Old 10-04-2012, 03:39 PM   #2051
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Originally Posted by foghelmut View Post
Did it for another tank, more consistently, got 26.9. I fill up twice a week, that adds up pretty quick. I'm going to be driving much slower.
is that mostly highway? thats pretty bad. are you weaving through traffic?
Old 10-04-2012, 03:49 PM   #2052
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
You think 27 mpg is bad for 80 mph? At that speed, I would expect a sub-30 mpg average.
Old 10-04-2012, 04:02 PM   #2053
myrt1987
Member#: 323103
2012 Limited 2.0i
i wouldnt as long as you werent changing speed. cruise control on typical highway grades i would guess 33 mpg for 80% hywy trip.
but i thought he was going 70mph as per his prior email.
Old 10-04-2012, 04:28 PM   #2054
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
My commute each way is about 5 miles of suburban road, and 37 miles of highway. Very little traffic for about 27 of those miles, so I'm neither drafting or weaving. I was not using cruise control either, and I wasn't changing speed much.
I was averaging 29.5 while doing 70 mph on the highway. I'm going to take it down to 65 for a few tanks.
At 65 mph, it should take roughly 34 minutes to do the 37 miles.
At 80 mph, it should take roughly 27.5 minutes to do the 37 miles.
I can leave the house 7 minutes earlier if it will save me some cash.
foghelmut is offline   Reply With Quote
Old 10-04-2012, 05:10 PM   #2055
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
For some reason i can't. My commute sounds identical
Old 10-04-2012, 07:47 PM   #2056
53x12
Member#: 206332
The EPA tests cars at what, 55mph? 80mph is significantly higher than that, so I would expect mpg's to drop well below 30 as well. Just to be expected.
http://www.dieselnet.com/standards/cycles/hwfet.php
53x12 is offline   Reply With Quote
Old 10-04-2012, 07:59 PM   #2057
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I've had my Impreza since January and have put about 4500 miles on the car so far. My commute to work is about 8-9 miles one way and it's all surface streets, no highway. If I drive conservatively I average about 29.5-30 mpg. When I don't drive as conservatively, I think the lowest I've seen was just under 28mpg.
italia490 is offline   Reply With Quote
Old 10-04-2012, 08:51 PM   #2058
53x12
Member#: 206332
I think the biggest factors for me have been outside air temp, engine temp, type of fuel (ethanol based vs. not), outside wind direction, terrain and traffic. All of those seem to play into the mpg factor.
Old 10-04-2012, 09:01 PM   #2059
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
He's averaging 44 MPH. This video is a lie. Notice that there is no tenths column in the number. What a jackarse.
Old 10-04-2012, 09:28 PM   #2060
ST Eye
Member#: 73068
What happened to the video??
Old 10-04-2012, 10:23 PM   #2061
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Didn't think to check my tires this morning before going to work. My gas mileage sucked this morning big time, but not just due to underinflated tires they was also 3"of slush i was plowing though and a 40mph headwind. Was getting 23mpg at 55mph.
Tonight with a 15mph tailwind i was only getting 28mpg at 75, which i know is low. Car was also sluggish in the handling department. When i got home after my 41 mile commute u checked my tires and they were all below 30, the front were down 6, while the back were down 5. Overinflating didn't seem to help much but underinflated site makes a big impact!
Old 10-04-2012, 10:43 PM   #2062
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
So what would you say is the ideal psi to inflate your tires to for a balance between handling (driveability) and mileage?
Old 10-04-2012, 10:51 PM   #2063
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I like 34/32. 38/36 was loose feeling and 32/30 feels mushy
Old 10-04-2012, 11:15 PM   #2064
chicagocpo
Member#: 315470
2012 Impreza LTD
Marine Blue Pearl
I think Stevehnm's point is that if two different model cars from two different manufacturers receive the same estimated EPA mileage (regardless of whether one of those cars is AWD or not), then you would expect those cars to deliver similar mileage if they were driven "in the real world" by the same driver, on the same roads, using the same gas, etc.
Stevehnm isn't saying (and he'll correct me if I'm wrong) that the Impreza should necessarily meet or beat its EPA's estimates. He's saying that if the Impreza can't meet or beat its EPA's estimates, then the Corolla (which he says has the same EPA estimate as the Impreza) shouldn't meet or beat the EPA's estimates either.
It's a good question. He owns a Corolla and an Impreza. They both have the same EPA estimates. Why can't he get the same real-world fuel economy from both? Your answer should not be "Because the Impreza is an AWD car", because if that's the excuse, then my follow-up question will be "Then how did the Impreza manage to achieve the same EPA estimate as the front-wheel drive Corolla?"
