Old 10-03-2012, 11:20 PM   #51
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Originally Posted by A Fatal Ode
.......or lay in a pile of tools.
That^^, definitely causes frustration.
You finally re-position yourself under the car, so you can actually get some good leverage, and the wrench you need is no where to be found. "Weird, I just had it", so you blindly reach all around yourself, still cannot find said wrench. Get angry enough and crawl out to look for it, and it's highlighted in neon colors laying right where you were in the driveway.
-_-
That^^^^ happens a lot.
ManualOverAuto is offline   Reply With Quote
Old 10-03-2012, 11:39 PM   #52
Just1More
Member#: 319078
2005 STi
Originally Posted by the suicidal eggroll View Post
What EWG is this? I've never had that problem with my Tial 44mm
Anyway, swapping springs started to become such a PITA on mine (since like you said, you have to basically stand on the EWG to compress it enough to start the bolts), that I just bought a bunch of bolts from McMaster that were the right thread pattern, all different lengths. The longest ones are about 5" long and can thread without compressing the springs at all. Those let me compress it about an inch, then I swap out three of them for ones that are an inch shorter, they let me compress it another inch, etc. After about 5 steps I'm able to swap in the final bolts that can seal it up all the way.
It takes a little bit of time swapping bolts in and out as the EWG compresses more and more, but it's much less fist-through-the-wall inducing than trying to do it "normally".
I've used a drill press(no bit) to compress the EWG and BOV when putting them together and taking em apart. Works good
Just1More is offline   Reply With Quote
Old 10-03-2012, 11:53 PM   #53
daseca07
Member#: 277630
2007 WRX TR
well i do it for a living all day everyday and on the side. i just treat it like a stubborn woman mouthing off at you over petty stuff and just walk away for a bit cool off and return to the problem with a clear head. If not bad things will happen
daseca07 is offline   Reply With Quote
Old 10-04-2012, 12:05 AM   #54
PlasticFoamMan
Member#: 197764
02 WRX Stage DD
PRND 01G
@ OP, throw tools, buy new ones!
PlasticFoamMan is offline   Reply With Quote
Old 10-04-2012, 12:16 AM   #55
A Fatal Ode
Member#: 243616
2010 wrx gh stage 2
i almost threw my first wrench the other day... but i came in and made this thread instead.
A Fatal Ode is offline   Reply With Quote
Old 10-04-2012, 10:31 AM   #56
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Originally Posted by A Fatal Ode View Post
subie as in just imprezas or all models? here in OK, we have foresters and outbacks EVERYWHERE. a few rex's and sti's. and a brz or two. maybe a couple of leggyz.
Subarus, like all of them... San Antonio is the 9th largest city in the country (last I heard) and there is ONE subaru dealership, and its tiny.
bugeyetex is offline   Reply With Quote
Old 10-04-2012, 11:00 AM   #57
Member#: 51961
2005 STi
2012 WRX
Originally Posted by bugeyetex View Post
Or you could live in San Antonio like me where there is only one subie per square mile.
I'd much rather have that, with the incredibly tight knit group of Subaru enthusiasts you have, than to live in an area like Boulder where there are ten subarus per eighth mile and 99.9999999% of the drivers couldn't care less what you or anybody else is driving. I was driving down the road yesterday right next to not one, but TWO other modded 11-12 WRX hatchbacks, three wide on a 6 lane (3 each way) road, and NEITHER of the other drivers even noticed.
Everyone's just in their own world doing their own thing up here. In SA you can post on NASIOC that you're going to pull your engine and need some help, and you'd get 5 people showing up the next day with cherry pickers, engine stands, beer, etc. Do the same thing in Boulder and you'll hear nothing but crickets. It's not about the number of Subarus in your area, it's about the quality of the drivers, and San Antonio is hard to beat.
Old 10-04-2012, 11:03 AM   #58
mechatricity
Member#: 290592
2006 WRX Wagon
2004 WRX Wagon
I leave the garage, down 2-3 beers, then go back into the garage with:
1) less concern for perfection
2) less self-control when it comes to hammering something into place
It usually works itself out
/thread. i've done this many, many times. Beers are usually preceded immediately by a ratchet ricocheting across the floor.
mechatricity is offline   Reply With Quote
Old 10-05-2012, 11:01 AM   #59
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
followed by ten minutes of wandering around trying to figure out where the he77 it landed.
Old 10-05-2012, 11:08 AM   #60
ManualOverAuto
Member#: 304662
Sedona red Pearl
They bounce like a superball!
Old 10-05-2012, 11:25 AM   #61
amarks563
Member#: 283410
2007 WRX Wagon
UGM
I feel that every job I do on my car takes twice as long as people say. I put on a rear sway bar last weekend. You know how the bolts have an unthreaded section near the head for the end link bushing? Whatever joker owned the car before me used a bolt that had an unthreaded section at the end, with the threads under the end link and an assload of loctite to keep it on (because there were no threads under the nut, genius). Long story short, I disintegrated the rear endlinks and now realize that some of my car's handling oddness may have been from the sway bar being fused in place.
amarks563 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 05:27 PM.
