but there was a relay in the main fuse box that was labeled just for the DRL's. I pulled that and all seems well.
Old 02-16-2012, 06:37 AM   #4
modular
Member#: 308850
2012 Impreza Sport
Camellia Red
Well, the wife went to use the hi beams yesterday morning and no joy. Seems pulling the DRL relay kills the hi beams as well. Back to square one.
Anyone found a way to successfully disable the DRL's while keeping the hi's intact?
Old 04-28-2012, 10:49 AM   #5
Jmzda
Member#: 313812
2012 Impreza 2.0i Pr
Dark Gray Metallic
I'd like to know how to do this as well
Old 04-28-2012, 12:09 PM   #6
bassman12350
Member#: 230795
2011 Impreza WRX 5dr
WR Blue Pearl
There is a thread on this procedure at the Subaru Outback Owners Forum. I'll see if I can hunt it down and post the link....
bassman12350 is offline   Reply With Quote
Old 04-28-2012, 12:15 PM   #7
bassman12350
Member#: 230795
WR Blue Pearl
Here is the link I was referring to. The proper post describes trimming down a pin on the DRL relay. This mod will NOT cut out the high beams, just the DRLs. http://www.subaruoutback.org/forums/...outback-6.html
Old 05-13-2012, 04:14 PM   #8
imcausinmadrukis
Member#: 318978
Has anyone figured out and successfully removed/disabled the DRL on the 2012 Impreza?
imcausinmadrukis is offline   Reply With Quote
Old 08-02-2012, 07:33 PM   #9
boostedwrx12
Member#: 316369
whats up bud if you find out anything on the disable the DRL's I want to do the same thing on my 12' wrx
boostedwrx12 is offline   Reply With Quote
Old 08-04-2012, 12:40 PM   #10
Lacessit
Member#: 311443
'12 2.0i 5DR DGM
'06 s2000
Just did this the other day.
Remove the front bumper.
Under the passenger headlight is a gray connector (large one).
Unplug.
Start the car, release handbrake, confirm no DRL's.
Turn on your lights, flip to highbeams, confirm they work.
Tape off both ends of the plugs to prevent water getting in.
Replace bumper and enjoy.
Gray plug under light & behind turn signal:
Lacessit is offline   Reply With Quote
Old 09-03-2012, 01:33 AM   #11
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I did the same thing to disable my DRLs I wanted to prolong the life of my shutters on my retrofitted HID projectors, there is a pink connector plug on the passenger side, once you unhook that the DRL no longer turn on.
Old 09-05-2012, 01:45 PM   #12
Angelus911
Member#: 89967
2012 Impreza Sport
FWIW, I remember people saying that you should check with your insurance before doing this, as DRL are listed as a safety feature in your car.
Old 09-10-2012, 10:06 AM   #13
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Why does she hate DRLs?
Old 10-04-2012, 09:08 AM   #14
jasonz34
Member#: 312498
So if someone wanted to turn my other lights into DRL's they could splice into the grey connector? Or could this cause other problems because of the low current?
jasonz34 is offline   Reply With Quote
Old 10-15-2012, 06:16 PM   #15
Jmzda
Member#: 313812
Dark Gray Metallic
So there is no way to disable the DRL's & still have the high beams work without removing the front bumper on the '12 model?
Old 10-15-2012, 10:29 PM   #16
trbill2003
Member#: 322643
2012 Imprezza Tourin
Deep Cherry Pearl
I don't understand why anyone would want to delete their DRL. It is the law here in B.C. Canada. The DRL system increases your visibility to others greatly, therefore it is a safety feature. We can easily see the benefits when we compare to out of country tourists coming to visit. Who are very welcome I might add, but it is a lot harder to see cars without DRL. I suggest, keep them working it might save your life.
trbill2003 is offline   Reply With Quote
Old 10-15-2012, 10:43 PM   #17
Bluefoton
Member#: 141373
2008 2.5i-hatch -
^ +1. Not fun to almost miss hitting a black dirty SUV with no DRLs in a badly lit dirty tunnel when you change lanes..
Old 10-16-2012, 07:27 PM   #18
Jmzda
Member#: 313812
Dark Gray Metallic
Unplug.
You are the man! 3 pop clips to get the passenger side mud flap free remove the plug, seal it from water, reinsert pop clips and done in under 10 mins. I appreciate you sharing the tip!!
Old 03-12-2013, 10:38 PM   #19
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Unplug.
That can also be done from the engine bay.
Remove the air duct that is held down by 2 plastic screws/tabs
remove box containing air filter.
same Plug is located there.
Unplug
Done
no need to remove bumper
gregorz4 is online now   Reply With Quote
2006 impreza outback daytime running lights failure hydej Newbies & FAQs 0 01-12-2011 10:11 AM
How to disable Daytime Running Light in 2007 Impreza wlit Electrical & Lighting 3 04-01-2010 09:40 PM
('93-'01) Installing daytime running lights on 93 Impreza? stigc8 Impreza Forum 1 04-22-2008 03:12 PM
Question: brake light on, clock light out, daytime running light out PhoKingWRX Electrical & Lighting 2 05-22-2005 07:29 AM
('93-'01) How to remove daytime running lights on 2002 Imprezas Dr. Spud Funk Impreza Forum 9 05-08-2001 05:43 PM
