Old 10-05-2012, 12:34 AM   #1
krystianb10
Member#: 320710
Default Am I screwed?
Tonight I was backing out of my driveway (its really long but not too wide). My dads massive pick up truck was parked on the right side and I was on the left. Being that it was really dark out my judgment was a bit off and I lightly hit his car but quickly stopped and drove it forward.
His car is already beat up from construction so you can't tell it was hit. But the car I was driving (02 durango) got some white scratch marks and a deep scratch on the rear fender. I was able to wash away the white marks but was wondering what my options are for the deeper scratch that won't wash away?
krystianb10 is offline   Reply With Quote
Old 10-05-2012, 01:47 AM   #2
subaruBnoobie
Member#: 309963
2004 WRX Wagon
Post pics if you can. however; Depending on how much you scratched through the paint, your cheapest option would be the following:
- fill the scratch with factory touch up paint (3-4 times or until its at or above the original paint surface level)( Let dry as long as you can between layers)
- Wetsand the work area after its COMPLETELY dry to blend the touched up area; Finishing with 2500-3000 grit paper.
- Compound, polish, & wax (With a Multi speed DA Polisher and proper foam pads for best results)
- Take pics of your results and post em!
I recomend using a DA Polisher with foam pads if you are a beginner and are not comfortable with a rotary and wool pad. You can get very good results with the DA and foam pads, and they are almost fool proof.
*Quick tip if there are any white marks or paint marks left that didnt wash away. Use a wet magic eraser (Wal-Mart) to get off any extra paint or scuffs. Be as light as possible and polish, & wax after to clear up the haze it will leave.
subaruBnoobie is offline   Reply With Quote
Old 10-05-2012, 01:53 AM   #3
subaruBnoobie
Member#: 309963
2004 WRX Wagon
