Old 10-03-2012, 07:28 PM   #1
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Default Defi advance BF issue.
Well i just finished installing my new Defi advance control unit V2, BF advance boost, oil pressure and egt gauges.
The blue light on the control box lights up a constant blue which shows that the power wire is wired correctly. The gauges all light up fine and work with the controllers features. (none of the peak or warning lights are flashing to indicate a wiring issue with the gauges).
The issue is that my gauges aren't reading accurately at all. The egt gauge doesn't even move until I have been driving for a while, the boost gauge needle dances around and reads .5-1 bar at idle (and never shows the correct boost), and the oil pressure gauge has a mind of its own.
I put all the sensors in just the same way I did with my previous Defi red racers so im confident that the sensors are good, as well as all the wiring.
Im thinking its a control box malfunction. warranty possibly.
Has anyone else had a similar issue? Thoughts?
I--RIDE--BIKES is offline   Reply With Quote
Old 10-04-2012, 10:39 AM   #2
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Anyone have an idea?
Old 10-08-2012, 10:18 AM   #3
tuzzio
Member#: 292532
05 STI
I honestly have no idea. However, I have two controllers sitting here. One bnib and one used, I'm no help, but if they won't warranty your controller, PM me and I'll give you a deal
tuzzio is offline   Reply With Quote
Old 10-12-2012, 11:20 PM   #4
TwinscrollGT35R
Member#: 256810
You have the sensors plugged into the right ports on the controller?
TwinscrollGT35R is offline   Reply With Quote
Old 10-13-2012, 05:38 PM   #5
IlovemyRex
Member#: 99933
05 OBXT
99 2.5 RS
Here is a link for the manual. I would recommend downloading and troubleshooting your wiring. Also check the little sliders on the side of the controller to make sure they are in the correct position.
http://www.defi-shop.com/installation/manual/
IlovemyRex is offline   Reply With Quote
Old 01-03-2013, 02:19 AM   #6
MG rex
Member#: 341359
2013 WRX Hatch
Off topic but related. How were you able to power the control unit?
Im trying to correctly connect the wires but not working atm. Used fuse taps and attached them to the fuse box so no cutting any wires.
Help or suggestions appreciated
MG rex is offline   Reply With Quote
Old 01-03-2013, 10:17 AM   #7
tuzzio
Member#: 292532
05 STI
Personally I would do as I have done and use the harness for the clock. Everyone seems to have wire tap issues lately
Old 01-03-2013, 01:27 PM   #8
TwinscrollGT35R
Member#: 256810
Damn solar flares
Old 01-23-2013, 12:00 PM   #9
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
I ended up using the decks harness as well as the harness for the hazard switch. Now everything is working just fine.
