Old 10-04-2012, 03:41 PM   #4376
PHruska
Member#: 214589
2002 wrx wagon
Got er figured out. Trying to figure out how to make ac lines on the compressor work now.
PHruska is offline   Reply With Quote
Old 10-04-2012, 04:36 PM   #4377
25rsti
Member#: 166324
Arm strength is your best bet. Be careful though, dont bend too much. They're brittle lines those suckers. I learned the hard way.
Old 10-04-2012, 04:56 PM   #4378
RealDealTarheel
Member#: 142447
06 Outback
Originally Posted by Torquey View Post
^^ I had the EXACT same issue when I tried this right before my swap... and even made a whole thread about it :
http://forums.nasioc.com/forums/show....php?t=2405875
... so lemme ask you as everyone on that thread asked me: "have you connected the jumper blocks, along with the green connectors?"...LOL even though the instructions don't call for it, for 'reading' purposes.
I personally never tried it with the jumper blocks while I still had the old setup, as I got impatient and started with the actual swap. My error was identical on romraider, but the fuel pump would prime just fine. The thought of a 'locked' ECU was bugging me the whole time... but once everything was said and done, we plugged the new one in along with AVCS wires AND the jumper blocks + green connectors ... and it read/ flashed like a champ. Mine is this particular model:
I have the same ECU as you but I can read just fine with the green connectors together but can't log. So there's two white connectors that need to be jumped together in order to read/log? Using Tactrix 2.0
RealDealTarheel is offline   Reply With Quote
Old 10-04-2012, 05:32 PM   #4379
PHruska
Member#: 214589
2002 wrx wagon
so what do we do about the lack of an o2 on the up-pipe?
just leave that harness connector with nothing on it?
Old 10-04-2012, 05:43 PM   #4380
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
That's the factory EGT gauge i believe... just leave it unplugged. Doesn't cause any CEL on the JDM ECU.
Torquey is offline   Reply With Quote
Old 10-04-2012, 05:45 PM   #4381
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
In order to log with Romraider... you don't need any connectors. Just the tactrix plugged into the laptop, and point it to the correct COM port.
Old 10-04-2012, 05:48 PM   #4382
RealDealTarheel
Member#: 142447
06 Outback
Got it to work just now, no idea what was different. Now onto my boost and IAM problems.....
Old 10-04-2012, 06:25 PM   #4383
RealDealTarheel
Member#: 142447
06 Outback
Anyone who can jump in here, my IAM reads at a 0, when I reset the ECU it climbs to an 8 and then immediately drops to a 0 when I start the car. Anyone have any ideas?
Old 10-04-2012, 07:22 PM   #4384
PHruska
Member#: 214589
2002 wrx wagon
been searching and trying **** but i still cant get pins out of the ecu.
does anyone have any tips?
after the engine and rent im too broke to buy a harness right now so im trying to use the tgv wires for the brown and black plugs and run the jdm wires outta that harness for the grey plug.
Old 10-04-2012, 07:45 PM   #4385
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
Search more. This was found in this thread. Once you figure it out, it's pretty easy.
Good luck. Take your time with it
Originally Posted by WhiteBgeye02 View Post
the ecu plugs have little plastic things on the top that pop up like a 1-2mm. its the lock. you just use a small flat head and get it to pop up. its got two small clips that hold it down but you can force it up basically and then push it down when your done. looking at the end of the plugs that go into the ecu...
for reference we will use the side with the pop up locking thing as the top.
-each pin will have an empty space below it. this is were you put the needle in.hold the plug in one hand and with the needle put it into the bottom hole below the pin you need to move and you will hit a small tab. pull the tab down. so away from the pin your removing then pull slightly on other plug. this should make it so the pin is pulled out far enough that the clip you just moved down wont lock back down. then go on the back side and pull the pin out. the pins only go in one direction. which is the small tabs on the pins face the top of the plug (pretty sure)
. the other plug is much easier but these have intercal clips of the same idea but smaller so you have to go by feel. the needle should not go in more than like 5mm or so.
just looking at a plug with the locking thing on the top the pins site in the very tiny slots and there corresponding unlocking slot were the needle goes is below each one. its about 3x size the hole of were the pin actually sits.
