#1 |
Member#: 294042
Just installed a set if pink injector on my 03 wrx, the car ran fine before the swap now the car send to hesitate at 4000rpm the car has a big 16g turbo swap as well.. Does it mean I need a bigger fuel pump or are the injectors no good? Ps I did change the filters and o rings before install
#2 |
Member#: 290517
Tri-State
Vehicle:2008 Impreza 2.5i Dark Grey Metallic |
a fuel pump wouldnt hurt it, but did you tune it when you put them in or reset it?
#3 |
Vehicle:OK Houston we have an Uncle |
pinks are NOT...no possible way...big enough for a 16g....and the pump is **** on the bugeyes
...replace that for sure, too and you can not just throw parts on a car and not tune it this is a disaster waiting to happen |
#4 |
Member#: 294042
I was planning on getting it tuned !! I just didn't understand why the car was chocking the way it was!! I just wanted to make sure that the injectors weren't bad before I take it to get tuned and I also have a fuel pump to install it
#5 |
Member#: 294042
Would a Cobb tuning accessPort help?
#6 |
Member#: 70395
MAIC
That's because you are a complete buffoon. Try reading the FAQ's and researching before you mod next time. You can not install larger injectors without changing the scaling in the ECU.
#7 |
Member#: 298271
NESIC
Vehicle:2004 WRX stage 2 PSM |
^ why no "like" button
#8 |
Member#: 296277
Vehicle:2002 Impreza WRX Silver |
yeah, you could have an amazing setup but it can run like complete poopoo if no tune ;(
#9 |
Member#: 94791
NESIC
Vehicle:2002 WRX wagon WRB Ver 8 EJ207 4.44's |
What is done to your car?
#10 |
Big Ron
Moderator Member#: 18062
MAIC
#11 |
Member#: 258491
South East
Vehicle:2002 VF34'd Bugeye My Other Ride's your MOM |
Your probably maxing out the pinks or at least close too it.....as for the pump....I had issues that little thing feeding my Td04 so I'm sure the 16g needs a pump upgrade
#12 | |
my p&p td04 @18psi maxed out the pinks any decent tune with ANY 16g will max the pinks at stupid low power PROBABLY??? NO 'probably' about it |
#13 |
Member#: 309967
BAIC
Vehicle:2003 WRX PSM vf34 |
No. An AP will only give you a limited amount of maps which include a vf39/vf34 for a stage 3 map. I dont believe there is a map for a 16g. That would be a protune. Your injectors are definately maxed out. I would suggest selling your 16g and getting a vf39/34. |
#14 |
Member#: 301037
Vehicle:2003 & 2006 WRX WRB & OBP |
I am surprised the car idles right. As others have stated you can not just put bigger injectors and larger turbo on the car and expect it to run right without a tune. There is a map for an FP 16g in the Accessport for an 03 WRX that uses 565cc injectors. Take a look at the map notes and see what it requires.
#15 |
Member#: 294042
Thanks for the info guys !!
