Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 10-04-2012, 09:04 PM   #1551
driftns2k
Member#: 333106
Originally Posted by noside View Post
More gold then your local jewelry store.
I have to get some pictures of a few other things, I spent about 15 hours wet sanding and polishing bare aluminium fuel rails, and a sheet metal intake manifold on the brother in laws 427sb looks tittys now with billet cnc heads and valve covers! I'm trying to figure out how to tackle doing the blower, charge piping and awic next. I spend a lot more time on that car then I do my own especially when it comes to custom modifications. Everything is one off custom made. even our injectors are billet adonized and polished
Did you by any chance measure your intake temps before and after? I'm wondering if this has been proven effective?
driftns2k is offline   Reply With Quote
Old 10-04-2012, 09:42 PM   #1552
CaseyMurphy
Member#: 329119
2002 Impreza
Default Shift Knob.
You should have put that on the hand brake! It looks so nice though. Cool idea!
CaseyMurphy is offline   Reply With Quote
Old 10-04-2012, 11:01 PM   #1553
gregroot198521
Member#: 280844
2006 STi
Originally Posted by Dale2011WRX View Post
Yeah I'm not going anywhere, so you can either get used to it, or stop being such a self-important blow-hard.
Failing to see how I'm being A) self-important or B) a blow-hard. I'm asking a simple thing, post unique mods or relevant things. Haven't seen any of either from you. Not hard to understand my dislike of your posts and attitude. Genius.
Originally Posted by garudatwo View Post
Easy gents, let's play nice here. We're all grown ass adults, yeah?
I've found two bolts on the mid section of the radiator support. If I twist the mounting flat bar for the hella horns, I can get them to stay within the bumper cover but angled upwards such that the sound projects to the outside, instead of inside.
I'm a big fan of those lower grill meshes, but to be honest, it's REALLY easy to work on the stuff between the bumper and the radiator when I can access them from that gap. Hell, back when I only had hella horns, I installed them without ever taking off the bumper/grill thanks to that.
I'd almost suggest pointing them downward so maybe they would reflect the sound upward off the ground. You know, since they are "directional" and all. Blast pattern on everything in front is a direction, kind of..... Pretty ingenious/lazy installing them through the hole. Only takes a few minutes to get the bumper cover off though, lol. Then again, I'm biased, I can't fit my baboon arms in there with the cover on anyways. I second installing them in the foglight spots, just put mesh in front of them. Dude on IWSTI has a crazy build that he used some chopped-up and fiber-glassed flower pots as a part of his covers. Here's the post: LINK.
Like that sort of, just with mesh in the front end, maybe a few layers to prevent too much crap from getting in.
Originally Posted by xlaterdaysx View Post
I'm retarded to not even think of that, as I will be installing Hellas soon. But I figured this will give me the opportunity to change my mesh grill up top and add one to the bottom.
That's what I ended up doing.... Worked well enough, I think. Until the raccoon "modified" my bumper.... Stupid raccoon...
gregroot198521 is offline   Reply With Quote
Old 10-04-2012, 11:06 PM   #1554
garudatwo
Member#: 322385
Are you the one who posted up a pic of the bumper with "stitches"? 'Cause that looked freakin' badass.
I have the OEM fogs in right now, so maybe I'll sell them and put the hellas there. Then again, it'd be almost the same as having them in the lower grill area in terms of problems during the winter. By the way, does anyone have a good way of removing the brackets that comes with the hellas? I run a 300 PFT and I'm having problems getting it off....
As for removing the bumper, I'll get around to it eventually. Was in a hit and run about 3 weeks after I took delivery...some prick hit my car in the parking lot and didn't leave a note. There's a 12"x1/8" streak of paint missing from my front bumper...
A bit off topic, I was trying to record a video of my '11 WRX's clicking clutch problem, and in the middle of it it developed into the "broken firewall weld" squeak problem. Daggon 3G WRX...
garudatwo is offline   Reply With Quote
Old 10-04-2012, 11:20 PM   #1555
gregroot198521
Member#: 280844
2006 STi
Wouldn't be surprised if it was mine, lol. That was a long while ago then, since I got the metal bumper made 3 or 4 months ago.
Could always mount the lights down there, but that would remove some of the uniqueness. It'd still be cool though, just like most of that dudes build. Bunch of nifty but inexpensive mods. I took the brackets off my hellas using a concrete step to hold them in place (horn off the edge of the step) stand on the bracket and break that bitch free.
Sucks about the bumper, at least my destruction waited till almost a year into ownership..... Lead to some good times, and some great learning experiences though.
Old 10-04-2012, 11:25 PM   #1556
garudatwo
Member#: 322385
Oh **** you're the guy with the mad max WRX on dirty Impreza! Big fan here. Been wanting to get mine lifted as well. Would you mind posting your suspension/wheel/tire setup?
Old 10-04-2012, 11:55 PM   #1557
gregroot198521
Member#: 280844
2006 STi
This one?
Suspension: Feal revalved/inserts (gravel spec) front struts and Feal rear struts (gravel spec also) on ~1.5" lift King springs and 1" strut top spacers (Subtle Solutions lift kit). Wheels are Braid Winrace TA's in 15x6.5+45 dual drilled for 5x100 & 5x114.3 with steel inserts riding on 215/70R-15 Yokohama Geolandar A/T-S. Enjoy.
Old 10-04-2012, 11:57 PM   #1558
garudatwo
Member#: 322385
That's the one! And thanks, my goal for 2013 is to have that suspension setup when I hit the backroads in Maine.
