Old 08-08-2012, 02:39 AM   #1
orestes85
Member#: 299557
2011 STI
Exclamation The Turboturtle: ETS GTX3576, GSC S2, VOLK, VARIS, RCE
Car was purchased 19OCT2011
On 1JAN2012 on my way back from vacation my motor suffered a catastrophic failure of the #2 and #4 cylinder piston rings. At the time the motor had 6000 miles on it and was Protuned stage 2 making ~300whp 325wtq before WCF on a mustang dyno. Spec Ops Motorsports in Hope Mills, NC spent the next few months guiding me in the right direction and rebuilding my motor.
The motor rebuild consisted of
Honed Block
Check Tolerances
CP 99.5mm 9.0:1 Pistons
Element Tuning Rods
ACL Race Main & Rod Bearings
Gates Racing Timing Belt Kit
Master Gasket Kit
Deatschwerks DW65c Fuel Pump
Deatschwerks 850cc Fuel Injectors
Post-rebuild the car was retuned and currently makes 340whp/350wtq on 93 octane fuel.
Currently I'm working on finalizing the entire build and getting everything purchased. Hopefully by the end of this year all parts will be paid for and on their way into the car.
Misc:
Cobb Heat Shield
JPM Coachworks Shift Boot, Black/Red
JPM Coachworks Hand Brake Boot, Black/Red
Red LED Dome/Map Lights
JPM Coachworks Wrapped Dash
JPM Coachworks Wrapped Door Cards
JPM Coachworks Wrapped Center Console
Phase 1: COMPLETED
Cobb AccessPORT
Cobb Downpipe
Cobb SF Intake
Kartboy Endlinks
RCE Front and Rear Sway Bars
Cobb Front/Rear Shifter Bushings
Cobb Short Throw Shifter
Invidia N1 Race CBE
Phase 2: COMPLETED
NGK One Step Colder Plugs
CP 9.0:1 Pistons
ACL Race Main Bearings
ACL Race Rod Bearings
ARP Head Studs
Element Tuning H Beam Connecting Rods
Deatschwerks 850cc Injectors
DW65C
Hallman MBC
Phase 2.5:
Exedy Triple Plate Clutch
RCE Tarmac IIs
18x10 TE37SL Black Edition
GT Worx Camber Plates
Cusco Lateral Links
Rear Dif. Bushings
Subframe Bushings
Killer B Oil Pan
Killer B Oil Pickup
Killer B Oil Baffle
Phase 3:
Invidia EL Headers
Crawford AOS
StopTech Stainless Brake Lines
Slotted rotors
Group N Engine Mounts
Group N Transmission Mounts
Air Pump Delete
TGV Delete
Phase Ω:
ETS Rotated 3576 w/ Tial V-band Hotside
ETS FMIC, Rotated UP/DP
GSC S2 Cams
GSC Valvetrain
Build/Ported Heads
orestes85 is offline   Reply With Quote
Old 08-08-2012, 02:44 AM   #2
orestes85
Member#: 299557
2011 STI
Old 08-08-2012, 02:48 AM   #3
orestes85
Member#: 299557
2011 STI
Old 10-03-2012, 11:47 PM   #4
orestes85
Member#: 299557
2011 STI
Heads are being sent off to HeadGames for a port job and will be reassembled with GSC S2 cams and valvetrain. GTX3576 Rotated and Front Mount kit from Extreme Turbo Systems will be on the way around the end of this month with an Exedy triple plate and the car will also be getting a complete re-vamp of the fuel system with aeromotive fuel rails/lines/FPR. A koyo racing rad will also be going in.
Old 10-04-2012, 02:35 AM   #5
wolfmanRX
Member#: 317171
nice car loving the black
wolfmanRX is offline   Reply With Quote
Old 10-04-2012, 03:39 AM   #6
Dr Oppopuss
Member#: 312599
2011 WRX Limited
Awesome. What a curve.
Dr Oppopuss is offline   Reply With Quote
Old 10-04-2012, 01:40 PM   #7
Belyanin
Member#: 333576
Great pictures. You did a good job!
Belyanin is offline   Reply With Quote
Old 10-04-2012, 05:12 PM   #8
invaderzim
Member#: 201991
2011 wrx dom3'd
satin white pearl
nice setup should be fun as hell.
is that a smoked film you have on your tail lights? details?
invaderzim is offline   Reply With Quote
Old 10-04-2012, 05:38 PM   #9
orestes85
Member#: 299557
2011 STI
Thanks guys!
It is indeed window tint on the tails. 35% if I recall correctly. I'm thinking about going a little bit darker and/or trying to find a way to make the red show through a little bit less on sunny days.
Old 10-04-2012, 06:38 PM   #10
SubaruWrxNewb
Member#: 236017
That car and those pictures are awesome man.
It's nice to see a fellow NCer with good taste.