Don't get me wrong. I'm not complaining about my Impreza's fuel economy. I'm simply explaining how people seem to be misinterpreting Stevehnm's legitimate question.
First off, approaching 10k miles I average 34.5 mpg without trying much (drive 60-70), and I've hit 38 mpg over a full tank of gas "grannying" for nearly 500 miles mixed driving, so I'm ho-hum about the EPA estimate arguments. To the point above though, how about this: Cd for the 2004 Corolla is .30, . Cd for the 2012 Impreza is .31/.33 (4d/5d). (Hey out there, are the sedans getting better mpg's than the hatches??)
Drag on the car increases by the square of speed (says Wikipedia), not linear. So, the faster you go the more the effect of the drag difference is amplified. If you like to drive faster than EPA uses for estimates, you could expect to to see the lower drag car get better mileage than the higher Cd car all else being equal. Sort of makes sense to me, but I have to leave the math to others. Interesting post on efficiency in this forum at
http://forums.nasioc.com/forums/show...5&postcount=14, don't know if he's right - says power required increases by ^3 with speed..
chicagocpo is offline   Reply With Quote
Old 10-05-2012, 01:09 AM   #2065
pkL
Member#: 313093
2012 Impreza 2.0i
Ok thanks and how is the weather like in North Dakota at this time of the year?
Old 10-05-2012, 06:13 AM   #2066
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I use 35/33 cold inflation pressure, after driving less than two miles to the gas station's air pump.
Old 10-05-2012, 06:32 AM   #2067
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Crappy. Averages are supposed to be low 60's, instead we got snow yesterday. Thankfully it is all gone and next week should be back towards average
Old 10-05-2012, 07:32 AM   #2068
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
We are getting an early Fall out here so I am hoping for early snowfall this season.
Old 10-05-2012, 11:52 AM   #2069
leeden
Member#: 41654
2005 Impreza WRX STi
2012 Sport Limited
My normal commute is 12 miles each direction, all highway with hills and sometimes windy. I lock the cruise control at 70 mph and average 26 mpg.
This weekend, I took a 120 mile trip each direction. Again locked the cruise control at 70 mph. I estimated that I was on my way to 32 mpg but Fuelly shows I only managed 28 mpg!
I ride my motorcycle half the time for my commute. I can get 40 mpg like everybody else with my bike. I don't think the problem is my route, I think it's my Impreza. The low MPG is very disappointing to me.
leeden is offline   Reply With Quote
Old 10-05-2012, 12:02 PM   #2070
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Even after airing up my tires i was only managing 23mpg this morning again at 81mph into a 30mph headwind. So i guess that isn't bad as the car was seeing a combined 110mph wind, but still. Temp was 31f
Old 10-05-2012, 12:30 PM   #2071
myrt1987
Member#: 323103
2012 Limited 2.0i
get a sedan. im avg 39mpg, digital readout 42mpg
Old 10-05-2012, 12:40 PM   #2072
53x12
Member#: 206332
that is why your fuel economy was so poor.
Old 10-05-2012, 01:16 PM   #2073
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Took a long time to see that too, maybe 18 miles to get everything warmed upi think.
I used to see around 26-27 at the same speed but not as much wind and not as cold
Old 10-05-2012, 03:23 PM   #2074
myrt1987
Member#: 323103
2012 Limited 2.0i
im sure type of impreza makes a difference too. MT vs cvt, sedan vs hatch. MT has 50/50 power split besides having only 5 gear ratios. cvt isnt always a 50/50 power split. These differences plus C_d apparently being different could add up. More reasons im happy with my decision.
Old 10-05-2012, 04:14 PM   #2075
lohnny
Member#: 327531
2013 Impreza Sport
MBP
After my first 380 miles, about 70% highway, 30% city, my average is 30.1. Very pleased!
lohnny is offline   Reply With Quote
New Impreza owner, low mpg? stuffedcabbage Newbies & FAQs 34 09-25-2012 10:10 PM
2012 Impreza Reviewed - Whytecliff to Seymour brendan_mac Vancouver Impreza Club Forum -- VIC 16 12-23-2011 01:12 PM
NJ Impreza owners - sighting Dan G General Forum Archive 76 10-06-2000 12:24 AM
Md or Va Impreza owners - I have an Impreza related question. Snoopy General Forum Archive 1 06-05-2000 08:08 AM
