Welcome to the North American Subaru Impreza Owners Club Tuesday July 29, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 10-01-2012, 03:24 PM   #4351
pgrily
Member#: 333354
Originally Posted by pgrily View Post
What should battery voltage be at during upper rpms under load during a pull? I'm still getting stuttering in the upper rpms (~5900+). Last log, the battery voltage was getting down as low as 12.16v around 6500 rpm. I've tried switching the coil packs and the spark plugs are all good and gapped at .026. Seems like the stuttering is related to my battery voltage dropping under load.
Any help?
I took a log in my brother's e85'd WRX and his battery voltage only dipped down to 13.2 under load in the upper RPM's. Guess I'll have to try a new/different alternator at this point as I'm running out of possibilities.
Does anyone know exactly what the battery voltage option in Romraider is measuring?
Edit--Both pulls were done with no accessories/lights on.
pgrily is offline   Reply With Quote
Old 10-01-2012, 04:03 PM   #4352
PHruska
Member#: 214589
2002 wrx wagon
Originally Posted by todeswalzer
How are they off? Are the studs too wide apart?
They seem to Sit about an inch to the right if looking from the front of the car.
PHruska is offline   Reply With Quote
Old 10-01-2012, 05:44 PM   #4353
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
Both of them are 1" to the right?
Push the whole motor to the left then.
You should be able to get under the car (with the car on jack stands) and push up on the exhaust manifold and pull the motor in the correct direction.
JRsleeper is offline   Reply With Quote
Old 10-01-2012, 05:48 PM   #4354
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
then move the motor to the left by about an inch..
If its a V7/V8/V9 I know for a fact the stock mounts will work fine
Old 10-01-2012, 05:54 PM   #4355
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
^^ Yes, and it really helps if you have a friend helping you (one person under the car, one above). GL
Torquey is offline   Reply With Quote
Old 10-01-2012, 06:08 PM   #4356
PHruska
Member#: 214589
2002 wrx wagon
It's not that simple for some reason though. I'm not a master tech or anything but if I just needed to move it over I would. When the motor mounts line up to the holes the Tranny and engine sit very far to the passengers side. That's why I'm confused.
Old 10-01-2012, 06:25 PM   #4357
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
Got any pics of this? I'd like to see the clearances of the valve covers to the frame rails.
All of the motor mounts are the same as the version 8. What tranny are you using. Did you use the correct mounts for your current tranny?
Old 10-01-2012, 08:15 PM   #4358
PHruska
Member#: 214589
2002 wrx wagon
At work now. Stock USDM 02 5spd w stock mounts. I'll try er out again tonight with a fresh head and see what happens.
Old 10-02-2012, 09:49 AM   #4359
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
that makes it even easier with the 5mt since the bellhousing doesnt have so much meat so you can squeeze the exh housing of the turbo by.
Old 10-02-2012, 10:36 AM   #4360
PHruska
Member#: 214589
2002 wrx wagon
I just pulled the turbo. Wasn't wanting to squeeze by very nicely.
Old 10-02-2012, 09:55 PM   #4361
PHruska
Member#: 214589
2002 wrx wagon
Got it in today. Mounts were fine. Was just too tired to make it work yest I guess.
Old 10-02-2012, 09:59 PM   #4362
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
see you got it! just takes some fanagaling to get it to work!
anyone else need some avcs harness's.
Old 10-03-2012, 01:05 AM   #4363
jhenry1983
Member#: 269361
2011 sti
03wrx Rallycar
Im going to need an avcs harness. Putting the ver8 in my GC into the bugeye rally car.
jhenry1983 is offline   Reply With Quote
Old 10-04-2012, 10:31 AM   #4364
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
any of you guys have trouble reading the JDM ecu? I have my test plugs connected and the car does not seem to go into test mode. the v8 motor is not in the car yet, as I'm just trying to pull the map off the v8 ECU. The test plug seems to make no difference, and the fuel pump does prime like it does with the usdm ecu. I can swap back the usdm ecu and read/write just fine. Swap back the jdm ecu and i can not access it. Neither with the romraider logger with the ign on and test plugs undone, or with the test plugs connected trying to use ecu flash. I've been flashing my 02 ecu for a few years now, so I'm pretty familiar with how finicky they can be as far as when you turn the ecu on and hit the read button.
I get the same error with the ecu on or off.
