Old 10-03-2012, 10:52 AM   #51
ScubyPhilly
Member#: 213303
2009 Impreza 2.5i
Higher octane fuel is, in short, just more resistant to knock. Having great knock resistance allows for more advanced timing, creating more power. That's the best I can explain without writing an entire chapter of text. Subaru's EMS will advance timing, if only a little, to accommodate higher octane fuel. Typically the difference is negligible at best, unless you get tuned for the higher octane.
ScubyPhilly is offline   Reply With Quote
Old 10-03-2012, 06:52 PM   #52
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Hehe **** rules my car can advance timing.
Even if to gain .5hp.
I'd get 91 oct just to get 0% ethanol if I had some extra money to waste.
And yeah thanks, I understand pretty well how the timing works, just wasn't sure if Subaru had implemented anything that could adjust for slightly higher than normal octane.
goregasm is offline   Reply With Quote
Old 10-04-2012, 11:00 AM   #53
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Octane does not in and of itself guarantee better performance and or mileage. Ethanol increases the octane rating; however, decreases both performance and mileage - also cost in many areas.
G-Omaha is offline   Reply With Quote
Old 10-04-2012, 01:38 PM   #54
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Actually ethanol only decreases performance in a car that wasn't made to handle it. Ex: Koenigsegg CCXR Edition, something like 810rwhp on regular pump 93 octane. I believe more than 1100HP on E85. (not sure of the exact numbers, but it's significant, at least 150HP increase)
Old 10-04-2012, 01:49 PM   #55
ans2k
Member#: 315631
2012 Impreza
i'm pretty sure he was referring to the comparison of pure gas and gas + ethanol with the same octane rating.
ethanol in itself produces les power per unit volume than gas at the same octane. E85 has a very high octane rating that can allow you run very advance timing or a lot more boost. you could do the same with pure race gas at 110 octane but the the cost of race gas was something like $7.50 a gallon 5 years ago. i have no idea what it is now.
Old 10-04-2012, 02:01 PM   #56
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
oic..
Old 10-04-2012, 10:39 PM   #57
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
So running E85 on our cars would result in increased wear and therefore not recommended, since our engines were not designed for it?
Old 10-04-2012, 11:03 PM   #58
ans2k
Member#: 315631
2012 Impreza
Originally Posted by pkL View Post
So running E85 on our cars would result in increased wear and therefore not recommended, since our engines were not designed for it.
yea, and a whole lot of thing. we would need upgraded fuel pump, fuel lines and fuel injectors.
Old 10-05-2012, 01:14 AM   #59
pkL
Member#: 313093
2012 Impreza 2.0i
On the other hand, I can get my car tuned to run on a higher octane? 87 vs 89; however, I don't really see the point on an econobox.
Old 10-05-2012, 01:20 AM   #60
ans2k
Member#: 315631
2012 Impreza
i mean the gain from 87to 89 is minimal, why not 93? but you are right why do it anyways? lol
Old 10-05-2012, 01:34 AM   #61
pkL
Member#: 313093
2012 Impreza 2.0i
Because whatever performance and mileage gains will be offset by the price of the tune (which is not even available) and the higher octane gas. Screw that I work in an environmental analytical lab, my car is going to run on a mix of isopropanol, methanol, and ethanol!
Old 10-05-2012, 02:36 AM   #62
ans2k
Member#: 315631
2012 Impreza
lol good luck, have fun. i wonder what subaru is going to say when your engine blows. i mean can you imagine the mechanic's face wondering why the engine blew and then sniffs the air, "is that alcohol?" then they have to prove you didnt use gasoline. man wonder if subaru would actually go through that much trouble.
Old 10-05-2012, 04:10 AM   #63
pkL
Member#: 313093
2012 Impreza 2.0i
Shhh...it's our little secret. If it was a major warranty claim for an issue as severe as this, Subaru would go through all that trouble to refuse your warranty claim.
Old 11-05-2012, 07:21 AM   #64
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
One thing I have noticed is that when the CVT is taking forever to shift up (it's still shifting, just not in the traditional sense) if I push it over to low it goes right up to 6000 almost instantly.
Old 11-05-2012, 07:33 AM   #65
tibug
Member#: 273906
1831 Conestoga Wagon
My oxen all died.
I feel bad for the poor chap who will buy your used Impreza. Keep it till you kill it please.
tibug is offline   Reply With Quote
Old 11-05-2012, 08:45 AM   #66
Zeeper
Member#: 299286
2012 Sport 5MT
Green/Silver
Ah, it was only driven gently, on Sundays, to church.
I don't know what those sounds are from the transmission, but they're normal, it always made those sounds...
Old 11-05-2012, 05:11 PM   #67
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Especially in "L"......
Message Board Statistics All times are GMT -4. The time now is 05:30 AM.