Old 10-05-2012, 12:08 AM   #1559
gregroot198521
Member#: 280844
2006 STi
I'd probably skip the 1" spacers if you enjoy sticking to the road though, mine slips around turns pretty bad now. Then again it's probably a combo of large floppy tires, higher COG, my endlinks being essentially ****ed, and just generally needing to go through my entire setup and do adjustments on stuff. it was pretty stiff and tight at first though..... Oh, and no problem, glad to help.
Old 10-05-2012, 12:20 AM   #1560
mattesonb
Member#: 139607
DGM Wrapped Satin Black
for those of you that remember, i purchased a set of LED lights and the seller sent me some blue ones. today a correct set arrived that are actually white.
the bonus on these is that the lens comes off with 2 screws from the front, thus when winter comes i will be able to pull the front off, wrap the lens with tinted yellow vinyl and easily but them back on.
mattesonb is offline   Reply With Quote
Old 10-05-2012, 12:24 AM   #1561
easterbran
Member#: 307359
'05 STi Stage II
Much better, looks great!
easterbran is offline   Reply With Quote
Old 10-05-2012, 03:02 AM   #1562
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
Well of course you fail to see it.
self-important = a person who overestimates their own importance and exhibits arrogant or pompous behavior
You're just one more schmuck on this forum, but through your posts it's clear that you have appointed yourself arbiter of what is "unique" and therefore what is worthy of being posted in this thread. You also appear to believe that you have the power to compel others to leave this thread or stop posting on it. Wrong on both counts.
Ask for whatever you want...
Dale2011WRX is offline   Reply With Quote
Old 10-05-2012, 10:03 AM   #1563
gregroot198521
Member#: 280844
2006 STi
Agreed, completely.
Dale, you've been added to the ignore list, since you are obviously a pompous turd who can't get the hint. Good luck, hope you figure out how to grow up and add to the discussion.
Old 10-05-2012, 10:07 AM   #1564
Dale2011WRX
Member#: 304299
2011 WRX, white
Excellent, now I can comment on your idiotic remarks without generating more of them.
Old 10-05-2012, 10:14 AM   #1565
microsnook
Member#: 313952
2006 STi
SGM DOM 3xt-r
Youre on this forum now?! Remember me from IWSTI?
microsnook is offline   Reply With Quote
Old 10-05-2012, 10:15 AM   #1566
Devon
Member#: 321595
2005 Legacy GT
And bam. still have to aim them:
Looks great man! Really making me want to blow some money on some fog or spot lights right now... Haha
Devon is offline   Reply With Quote
Old 10-05-2012, 11:22 AM   #1567
gregroot198521
Member#: 280844
2006 STi
Yeah, good job, tool. Look at the difference between my post history and yours. One has mostly useful comments and questions to clarify things (mine) the other (yours) has stupid, snarky comments. Blow-hard.
Lol, this is the first forum I started on, though I joined most during the same time frame. You have the same s/n on IWSTI? Don't remember though, sorry....
Big difference between the 2, but if you don't mind having square or rectangular lights, check out Rigid Industries LED lights. Great quality and output. If you look at my pic I posted earlier you should be able to see the square D series lights, same size as the D2s they now have. Also they have some the same width but with a single row of LEDs, something like 1.5x3", IIRC.
Old 10-05-2012, 02:29 PM   #1568
Devon
Member#: 321595
2005 Legacy GT
Lol, I understand there is a big difference, so I need to decide what I will need them for in the first place. But regardless I would like to eventually work on something along those lines.
I'll have to look into those LED's. loving the ideas though.
Old 10-05-2012, 02:56 PM   #1569
Dale2011WRX
Member#: 304299
2011 WRX, white
This is like having a battle of wits with an unarmed man.
And I thought I was on your ignore list?
Old 10-05-2012, 03:11 PM   #1570
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
ok fellas simmer down
burkart is offline   Reply With Quote
Old 10-06-2012, 11:00 AM   #1571
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
I though I'd try my hands at making halos for my headlights to accent the red eyes. plus it was a cheaper option then buying the kit from the online stores. Here are a few pics of the progress.
materials:
LED's = 4$
Resistors = 2$
Blind adjuster rods = 4$
Heat wrap = 6$
Lead free solder 5$
Total Cost: 21$
Tools:
drelmel
oven
tape
wire pliers
screwdriver
socket wrench
gorilla glue
spent all night but I think it paid off. I will get better pics of them when it gets darker.
ravenlunatic is offline   Reply With Quote
Old 10-06-2012, 11:03 AM   #1572
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Originally Posted by ravenlunatic
I though I'd try my hands at making halos for my headlights to accent the red eyes. plus it was a cheaper option then buying the kit from the online stores. Here are a few pics od the progress.
Day time pics pls
krzywhtboi82 is offline   Reply With Quote
Old 10-06-2012, 11:11 AM   #1573
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
That's pretty slick. So you just heated up the blind adjuster rods so you could bend them into a circular shape, then stuck LEDs into either end?
Old 10-06-2012, 11:26 AM   #1574
garudatwo
Member#: 322385
That's awesome, mine's just lame now:
Relocated the GR's clock pod to the 2nd din compartment instead of my cubby hole.
Old 10-06-2012, 11:26 AM   #1575
ravenlunatic
Member#: 180601
2003 PSM WRX
yup, (to Pat)
i like the flocked dash.
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