[18:55:10.472] denso02_bootloader_cmd_start
[18:55:11.706] denso02_bootloader_cmd_start
[18:55:12.940] denso02_bootloader_cmd_start
[18:55:14.159] denso02_bootloader_cmd_start
[18:55:15.394] denso02_bootloader_cmd_start
[18:55:15.831] kernel get version
[18:55:16.159] interface close
I just feel like the ECU isnt coming on or something. I'm kinda stumped. I've spent a couple hours just trying to read the ecu at this point.
Old 10-04-2012, 10:58 AM   #4365
WRick
Member#: 86107
I've also encountered the same issue this week with a collegues ej207 swapped 2002 TS.
I can log fine, read the learning view, have the car in test mode ( pump cycling ) but cannot for the life of me read the ecu.
I've tried ecuedit ( admin mode ) and ecuflash with same results.
WRick is offline   Reply With Quote
Old 10-04-2012, 11:41 AM   #4366
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
^^ I had the EXACT same issue when I tried this right before my swap... and even made a whole thread about it :
http://forums.nasioc.com/forums/show....php?t=2405875
... so lemme ask you as everyone on that thread asked me: "have you connected the jumper blocks, along with the green connectors?"...LOL even though the instructions don't call for it, for 'reading' purposes.
I personally never tried it with the jumper blocks while I still had the old setup, as I got impatient and started with the actual swap. My error was identical on romraider, but the fuel pump would prime just fine. The thought of a 'locked' ECU was bugging me the whole time... but once everything was said and done, we plugged the new one in along with AVCS wires AND the jumper blocks + green connectors ... and it read/ flashed like a champ. Mine is this particular model:
Old 10-04-2012, 11:50 AM   #4367
WRick
Member#: 86107
yeah I guess the jumper block must not be there. I assumed that if the jumper block wasn't there, it would be giving me a ''voltage too high/low'' error, but that I could at least get the ecu connected.
It's the ****tiest swap I've seen and I can't even find the damn flash connector
Old 10-04-2012, 12:00 PM   #4368
PHruska
Member#: 214589
2002 wrx wagon
What the hell is a jumper block? The thing you put in to reflash?
Old 10-04-2012, 12:07 PM   #4369
WRick
Member#: 86107
I made one like this
Make it as short as possible so you can leave it there
It's a white connector with nothing connected to it. You need THAT and the green connector to flash, but the flash block you can leave there.
Old 10-04-2012, 12:14 PM   #4370
PHruska
Member#: 214589
2002 wrx wagon
Even with a tactrix cable? I thought the point of those was that you could just flash through em.
Old 10-04-2012, 12:21 PM   #4371
simon021
Member#: 157532
2002 MY03 EJ207 E85
Oh ****. Did the tactrix cable come with one of those that wasnt needed on the USDM 02 wrx? I take it since it's the sti ecu, i need the jumper on the white plug as well. I seem to remember there being a couple jumper plugs with the tactrix cable that I didnt need. I've actually taken my green plugs out and replaced them with a switch, so I know thats not the issue. I seem to remember seeing that plug up under the dash yesterday as well. I'll check it out at lunch if I can. Might be raining and the car is outside atm =/
Old 10-04-2012, 12:25 PM   #4372
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Mine is tactrix 1.3... and you do need a flash connector/ jumper block when using it... or make one like WRick did. Tactrix 2.0 maybe different.
And from the list of cars on ECUFlash, I still had to choose 2002-2003 USDM Impreza, for it to work... even though there is an non-USDM option.
Old 10-04-2012, 12:29 PM   #4373
simon021
Member#: 157532
2002 MY03 EJ207 E85
Oh I see. For 02 you need the blue reflash connector, for 03-05 you need the white one. That would explain it. I'll jump the white connector and see if that gets things going
edit: Still no luck
Old 10-04-2012, 01:04 PM   #4374
PHruska
Member#: 214589
2002 wrx wagon
Right now I have a mystery vaccum hose underway pops up to right under the recirc. No idea what it goes to. Not the I/c hose. Anyone know?
Old 10-04-2012, 02:59 PM   #4375
OppositeLock
Member#: 54060
Now: v8 207/v6 5mt
Then: JRTune fastest td04
Pics?
OppositeLock is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain 10 06-03-2010 04:53 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain 21 10-17-2005 01:56 AM
