Old 10-04-2012, 06:47 PM   #1
Danthrax
Member#: 299368
2014 Impreza 2.0i
Default Keep / sell the wrx
I have a 2002 with 72k miles on it. Everything is in great condition but what else, the transmission. My fourth gear synchro is shot and will cost 1000 to drop the tranny and fix it. Would it be worth dropping the tranny or should I sell it and go off and buy a different subaru?
Danthrax is offline   Reply With Quote
Old 10-04-2012, 06:55 PM   #2
SubieMonte
Member#: 264803
2005 WRX Wagon
Unabomber in. 3.....2.....1......
SubieMonte is offline   Reply With Quote
Old 10-04-2012, 06:59 PM   #3
Newkid17
Member#: 334165
Me personally I love my wrx! I would do anything to keep it on the road, but I do all the work to anything myself to, which saves a lot of money! As most of you know!
Newkid17 is offline   Reply With Quote
Old 10-04-2012, 07:13 PM   #4
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Try ending a sentence with punctuation other than an exclamation mark.
OP: a new car will cost more than $1K.
Spenk is offline   Reply With Quote
Old 10-04-2012, 07:17 PM   #5
NW Rex02
Member#: 314030
2002 wrx
just fix it. if you really love the car then that is the better decision. to me, spending a grand to fix it sounds a hell of a lot better than losing money on selling it, and then trying to go find another car you can afford.
NW Rex02 is offline   Reply With Quote
Old 10-04-2012, 07:18 PM   #6
NW Rex02
Member#: 314030
2002 wrx
not to mention the low mileage for that year wrx. i also have an 02 wrx. but mine is about to roll over 120,000 miles.
Old 10-04-2012, 07:30 PM   #7
TehFulg
Member#: 333035
04 WRX GD
I would just fix it unless you intend to to buy a newer wrx. Look at it this way, your car only has 72k miles and its an 02. It should have a very long life left if taken care of properly. If you go to sell it your going to take a pretty big hit because it needs repairs.
I know it sucks to drop a stack, but its probably the best thing to do.
TehFulg is offline   Reply With Quote
Old 10-04-2012, 08:15 PM   #8
pghana66
Member#: 302066
at 72k you r looking at new struts sooner than later. that will cost anywhere from 350$ to over a grand for oem replacement, pending on if u do the labor or not. most other major maintenances will be at 100k+. it comes down to what u want, either a higher mileage car with maintenace costs or a new car with nothing but a monthly payment. this is all assuming u r not modding it out.
im at 145k n havent had any major problems n costs. new radiator, struts, timing belt, general tune ups, had a power steering leek. going to replace the clutch n fw at the end of the year. all in all its been nice not having payments for the last six years n i like working on it myself.
i cant comment on the trans issue ur having cuz i havent had an issue. ive seen ppl post good n bad bout the trans. seems mostly those with mods r running into poblems.
if ur not into ur third or fourth set of tires by now, that'll be up soon. of course, like stated all ready, youll have to put some $ into it to get a fair shake on the sale.
think about if ur trading in or going private. trading at dealer will be a loss. private sale might get u what its worth if ur trans is fixed. lots to consider.
fix or sell, ur still gonna have to shell out some dough unless u just sell at an adjusted cost. buying new means shelling out a downpayment n then a monthly bill for three to five.
pghana66 is offline   Reply With Quote
Old 10-04-2012, 08:24 PM   #9
when was the last time the lube in the trans was changed??
Old 10-04-2012, 08:29 PM   #10
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I would just find a used transmission in the fs section for $5-900 and drop it in. Then sell yours for a few hundred to someone looking for a transmission to rebuild.
2gnt2wrx is offline   Reply With Quote
Old 10-04-2012, 09:43 PM   #11
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
This. Answer it. It might save you $1000. And be SURE to state what kind/brand/flavor of trans fluid was used....if you don't know say so.
Old 10-04-2012, 09:44 PM   #12
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
or just skip 4th from now on :P
tebriel is offline   Reply With Quote
Old 10-04-2012, 10:49 PM   #13
Newkid17
Member#: 334165
Exclamation mark is a form of punctuation!.....
Old 10-05-2012, 10:54 AM   #14
Danthrax
Member#: 299368
2014 Impreza 2.0i
I have no idea when it was last changed, what trans fluid should I get, because I love this car and want to save it if possible.
Old 10-05-2012, 11:23 AM   #15
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
My advice:
Dump whatever fluid you have now.
Refill case with Redline lightweight shockproof.
Good ebay deal on how much you need with here: http://www.ebay.com/itm/RED-LINE-LIG...9c5041&vxp=mtr
Dump in 3 qts, then add/check/add/check until full.
Odds are it will cure all ills. If not, you wasted $XX on fluid and now you know your synchro is 100% toast and you need to use the expensive solution.
Old 10-05-2012, 12:05 PM   #16
Danthrax
Member#: 299368
2014 Impreza 2.0i
My advice:
Any more opinions on this idea? I like it but before 70 dollars are spent I'd like to know
Old 10-05-2012, 12:56 PM   #17
pghana66
Member#: 302066
just curious, what is the symptom of the synchro issue?
Old 10-05-2012, 02:51 PM   #18
Danthrax
Member#: 299368
2014 Impreza 2.0i
Shifting into fourth gear at high rpms, like 4500+ from third to fourth.
Old 10-05-2012, 03:02 PM   #19
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
That's how to produce it, but what actually happens?
Counterfit is online now   Reply With Quote
Old 10-05-2012, 03:20 PM   #20
Danthrax
Member#: 299368
2014 Impreza 2.0i
I feel a grinding in the shifter and it makes a loud bite sound.
Old 10-05-2012, 03:41 PM   #21
leecea
Member#: 37359
Even if you plan to sell the car, it still makes sense to fix it. Anyone buying the car as-is will beat you down on price by more than the $1000 it will cost to fix.
leecea is offline   Reply With Quote
Old 10-05-2012, 04:23 PM   #22
Counterfit
Member#: 124254
"The Scoobinator"
^ This. I just watched an episode of Wheeler Dealers, where he knocked 500 of the buy price of the car (a Bond Bug, think Reliant Robin ) because of some grinding. The replacement transmission cost 75
Old 10-06-2012, 02:52 AM   #23
STIll inspired
Member#: 248431
low mileage bugeye... definitely worth repairing in some way.
STIll inspired is offline   Reply With Quote
Old 10-07-2012, 04:52 PM   #24
rallybluewrx02
Member#: 334400
Default i feel the same way....
i jus bought a 02 wrx and my tranny is broken already
rallybluewrx02 is offline   Reply With Quote
Old 10-07-2012, 06:06 PM   #25
Counterfit
Member#: 124254
"The Scoobinator"
Something something PEBCAK PEBSASW?