SubaruWrxNewb is offline   Reply With Quote
Old 10-04-2012, 07:52 PM   #11
orestes85
Member#: 299557
2011 STI
Thanks! It might be changing in the near future. I've got my eye on a suite of Varis stuff
Old 10-19-2012, 11:36 PM   #12
orestes85
Member#: 299557
2011 STI
GSC cams are on back order until next year so I've kinda run into a wall. I'll be buying the ETS 3576 rotated kit within the next month or so and upgrading the fuel lines/rails and probably getting some ID1000s or bigger. Hopefully the motor will be back together by the end of Jan.
Old 10-20-2012, 12:08 AM   #13
EnJoY120
Member#: 325247
2012 STI
Dying to see those RG-D's on the car!
EnJoY120 is offline   Reply With Quote
Old 10-20-2012, 03:12 AM   #14
orestes85
Member#: 299557
2011 STI
I can't decide between black or gold RG-Ds or maybe paying a bit more and going with the bronze RE-30.
RPF-01s are also sitting on the back of my mind right now :x I may pick up the enkeis later and just keep R Comps on them once I'm comfortable with a sticky sport tire on the track.
Old 11-06-2012, 02:43 AM   #15
orestes85
Member#: 299557
2011 STI
ETS Rotated GTX3576r setup paid for in full; http://www.extremeturbosystems.com/
Exedy Triple Plate Clutch also paid for in full; http://www.exedy.com.au/HyperMetalSeries.aspx
Ordered and paid for the following items from Bulletproof Automotive
Varis Carbon Bonnet
Varis Carbon Front Spoiler
Varis Carbon Side Underboard
Varis Carbon Side Splitter Fin
Varis Carbon Rear Diffuser
I also think I'll be going with my original choice of wheel, but in a slight variation.
TE37SL Black Edition in 18x10 +40 with 275/35r/18 Direzzas
Old 11-06-2012, 10:15 AM   #16
KriskoBG
Member#: 301000
Awesome car man
KriskoBG is offline   Reply With Quote
Old 11-07-2012, 12:05 AM   #17
orestes85
Member#: 299557
2011 STI
Thank you very much!
Old 11-08-2012, 02:40 AM   #18
orestes85
Member#: 299557
2011 STI
Happy birthday to meee
TE37SL Black Edition 18x10 +40mm and Dunlop Direzza Z1 Starspecs in 275/35r/18
Old 11-13-2012, 10:29 PM   #19
just_hatched
Member#: 199286
any pictures mounted yet???
just_hatched is offline   Reply With Quote
Old 11-14-2012, 06:56 AM   #20
orestes85
Member#: 299557
2011 STI
I'm out of the country until early next year, so I wont have any pictures for a while. As far as I know, my shop hasn't taken delivery of them yet either. When they do I'll post whatever photos they send me as well as the other stuff that is coming.
Old 11-28-2012, 12:09 AM   #21
orestes85
Member#: 299557
2011 STI
Old 11-29-2012, 03:09 PM   #22
ssalty
Member#: 334636
2006 Stage 2 WRX TR
Suscribed from a former Greenville NC scooby
ssalty is offline   Reply With Quote
Old 01-20-2013, 10:32 AM   #23
orestes85
Member#: 299557
2011 STI
7JAN2013
GSC S2s are no longer an option. I was left with the decision of sending my heads back to HeadGames to get them re-clearanced for Kelford 272s or go with GSCs S1 cam (268). Because the GSC S1 will work with the headwork I already had done, are available right now, and won't sacrifice as much drivability I decided that they would be the wise choice. After all, this is still a DD. If/When I get another vehicle that I enjoy driving and I can put the STI strictly on track duty (with the occasional romp through town) then a more aggressive cam can be put in if I desire.
I'm also tossing around the idea of buying a thrashed motor (or a completely fine motor if the price is ok). I want to have something I can take apart and figure out how everything goes together without taking my car out of commission. In the end this will hopefully save me some money and will definitely give me some peace of mind knowing that I've got a contingency plan for when this motor decides to grenade on me.
Lastly, a new fueling setup is on it's way. I'm looking at E85 capable injectors, new fuel lines, rails, possibly 2 bigger fuel pumps, and maybe a Q16 map. Matt @ Spec Ops is going to get some ideas to me and we'll come to a decision shortly. Hopefully this beast will be ready to go by the middle of next month.
Old 01-20-2013, 10:33 AM   #24
orestes85
Member#: 299557
2011 STI
15JAN2013
Registered for VIR with Tar Heel Sports Car Club on April 6-7, 2013. I might purchase another set of 18x10s (something cheap, used) and wrap them in a set of direzzas as well. I'm just concerned with fuel. I'd like to run Q16 but I have no way to really transport 20-30 gallons of extra fuel. I may just get a 110 tune since I know they have a 110 pump at VIR. I don't REALLY need the extra power from Q16 anyway.
Old 01-20-2013, 10:33 AM   #25
orestes85
Member#: 299557
2011 STI
Still waiting on a set of cams. GSC s1 for DAVCS are also nowhere to be found...A source has 2 sets of cams for DAVCS supposed to arrive next week, s1s and s2s apparently...so whichever set arrives first will be getting sent to me and that will be what the car is running. I'm also kinda writing a blank check so that the shop can have free reign to do whatever they need to do to finish up the rest of the car (MAP Sensor, Fueling, Cooling, finishing items).