I literally just figured this out... lol, but thanks so much for the detailed explanation. I'm glad i can now use the plug 'n play feature! Here are couple of pictures for illustration (the "test" connector was off the cut JDM harness that came with my swap) :
JRsleeper is offline   Reply With Quote
Old 10-04-2012, 08:07 PM   #4386
PHruska
Member#: 214589
2002 wrx wagon
i guess that wasnt what i was looking for cause im trying to move the harness side plugs.
thanks for the help though.
Edit: got it. im a dumbass.
Old 10-04-2012, 08:30 PM   #4387
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
The above pics are of the correct ecu pin connector that needs to re-pinned. And how to get them out.
I understand that you want to re-pin your stock tgv's also.
What exactly are you looking for?
Move which harness side plugs?
-ecu harness
-drivers side engine harness
-pass side body harness.
Old 10-04-2012, 09:38 PM   #4388
PHruska
Member#: 214589
2002 wrx wagon
i pulled the 4 wires that ran avcs off the jdm harness and one of them was cut. are any others in the harness shielded?
EDIT: none of the harness wires appear to be shielded. am i just looking over them? they all appear to be just regular wire.
Old 10-04-2012, 10:36 PM   #4389
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
If you have the JDM ECU wiring harness, then take a look at pin# 14 on the center most connector on the ECU end (which is also the smallest). The wire that is in there should be the 'shield common ground'. You need to integrate that to your chasis harness, along with the four other wires that go from the same ECU connector to get added to the passenger side grey plug. This is done for the AVCS sensor signals.
For the AVCS Solenoid signals... you don't add any wires, but just move four pins to different points on the same center ECU connectors as before. And in the engine bay move the same four wires one row above, on the driver side black connector. All this I did according to the DS1 motorsports wiring instructions... really hope you have a copy of it, as it explains how to read the pin numbers. I didn't reuse the JDM harness wires, but bought one made by Whitebgeye02.
If you are more of a visual person... check out the wiring pictures on this article that I found: http://www.importtuner.com/tech/0311it_sti_conversion/
Old 10-04-2012, 10:38 PM   #4390
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
man the harness is just so much easier!
Old 10-04-2012, 10:46 PM   #4391
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
^ harness made it easy. Along with the wiring diagram. Completed the harness install and re-pinned what was needed in a hour.
Old 10-04-2012, 11:18 PM   #4392
PHruska
Member#: 214589
2002 wrx wagon
Rad. ill try that out. the placement and wiring and moving pins isnt an issue for me. i got that on lock. spent a good hour messin with them today.
Old 10-04-2012, 11:32 PM   #4393
PHruska
Member#: 214589
2002 wrx wagon
so off of this harness?
Old 10-05-2012, 12:41 PM   #4394
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
you sir look like you have a genuine cluster ****! lol
Old 10-05-2012, 03:29 PM   #4395
PHruska
Member#: 214589
2002 wrx wagon
Everyone chill the **** out .... I got this. :/
Old 10-05-2012, 03:34 PM   #4396
25rsti
Member#: 166324
I'm so fricking pissed. I've been trying to get my car started all week with no luck. Passed a couple hurdles and now I'm stumped. I try to start the car and it doesnt even crank. When I try, the clock and radio dims off. I tried swapping starter relays and swapped starters and no difference. grrrrr
Old 10-05-2012, 04:54 PM   #4397
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
The clock and radio dim off when you try to start her up! How is your battery doing?
Old 10-05-2012, 05:02 PM   #4398
25rsti
Member#: 166324
It's brand new. I took the main relay out but don't know how to check it. Usually some of the relays have a diagram for each pin. This main relay doesn't.
When I first tried starting the car the fuel pump didn't prime and no click sound from relay. I traced down the relay and found original owner (Of used complete harness) spliced two of the wires and didn't connect them. So I soldered, heatshrinked and loomed them. Fuel pump works. Try to crank and get no "click" from main/starter so I thought maybe the main was bad and wanted to check it. I've gone over the complete cars harness several times now (again) and everything looks to be in order. All fuses are good too.
Old 10-05-2012, 07:16 PM   #4399
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
But did you test the battery. I can be D.O.A. Doesn't matter if its new. Rule out the simple stuff first.
Old 10-05-2012, 07:24 PM   #4400
25rsti
Member#: 166324
It gets 12v.
