Old 03-22-2012, 10:01 PM   #1
pktzygt
Member#: 70612
1973 Porsche 914
Default ej20k Porsche swap need wiring help
I know it is a longshot to find someone with EMS Stinger, but I know you have experience with an ej20k.
The coil pack is on top of the motor and I have an external ignitor. The coil has 3 wires, Red/Green, Yellow/Red and Blue. I don’t know which one goes to which wire on the ignitor.
I'm still trying to figure out which wire is the trigger and which one is the sync.
I don't know which injector wire goes to which injector port on the ECU.
Any help would be greatly appreciated.
Here is the diagram for the Stinger.
pktzygt is offline   Reply With Quote
Old 03-28-2012, 06:01 AM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Are you using the original Subaru igniter or an aftermarket unit?
Are you saying that the engine originally has spark plug wires (not coil on plug)?
A picture is worth a thousand words. It would help narrow down which engine you have if you took a top view picture and a picture of the valve covers.
ciper is offline   Reply With Quote
Old 04-05-2012, 09:23 PM   #3
pktzygt
Member#: 70612
1973 Porsche 914
I figured it out. I called up my EMS Stinger guru and he pointed me the right direction.
It is actually a late ej20g, which had the same coil setup as the ej20k. Coil on top of manifold with plug wires.
I'm using an aftermarket ignitor.
Old 10-04-2012, 10:28 AM   #4
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
What aftermarket ignitor was this? I need one for my late G swap. I have no spark at startup and realized there's no ignitor.
GGSimpreza is offline   Reply With Quote
Halfway through my swap... Need wiring diagrams Soarer Subaru Conversions 12 09-08-2008 07:07 PM
greddy gauges - need wiring help hybrid gti 2 Electrical & Lighting 7 09-13-2005 05:27 AM
Need Wiring help! Infest Car Audio, Video & Security 8 12-03-2004 12:27 PM
Need wiring help, ASAP Greg Sharpe General Forum Archive 0 02-17-2001 07:25 AM
Field SFC, need wiring help - someone w/ owners manual Tony Technical Forum Archive 2 08-02-2000 03:06 PM
Message Board Statistics All times are GMT -4. The time now is 11:02 PM.
