Old 10-03-2012, 11:38 PM   #1
POLSKA9000
Member#: 332026
Pearl
Default Knock feedback sporadically
Hello,
I have a 2011 WRX which I have flashed with the Stage 1 + SF HWG OTS map (Regular map was only peaking at 15.8 - 16.1 psi). For mods I of course have the COBB SF and an AVO TBH (if that could be called a mod, original kept opening up at the Throttle body). I ran a log today coming back from work and noticed a bit of sporadic knock feedback around the 2300-2800 rpm. I'm not exactly sure if this is normal. I've had it flashed for about a week +, don't think it gotten to 2 weeks.
Here is the log:
https://docs.google.com/open?id=0B7s...Wg5QlJoTzIyOUU
POLSKA9000 is offline   Reply With Quote
Old 10-04-2012, 03:55 AM   #2
Andrewxxcarlson
Member#: 316415
2006 WRX
You have to make the log file public
Andrewxxcarlson is offline   Reply With Quote
Old 10-04-2012, 10:08 AM   #3
Cobb Tuning
Member#: 4803
Originally Posted by POLSKA9000 View Post
Hello,
Here is the log:
You'll want to also convert the log to google docs' native format so that there is a preview.
Bill
Old 10-04-2012, 12:42 PM   #4
POLSKA9000
Member#: 332026
Pearl
I had the original set to anyone with link. I thought that should have worked... Anyway I uploaded an xlsx version and made it public.
https://docs.google.com/open?id=0B7s...ldTc0NOOGZ0VG8
This may be stupid, but I drove around town today, and there didn't seem to be any knock feedback. When I got on the highway the knock seemed to mainly if not only occur on turns. I can't say at what throttle position, but that's when it seemed to happen. I forgot to log this run but if this is a possibility I could log it next time?
Old 10-05-2012, 08:22 AM   #5
Cobb Tuning
Member#: 4803
You will see the occasional knock correction at low throttle/low loads or when throttle is changing - this is normal noise. What you want to do is to put the car under some heavy load and see how it responds. Check out our data logging video for details:
Bill
Old 10-05-2012, 10:29 PM   #6
POLSKA9000
Member#: 332026
Pearl
Thank you, that video was informative. I did do a 3rd gear pull a couple times and nothing so I guess it's nothing to worry about. At least now I know a little more about the values and what they actually mean because of that video!
